Old Dec 06, 2012, 08:56 AM
vivazapata is offline
Find More Posts by vivazapata
France, RA, Roche-la-Moličre
Joined Sep 2012
Originally Posted by brontide View Post
No settings should have an effect on ESC calibration since it passes the signal through.
Excuse me but i don't speak english very well
So you confirm me that for the ESC calibration , i must have self level off ?
Thanks a lot
vivazapata is offline Find More Posts by vivazapata
Old Dec 06, 2012, 09:04 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Thanks a lot
does not make a difference
brontide is offline Find More Posts by brontide
Old Dec 06, 2012, 09:06 AM
Joined Sep 2012
Ok thanks
Old Dec 06, 2012, 09:12 AM
brontide is offline
Joined Sep 2012
http://oddcopter.com/2012/11/08/trou...ht-controller/
Old Dec 06, 2012, 09:13 AM
oyibox is offline
Find More Posts by oyibox
Joined Jun 2011
sorry if it's been asked before...
which one gives a better cal :
- ESC cal through KK2?
- ESC cal through a 4in1 pin header connected to Th channel receiver?
- ESC cal done1 by 1 through throttle channel receiver?
are all of them the same result?
oyibox is offline Find More Posts by oyibox
Old Dec 06, 2012, 09:19 AM
MoRaLeSD is offline
Find More Posts by MoRaLeSD
^(_Mđ®ăĻēŜĐ_)^ ЯuĽeŽ U
Greece, Attica, Elefsina
Joined Sep 2010
After some trimming I managed to make it work in Self level mode. My ony thing is that it is UP or DOWn in throttle. A click of + throttle it speeds and a click of - throttle it goes down I cant make it hover stable :P
MoRaLeSD is offline Find More Posts by MoRaLeSD
Old Dec 06, 2012, 09:31 AM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
RIP KK2
shafter is offline Find More Posts by shafter
Old Dec 06, 2012, 09:37 AM
srepfler is online now
Find More Posts by srepfler
srepfler's Avatar
Croatia, Osijek-Baranja County, Valpovo
Joined Jul 2011
ESC cal through KK2
srepfler is online now Find More Posts by srepfler
Old Dec 06, 2012, 09:53 AM
trinco is offline
Find More Posts by trinco
☢ ɴᴏᴏʙ ☢
trinco's Avatar
Malaysia
Joined Mar 2012
this is what i did to get the best result
then
- ESC cal through KK2 by holding button 1 & 4
trinco is offline Find More Posts by trinco
Old Dec 06, 2012, 10:02 AM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
Originally Posted by RC_Kid View Post
Hey, everyone.
I have a problem with my KK2.0. I am almost sure it is my fault, though.
I have been flying my FPV quad for a few weeks now. I have had great luck with the KK2.0, except for the arming. I need to leave it on always armed as I can't get it to arm with rudder. I have made sure the rudder channel reads 100% in both directions on the RX test. But it still will not arm. This is on firmware 1.2.
I have just updated to 1.5 to take advantage of autolevel, but there is no more always armed setting. Does anyone have any ideas how to arm the board?
Thank you so much in advance.
Will
You should start with a "new airplane model" in your computer radio to get all default trims (and settings). Search "KK2 quick setup guide" on youtube. It tells about making sure the trims and sub-trims are centered to avoid this issue. Lastly, I understand that v1.5 has changed the servo throw ranges for this exact reason.
Good luck. Hope this helps.
theothercliff is offline Find More Posts by theothercliff
Old Dec 06, 2012, 10:08 AM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Are the ESC's that you are using flashed with SimonK? If not, you could have one ESC that has different settings, such as the type of start, etc. The calibration process does not perform these settings. You can program each ESC via a programming card and/or your transmitter.
rcjose is offline Find More Posts by rcjose
Old Dec 06, 2012, 10:24 AM
Temple, GA, USA
Joined Jun 2009
Originally Posted by shafter View Post
It's just theory, but In reality you will burn your ESC's or motors when quad crash land on failsafe set in this manner.
You are not first to try this, and not first to fail badly.
There are only two valid failsave options for multirotors and using other methods will get in you trouble:
1. Cut all engines to 0% aka NO PWM-PPM
2. GPS-RTH procedure.
If you are below tree-top level, RTH will crash into a tree and potentially burn an ESC there (depending on how smart the ESC firmware is).
If you are high up, motor shutoff could get you in more trouble than hover down power.
You take your chances no matter which way you do it. Someone who flies at 20 feet over mown grass might choose hover down and someone who flies FPV at 400 feet might choose RTH. Someone who flies over thick forest, but has no GPS may choose power cut.
Old Dec 06, 2012, 10:33 AM
Temple, GA, USA
Joined Jun 2009
M1 output give more throttle to the motor than the others. I have tested it by adding the motors opposite. M1 to the YAW motor and M3 to front left. Either way the motor in the M1 slot is spinning gradually more and more.
If you have configured the board so that it knows that M1 got moved to the yaw motor then I'm afraid that sounds like a bad board. You could try re-flashing to see if it goes away. You could try a different version of flash (v1.5) to see if it moves to something you can live with.
One or two motors, when I throttle just a little, they behave like when they are connected to the ESC with 2 cables and cant spin, after I throttle a little bit more they spin like they should. Is this all problem ESC calibration? Because with the KK v3 Blue board it flies just immediately with no trims required. What can I do? Any suggestions?
This is a problem that the ESC is not working well with that type of motor. It is common with several motor and ESC pairs.
It sounds like your v3 board "jumps up" and skips the "slow spinning" where the problem exists?
For unflashed ESCs, you might try adjusting the timing of the ESC using the ESC's beeping menu with the ESC directly connected to the receiver throttle channel. If you are running flashed ESCs, you might try the latest version or send a message to SimonK (who wrote the ESC code for multicopter).
Old Dec 06, 2012, 10:38 AM
brontide is offline
Joined Sep 2012
Originally Posted by Sudsy View Post
Check "Failsafe" settings too. It's a terrible thing to watch your new quad sail off into the blue! I set mine to just above hover so in theory it will make a slow decent when the batts start going low!
I don't know about your multi, but slightly above hover and my unit can gain altitude pretty quickly.
Old Dec 06, 2012, 10:43 AM
Temple, GA, USA
Joined Jun 2009
M1 to left motor = Left motor Spins MORE.
M1 to yaw motor= Yaw motor Spins MORE
Either way the motors connected to M1 spins more than the others. ESCs are calibrated.
Does it still think that the M1 is connected to the left motor when you connect it to Yaw motor? If so then it could be a gyro calibration where it thinks it needs to level itself. Spinning faster and faster would come from I gain. Does the problem (motor getting faster and faster) go away if you set all your I gains to 0 for a test? If so, then see if it also goes away if you hold that multicopter arm higher.
