Old Dec 05, 2012, 06:02 AM
WalneyCol is offline
Find More Posts by WalneyCol
youtube.com/seafax
WalneyCol's Avatar
United Kingdom, Barrow-in-Furness
Joined Feb 2011
Originally Posted by Del-Dredd View Post
I have flashed the two i have in use up to 1.4 with everything connected, no issues.
Thanks, I'll give it a go.
Col.
WalneyCol is offline Find More Posts by WalneyCol
Old Dec 05, 2012, 08:57 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Col.
I have flashed plenty of times with everything still connected ( but unpowered ). I think the issue might be that powering the board powers the Rx and some back current through M1. If your USB port is not up to the task the flash might fail or cause issues, if that is the case remove the wires and try again.
brontide is offline Find More Posts by brontide
Old Dec 05, 2012, 09:32 AM
CO2X is offline
Find More Posts by CO2X
CO2X's Avatar
United States, CA, Hayward
Joined Oct 2010
1.5v
Originally Posted by srepfler View Post
Good result,
previous default 1.0-1.2 for self level ( 40 20) was better for me, 100 is to high.
new default for P and I are lower and suite most flyers, but if you can bum them up you get much more stable flight, they are good start point.
Yaw P 150 from 1.0 is good for me, new 50 makes tail drift.
But for start definitely better values (except self level).
Thanks for sharing this . I tested them all after flashing to 1.5v and they are flying but still need to see and do more tuning to make it better.
CO2X is offline Find More Posts by CO2X
Old Dec 05, 2012, 10:20 AM
geedee is offline
Find More Posts by geedee
Chester, UK
Joined May 2010
New Quad
Hi
I have just completed my first quad using a KK2 LCD controller.
It flies great with Emax 2822 motors and 20a HK Esc's. 8x 4.5 props
Presently using 2200ma 3s lipo's
Can anyone tell me if it is possible to use larger Lipo's (3s) and if so,how large.
geedee is offline Find More Posts by geedee
Old Dec 05, 2012, 11:01 AM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
Originally Posted by geedee View Post
Hi
Try this calculator....
http://www.ecalc.ch/xcoptercalc_e.htm?ecalc
harrym is offline Find More Posts by harrym
Old Dec 05, 2012, 11:04 AM
geedee is offline
Chester, UK
Joined May 2010
Calculator
Just found it on another thread as well.
Old Dec 05, 2012, 11:16 AM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
Originally Posted by harrym View Post
A larger capacity LiPo will add weight so it depends on your machine.
The larger capacity won't hurt anything.
Old Dec 05, 2012, 03:07 PM
nordwest is offline
Find More Posts by nordwest
knows the last digit of Pi...
Joined Sep 2009
I use 3000mAh (20C - good for around 60A) and 4000mAh (40C - used in a speedboat also, good for 160A) for my larger copters...
Check with the calc-tools how many Amperes your machine draws and align your battery to the needs.... (BTW: higher C-Rate = more weight as these cells have more density)
Does this answer your question?
nordwest is offline Find More Posts by nordwest
Old Dec 05, 2012, 03:24 PM
nordwest is offline
Joined Sep 2009
Originally Posted by alumina View Post
thanks northwest, you were the only one that gave me a feedback on my video.
from what you see on the video can you say if the quad is stable or not? or that is something that you only can feel while flying it?
Looks stable as far I can see in your video... But it is more important what do YOU think about - you are flying this baby ;-)
ATM I am more into larger quads - hey behave different compared to sport-quads...
Hangar:
WLToys V929 Miniquad
XAircraft X450Pro (V1) + Compass&GPS
X8-550 Quad(Octo) with Gimbal on AUX-Channel (KK2-Board)
X-550 Hexa (KK2-Board)
X-600 (KK2-Board)
X-650 (DJI Naza+GPS)
.... maybe more to come - Winter is cold in Austria ;-)
Old Dec 05, 2012, 05:00 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Hi
My son's KMAN Kopter used Emax CF2822 motors with 30A ESC and 3S 4000Mah LIPO with no problems. I do not think the emax CF2822 motors can handle 4 cells.
rcjose is offline Find More Posts by rcjose
Old Dec 05, 2012, 07:55 PM
juanquy is offline
Find More Posts by juanquy
United States, KS, Buhler
Joined Feb 2011
Here is some specification about the Emax CF 2822.
Look at the Voltage (Voltage = 7.2 to 12.6 ), it can handle 3s perfect but not 4S if you are looking for a light weight Batt take a look at ZIPPY Compact series from Hobbyking. Nice performamce not the best but acceptable and lighter.
EMAX CF 2822
Recommended props when using 3 cell Lipo batteries:
The GWS EP9050 produces 30 ounces of thrust at 17 amps. Use with caution
The GWS EP8040 produces about 24 ounces of thrust at 12 amps. Best all around prop for this motor.
The APC 8x4E produces 25 ounces of thrust at 14 amps.
The GWS HD8060 produces 22 ounces of thrust at 17 amps. Use with caution
The GWS EP7035 produces 15 ounces of thrust at 7 amps.
The APC 7x6E produces 19 ounces of thrust at 12 amps.
Recommended props when using 2 cell Lipo batteries:
The GWS EP1170 prop produces about 21 ounces of thrust at 15 amps
The GWS EP1060 prop produces about 18 ounces of thrust at 12 amps.
The GWS EP1047 prop produces about 19 ounces of thrust at 13 amps.
The GWS EP9050 prop produces about 16 ounces of thrust at 10 amps.
The GWS EP8040 prop produces about 12 ounces of thrust at 6.5 amps.
Please be aware that the battery used can make a tremendous amount of difference in the performance of brushless motors. The above data was obtained using batteries in good condition that were fully charged. Thrust and amp draw may be less with the use of batteries rated at lower amp output, and slightly more using batteries rated for higher amp output. Other factors, such as ESC timing and variations in actual motor KV can affect the performance of brushless motors as well. We recommend the use of a Watt Meter to test the current draw of your particular power system, especially if you plan to use a prop that pushes the motor near it's maximum amp rating.
EMAX CF2822 Specifications:
Weight = 1.4 ounces (39 grams)
Diameter = 1.1 inch (28mm)
Length not including shaft = 1.2 inches (30mm)
Shaft Length = 0.62 inches (15mm)
Shaft Diameter = 3mm
Bearing Size = 3mm x 8mm x 4mm
KV = 1300
Current = 16 amp maximum for 60 seconds
juanquy is offline Find More Posts by juanquy
Old Dec 05, 2012, 08:47 PM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
Originally Posted by juanquy View Post
Look at the Voltage (Voltage = 7.2 to 12.6 ), ......
Where do you get your prop data?
Can you provide a link please.
Thanks!
Old Dec 05, 2012, 08:48 PM
pprioverde is offline
Find More Posts by pprioverde
M Griffith
Ecuador, Tungurahua
Joined Jun 2012
Originally Posted by brontide View Post
For those with DEAD BOARDS ONLY. Changing fuses is an unsafe operation and if your board is working you should never mess with them.
You have nothing else to lose, you can try a fuse reset. On my Mac the command would be similar to the following, but may be different for your system. I use the terminal and use the avrdude within the KK flashing tool.
Code:
./avrdude -C ./avrdude.conf -c usbasp -p m324pa -U lfuse:w:0xf7:m -U hfuse:w:0xd7:m -U efuse:w:0xfc:m -F
The one below is FOR TESTING ONLY, it switches to the internal chip clock. I needed to use these fuses to revive my board that was locking up. DO NOT FLY WITH THE FUSES BELOW. They are useful for the boards that are no longer responsive, but need to be applied as soon as the programmer is plugged in. After flashing with these I was able to flash and the set the proper fuses and the board has been flying ever since.
Code:
./avrdude -C ./avrdude.conf -c usbasp -p m324pa -U lfuse:w:0xe2:m -U hfuse:w:0xd7:m -U efuse:w:0xfc:m -F
Awesome, saved mine after a corrupt upload. Tip, don't program your KK2 while on the couch with the dog.
pprioverde is offline Find More Posts by pprioverde
Old Dec 05, 2012, 09:53 PM
georgez is offline
Find More Posts by georgez
C'mon Man!
georgez's Avatar
United States, TX, Denton
Joined Jul 2012
Originally Posted by HappySundays View Post
If the motors started to spin during "calibration" then you did it wrong.
If you do calibration correctly the motors will not spin until you finish the process, then repower the board and ESCs.
Got my new ESC and the calibration went smooth. Like you said, it was operator error the first time.
georgez is offline Find More Posts by georgez
Old Dec 05, 2012, 10:02 PM
RC_Kid is offline
Find More Posts by RC_Kid
Registered Crasher
United States, NJ, Lincoln Park
Joined Apr 2005
Hey, everyone.
I have a problem with my KK2.0. I am almost sure it is my fault, though.
I have been flying my FPV quad for a few weeks now. I have had great luck with the KK2.0, except for the arming. I need to leave it on always armed as I can't get it to arm with rudder. I have made sure the rudder channel reads 100% in both directions on the RX test. But it still will not arm. This is on firmware 1.2.
I have just updated to 1.5 to take advantage of autolevel, but there is no more always armed setting. Does anyone have any ideas how to arm the board?
Thank you so much in advance.
Will
RC_Kid is offline Find More Posts by RC_Kid
