Old Dec 03, 2012, 02:42 AM
AlxFly is offline
Find More Posts by AlxFly
Joined Nov 2012
Originally Posted by rcroadtrain View Post
yep.. GLB hex spider... massive self oscillation... V1.4firmware.
almost unflyable with out-of-the-box settings.
$20? if it was a 'issue', then they'd stop sale of them until a fix was worked out.
they did say they were leaving a few products 'on sale' since their sale 'tother day broke their website..
I think the following prompted me to ask the question,
Perhaps you have all all-ready seen it...?
http://scolton.blogspot.com.au/2012/...lementary.html
So.. Could this revelation have anything to do with anything?
For me .. I believe I have a great FC board with unfolding potential.
Its the only type of FC board I have. (leap of faith).
Its also a journey for me, one of synchronicity that I enjoy.
Thank you all for being here to share.
AlxFly is offline Find More Posts by AlxFly
Old Dec 03, 2012, 02:50 AM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
mine could just be adjustment.
my hex on v1.4 flies as badly as my quad did on v1.2..
quad's been updated to 1.4, and a forum member with a lot of experience with these boards dialled it in, now its a gem to fly.
I think a p of 50 is just too high for this airframe.
rcroadtrain is offline Find More Posts by rcroadtrain
Old Dec 03, 2012, 02:52 AM
AlxFly is offline
Joined Nov 2012
This is my first piece of footage on a tricopter./ Go pro
lok it in. Tri, go pro test. Tricopter (2 min 37 sec)
Original kk2 ver 1.1.
Even the tail servo jitter problem of the time didn't seem to worry the platform too much.
My yaw is a solid DD with double bearings.
Peace.
Old Dec 03, 2012, 03:19 AM
Joined Feb 2012
hmm.. that modded firmware looks interesting.
If I cant get a result with 1.4 I might give it a try...on the hex.
the quad works great on 1.4 now.
failing that, I might just push my hand deeper into my pocket and buy a second Naza.... and fit this 2.0 to a f450 clone..
Old Dec 03, 2012, 04:40 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Originally Posted by theothercliff View Post
I suggest that you either have better power (cleaner, correct voltage, adequate current) coming from USB than from your other source (that is why I suggest that you try a different, clean source like linear BEC or nicad attached to M1) or that connecting clean power to the USB connection would make the whole thing work (that is why I suggest you connect USB power to M1 power).
Hi Cliff
Ah yes I see that. I will give that a try However my replacement board works ok on the same quad
But I will test as you suggest
Thanks Jeff
Upup is offline Find More Posts by Upup
Old Dec 03, 2012, 05:29 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
No.
V1.2 with Shane's patch was a huge improvement. Since then 1.4 has superseded that patch by a large margin. This was after the short lived 1.3 patch which has several issues.
Not saying there is not room for improvement, but the change in price has little to do with the complementary filter.
brontide is offline Find More Posts by brontide
Old Dec 03, 2012, 08:43 AM
MoRaLeSD is offline
Find More Posts by MoRaLeSD
^(_MăĻēŜĐ_)^ ЯuĽe U
Greece, Attica, Elefsina
Joined Sep 2010
Hello! Just plugged one on a Tricopter but the servo on tail doesn't move. Do I need to do something different? All motors works fine with KK, and the sticks are fine too in the little screen. Such as Rudder, Servo not moving...Why?
MoRaLeSD is offline Find More Posts by MoRaLeSD
Old Dec 03, 2012, 08:57 AM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Have you got ESC power supplied to board from ESC 2 or 3, the servo needs power on M2 - M8 which are ganged for its supply.
If you only have ESC1 powering board, that is your problem.
It states that on Post 1 FAQ.
It also will not move until you have raised throttle a bit.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Dec 03, 2012, 09:01 AM
MoRaLeSD is offline
^(_MăĻēŜĐ_)^ ЯuĽe U
Joined Sep 2010
Xmmm I must be blind or something cause I really read the FAQ section and couldn't find it, only the Reversing of the Servo I saw. My ESCs have all BECS, would be a problem if 2 of them give power? Sorry for asking something already written. BTW I have seen the New versions of the Kk like 1.4, how Can I know witch one I have and how do I upgrade it? This is said before too?
Old Dec 03, 2012, 09:06 AM
Uwe R. is offline
Find More Posts by Uwe R.
Uwe R.'s Avatar
Germany, NRW, Essen
Joined Sep 2005
Another little quad is born. Of course with the KK2-Board
Due to the rainy, snowy and windy Wheather last Days only a little „hopping“ in the Doorway drive. - - But i think it works well.
If it would be a PC – i think you could call it „Small-Tower“
Greetings from Germany - Uwe
Uwe R. is offline Find More Posts by Uwe R.
Old Dec 03, 2012, 09:07 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
From version 1.2, I think. It prints a version number when you power up the board.
Updates can be done with the kkflashtool.
LazyZero is offline Find More Posts by LazyZero
Old Dec 03, 2012, 09:12 AM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Shane already created/posted his modified firmware a while back so this is nothing new or a revelation.
rcjose is offline Find More Posts by rcjose
MoRaLeSD is offline
^(_MăĻēŜĐ_)^ ЯuĽe U
Joined Sep 2010
Powering up only say the first readings not Version :/. Yes I have seen the menu for KK.2 thanks! 1.5 KK available I see!
Old Dec 03, 2012, 09:15 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Okay, then version 1.0 is installed on your board.
Old Dec 03, 2012, 09:17 AM
MoRaLeSD is offline
^(_MăĻēŜĐ_)^ ЯuĽe U
Joined Sep 2010
Upgrading fast, into that 3rd computer hahaha
