Old Dec 05, 2012, 11:02 PM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Not cool to not give credit.
http://www.headsuprc.com/servlet/the...ushless/Detail
Originally Posted by juanquy View Post
Look at the Voltage (Voltage = 7.2 to 12.6 ), it can handle 3s perfect but not 4S if you are looking for a light weight Batt take a look at ZIPPY Compact series from Hobbyking. Nice performamce not the best but acceptable and lighter.
EMAX CF 2822
Recommended props when using 3 cell Lipo batteries:
The GWS EP9050 produces 30 ounces of thrust at 17 amps. Use with caution
The GWS EP8040 produces about 24 ounces of thrust at 12 amps. Best all around prop for this motor.
The APC 8x4E produces 25 ounces of thrust at 14 amps.
The GWS HD8060 produces 22 ounces of thrust at 17 amps. Use with caution
The GWS EP7035 produces 15 ounces of thrust at 7 amps.
The APC 7x6E produces 19 ounces of thrust at 12 amps.
Recommended props when using 2 cell Lipo batteries:
The GWS EP1170 prop produces about 21 ounces of thrust at 15 amps
The GWS EP1060 prop produces about 18 ounces of thrust at 12 amps.
The GWS EP1047 prop produces about 19 ounces of thrust at 13 amps.
The GWS EP9050 prop produces about 16 ounces of thrust at 10 amps.
The GWS EP8040 prop produces about 12 ounces of thrust at 6.5 amps.
Please be aware that the battery used can make a tremendous amount of difference in the performance of brushless motors. The above data was obtained using batteries in good condition that were fully charged. Thrust and amp draw may be less with the use of batteries rated at lower amp output, and slightly more using batteries rated for higher amp output. Other factors, such as ESC timing and variations in actual motor KV can affect the performance of brushless motors as well. We recommend the use of a Watt Meter to test the current draw of your particular power system, especially if you plan to use a prop that pushes the motor near it's maximum amp rating.
EMAX CF2822 Specifications:
Weight = 1.4 ounces (39 grams)
Diameter = 1.1 inch (28mm)
Length not including shaft = 1.2 inches (30mm)
Shaft Length = 0.62 inches (15mm)
Shaft Diameter = 3mm
Bearing Size = 3mm x 8mm x 4mm
KV = 1300
Current = 16 amp maximum for 60 seconds
Bigster is offline Find More Posts by Bigster
Old Dec 05, 2012, 11:15 PM
Sudsy is offline
Find More Posts by Sudsy
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
Originally Posted by RC_Kid View Post
Hey, everyone.
I have a problem with my KK2.0. I am almost sure it is my fault, though.
I have been flying my FPV quad for a few weeks now. I have had great luck with the KK2.0, except for the arming. I need to leave it on always armed as I can't get it to arm with rudder. I have made sure the rudder channel reads 100% in both directions on the RX test. But it still will not arm. This is on firmware 1.2.
I have just updated to 1.5 to take advantage of autolevel, but there is no more always armed setting. Does anyone have any ideas how to arm the board?
Thank you so much in advance.
Will
What kind of radio do you fly? I fly Spectrum DX7 and had issues in this area.
Sudsy
Sudsy is offline Find More Posts by Sudsy
Old Dec 05, 2012, 11:19 PM
RC_Kid is offline
Find More Posts by RC_Kid
Registered Crasher
United States, NJ, Lincoln Park
Joined Apr 2005
Sudsy
I am using a DX8, but have also had the problem with a DX 18 and Aurora 9. Interesting I have not read about it before.
RC_Kid is offline Find More Posts by RC_Kid
Old Dec 05, 2012, 11:36 PM
Sudsy is offline
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
Ok I just got my tx.
I am looking at one of my quads setup and all of them are set the same for throttle and arm/disarm work fine.
Leave the default on the KK2 for min throttle at 10.
In menu look at "travel adjust".
Select throttle channel.
Set
H 150%
L 100%
trim to minimum.
Let me know if this works for you.
Sudsy
Old Dec 05, 2012, 11:45 PM
RC_Kid is offline
Registered Crasher
Joined Apr 2005
Set
H 150%
L 100%
trim to minimum.
Sudsy
Thank you SO much. Just moving the trim lower, let it arm. I guess it needs to be below the 0% mark on the RX test to arm. I will add some travel to my EPA.
Thank you again!
Old Dec 05, 2012, 11:49 PM
Sudsy is offline
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
Thank you again!
It took me a long time to figure out that I could "safe" the board buy moving the stick full left at idle. That keeps it from jumping up in your face when you bump the throttle when picking it up after a flight.
Check "Failsafe" settings too. It's a terrible thing to watch your new quad sail off into the blue! I set mine to just above hover so in theory it will make a slow decent when the batts start going low!
Sudsy
Old Dec 05, 2012, 11:57 PM
RC_Kid is offline
Registered Crasher
Joined Apr 2005
Sudsy
That is a great idea. I think i will do that.
I just tested the 1.5 firmware outside under the street light on box stock settings. Autolevel is rock solid and almost perfectly trimmed first try.
Old Dec 06, 2012, 12:33 AM
jonesy40001 is offline
Find More Posts by jonesy40001
jonesy40001's Avatar
Australia, QLD, Meadowbrook
Joined Sep 2012
Mwc
Hey Sudsy. Did you get your MWC yet? if so how you going with it?
jonesy40001 is offline Find More Posts by jonesy40001
Old Dec 06, 2012, 12:39 AM
Sudsy is offline
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
Yes I got it. I am on the forum and have downloaded all the required software stuff. It's pretty complex. I am not going to have motors and speed controls until after Christmas but plan to put the board on the frame (after I paint two arms) and get it going.
S
Old Dec 06, 2012, 12:49 AM
Joined Sep 2012
S
Sweet. I have the V1 and yep... its a mission to work it all out but I'm sure you will have fun with it.
Good luck.
Pete.
P.S. Happy to help with what I've learnt if you get stuck.
Old Dec 06, 2012, 01:37 AM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
Third Flight - KK2 Auto Level on for whole flight.
Test with GoPro on top. Winds gusted and battery got low.
Temp: 60F/16C Humidity: 29% Wind Speed: S13/G18 mph Barometer: 30.22 in (1023.3 mb) Dewpoint: 28F (-2C)
Quadnid Multicopter with GoPro (Third Flight) (2 min 35 sec)
harrym is offline Find More Posts by harrym
Old Dec 06, 2012, 05:14 AM
tedrobphoto is offline
Find More Posts by tedrobphoto
Joined Jun 2006
Sudsy
Sudsy, interesting about the failsafe - I set mine as you suggested at just above hover but when I turn off the Tx (DX7) the board goes to Safe and all power shuts off?
Any ideas, Ted
tedrobphoto is offline Find More Posts by tedrobphoto
Old Dec 06, 2012, 05:22 AM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
Sudsy
It's just theory, but In reality you will burn your ESC's or motors when quad crash land on failsafe set in this manner.
You are not first to try this, and not first to fail badly.
There are only two valid failsave options for multirotors and using other methods will get in you trouble:
1. Cut all engines to 0% aka NO PWM-PPM
or
2. GPS-RTH procedure.
shafter is offline Find More Posts by shafter
Old Dec 06, 2012, 05:24 AM
seibernator is offline
Find More Posts by seibernator
***** on a stick
seibernator's Avatar
United Kingdom, England, Solihull
Joined Sep 2011
Any ideas, Ted
Have you tried turning off auto-disarm in the mode settings menu?
seibernator is offline Find More Posts by seibernator
Old Dec 06, 2012, 06:10 AM
Joined Jun 2006
Thanks for the suggestion - I will give it a try
