Old Dec 09, 2012, 02:25 AM
theothercliff is offline
Find More Posts by theothercliff
Temple, GA, USA
Joined Jun 2009
Originally Posted by HZSuperCub View Post
its just like i add 1% throttle , no motor starts to spin but the rudder servo just goes mental , i dont know what to do.
It sounds like a servo update rate problem. Try setting the rate faster or slower.
theothercliff is offline Find More Posts by theothercliff
Old Dec 09, 2012, 04:58 AM
Acit is offline
Find More Posts by Acit
Acit's Avatar
Singapore
Joined Sep 2012
Originally Posted by rcroadtrain View Post
Yes, its the message that you want to see.
make sure throttle is on full, Tx turned on, pull M1, power the escs, hold the buttons, plug M1 back in (while holding the buttons down). You should see the message, and hear your escs/motors 'beep'.. reduce throttle to min, should hear another beep.
Done.
Thanks Rcroadtrain, for this confirmation. I'm on the right track
Acit is offline Find More Posts by Acit
Old Dec 09, 2012, 05:54 AM
geedee is offline
Find More Posts by geedee
Chester, UK
Joined May 2010
Auto level with DX7
Could someone please point me to where I may find info on how to set up Auto level with my DX7
I presume that when the Quad is in flight, I can switch either the Gear or Aux switch and this actuates the self level function.
Many thanks
geedee is offline Find More Posts by geedee
Old Dec 09, 2012, 06:35 AM
MoRaLeSD is offline
Find More Posts by MoRaLeSD
^(_MăĻēŜĐ_)^ ЯuĽe U
Greece, Attica, Elefsina
Joined Sep 2010
Originally Posted by brontide View Post
PI(D) tuning, just google it already. It takes a while to wrap your head around, but below is a very simplified model of how the KK2 works.
(1) Stick movement * stick scaling -> (2) limit(Input * P gain + Error * I gain) -> (3) Mixer is the output stage, it takes the PI(D) values and mixes them to get motor output.
1 Is the input stage, it takes the stick movements and multiples them by the stick scaling
1a Height dampening adjusts the throttle input based on accelerometer
2 Is the PI(D) stage which takes the stick, gyro, and acc data to create pitch, roll, and yaw output data
3 Is the mixer that takes the throttle, pitch, roll, and yaw and translates them into motor commands ( M1 = throttle * m1 throttle mix + pitch * m1 pitch mix + roll * m1 roll mix + yaw * m1 yaw mix + m1 offset ).
Its a little bit difficult but understandable! I have seen some videos from KK too and I can understand now hot these things works. Thank you very much!!!
MoRaLeSD is offline Find More Posts by MoRaLeSD
Old Dec 09, 2012, 06:37 AM
MoRaLeSD is offline
^(_MăĻēŜĐ_)^ ЯuĽe U
Joined Sep 2010
Originally Posted by tedrobphoto View Post
Yes, Any idea on settings?
Someone wrote to me to start with 10 or less to H. Dampening and see in flying how it reacts. If you need more or less you adjust and this is what I am going to do!
Old Dec 09, 2012, 06:41 AM
MoRaLeSD is offline
^(_MăĻēŜĐ_)^ ЯuĽe U
Joined Sep 2010
Many thanks
Make the menu in AUX and then find witch switch goes on what channel. My futaba 7c can lets say:
Channel 5 > Switch E. So if I connect to RX channel 5 to the 5th pad on KK2, the E switch is the one that Activates the Self level. Find in your menu where you can select the switches to be and select the one you want to the 5th channel. I think this will do!
Old Dec 09, 2012, 08:13 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Originally Posted by helizrnew2me View Post
same thing happened to mine
http://www.rcgroups.com/forums/showp...postcount=7669
i got a new board coming but afraid to try again .
Same thing happened to me as well
The best cure I found up to now is a new board
Upup is offline Find More Posts by Upup
Old Dec 09, 2012, 10:14 AM
geedee is offline
Chester, UK
Joined May 2010
I will try this tomorrow when I return home.
Looks like this should work OK
Old Dec 09, 2012, 11:14 AM
Gladiac is offline
Find More Posts by Gladiac
Joined Sep 2010
Hi there!
I just solved the mistrery of my non working samera stab
I had to connect power for servo into the reciver and now it works
Thanks for all your trouble and replys.
Best regards and happy holidays to all
Gladiac is offline Find More Posts by Gladiac
Old Dec 09, 2012, 11:23 AM
helizrnew2me is online now
Find More Posts by helizrnew2me
helizrnew2me's Avatar
United States, PA, Slatington
Joined Sep 2010
did you try flashing your new board?i`m afraid to try now ,dont wanna brick another board .especially now that its up and flying again .
helizrnew2me is online now Find More Posts by helizrnew2me
Old Dec 09, 2012, 12:35 PM
yarg is offline
Find More Posts by yarg
United States, IN, Greenwood
Joined Oct 2011
My quadrotor yaws slightly to the right, but only when applying thrust. It's slight enough that it doesn't really effect things too badly, but enough so that I have to stop and correct the direction I'm facing as I'm practicing.
Any idea what's causing it? I admit, my props aren't balanced, but I'm not sure if that would be enough to cause this.
yarg is offline Find More Posts by yarg
Old Dec 09, 2012, 12:53 PM
srepfler is online now
Find More Posts by srepfler
srepfler's Avatar
Croatia, Osijek-Baranja County, Valpovo
Joined Jul 2011
KK2 on cold wind and sub zero temperature (-5 .. -7 C).
srepfler is online now Find More Posts by srepfler
Old Dec 09, 2012, 01:56 PM
CO2X is offline
Find More Posts by CO2X
CO2X's Avatar
United States, CA, Hayward
Joined Oct 2010
yaws
Start by trimming it and balancing your props and go from there.
CO2X is offline Find More Posts by CO2X
Old Dec 09, 2012, 02:11 PM
Joined Sep 2010
cool pictures .....
Old Dec 09, 2012, 02:52 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
Balance your props anyway.
tried increasing yaw gyro?
rcroadtrain is offline Find More Posts by rcroadtrain
