United States, NY, Albany
Joined Sep 2012
.equ GyroLowLimit = 500 ;limits for sensor testing .equ GyroHighLimit = 630 .equ AccLowLimit = 450 .equ AccHighLimit = 850 If you go to sensor test how are your gyro and acc numbers? |
Joined Feb 2011
Joined Sep 2012
Joined Oct 2012
Ok guys, here I post my first video.
this was my 3rd day/session flying the quad or anything else for that matter. I felt the quad very stable but since I lack any experience and can not compare to any other quad I will ask you for your help judging the performance. I read a lot about PI settings and still don't understand them so I'm afraid to touch any settings "don't fix it if it is not broken" the videoi is edited from a 3minute flight (I made it shorter so is not that boring).but the ending is good:} it's an Ifly4 frame plush 12A KK2.0 v1.2 10x4.5 autolevel is off Pitch/roll Pgain 60 Plim 100 Igain 60 Ilim 20 Yaw Pg 70 Pl 20 Ig 55 Il 10 I would really appreciate any feedback I don't know how to embed the videio
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/-i0V7YahjuQ?version=3&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-i0V7YahjuQ?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object> |
Joined Nov 2012
Hi Guy's,
FW 1.5... How's it going for everyone? Any Self level oscillation issue's? I've just built my second Tri with the KK2.0 FW 1.5 Flashed... Now.. My first Tri after upgrade to fw 1.5 flies Awesome just like it always has, with noticeable Self level speed. The new one on the other hand, is experiencing major oscillations in either a moment of descent or a breath of wind.... Strangely, when I re-boot/re-plug.. The situation seems corrected until it happens again and continues to worsen. I will try Tri 1 Board on Tri 2 and visa versa to see what happens. Both have exactly the same settings... Any Ideas? Cheers Fella's |
Joined Nov 2012
What could this mean? Overstocked, Issue, super-seeded, GPS? Omg, my poor little brain....
Temple, GA, USA
Joined Jun 2009
I suggest that you either have better power (cleaner, correct voltage, adequate current) coming from USB than from your other source (that is why I suggest that you try a different, clean source like linear BEC or nicad attached to M1) or that connecting clean power to the USB connection would make the whole thing work (that is why I suggest you connect USB power to M1 power).
almost unflyable with out-of-the-box settings. $20? if it was a 'issue', then they'd stop sale of them until a fix was worked out. they did say they were leaving a few products 'on sale' since their sale 'tother day broke their website.. |
Latest blog entry: Win a frame
Son, Norway
Joined Sep 2004
No movement around the three axis, just jumping up and down. Same problem both with and without self leveling on. Never had this problem earlier. I tried it in my basement later, and it worked OK, so it could be a temperature issue. I noticed some high fq oscillation, but that could be caused by the self leveling settings, which I haven't tuned yet. Fred |
Temple, GA, USA
Joined Jun 2009
I've been seeing more "broken when received" questions lately than I like... HK is protected by an ocean and an international boundary and it their mind it gives them free rein to sell broken items and make you pay more to send it back than it cost in the first place. |
Joined Sep 2009
I personally try to lower the PI values as much as possible with the result that the quad is smooth to fly (but does not have a really fast snap-lock in autolevel mode). It is easier for me to fly in this "smooth mode" - but my quads are 550, 600 and 650 size (air photography). I usually set I value to around half P value and do not touch the limits. I have my P values around 30-40, I values around 15-25. (checked on the 550 X8 copter) - FW 1.5 But again - that is my personal preference. Like to see more vids ;-) |
Joined Nov 2012
I have only been involved with this fc board over the last 6 months. I've ordered 4 in that time, one by one, either with a larger order or alone by the cheapest post available. 2 still packed on the shelf, 1 perfectly amazing, and one in question awaiting some comparisons. There is a record of all orders with HK.... I'm sure suitable communication would rectify DOA's over time. Snail mail, time, time, time. Actually.. I'm new to this game, yet completely addicted. |
