Old Jul 14, 2012, 03:11 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Mind turned up today after to ordering from the first batch thats the longest i have ever waited for a order to come to the UK still glad it got here eventually
Kris... is offline Find More Posts by Kris...
Old Jul 14, 2012, 04:23 AM
NEAGRON is online now
Find More Posts by NEAGRON
United Kingdom, Scotland, Aberdeen
Joined Mar 2010
Kris,how long did you have to wait for your KK2,and very excited that KK is going to rewrite the P&I gain setup,many thank's,Marty.
NEAGRON is online now Find More Posts by NEAGRON
Old Jul 14, 2012, 06:01 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
what does I of PI >> ON/OFF do ??
i noticed this is an option is the menu and can be seen on the start up .. right with the autolevel ON/OFF
QiW is offline Find More Posts by QiW
Old Jul 14, 2012, 06:49 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Originally Posted by kapteinkuk View Post
The hardware is closed.
is a pity.
afraid of copying?
... is probably never expected.
ACC; would probably work better with software MultiWii
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jul 14, 2012, 06:51 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
I assume it allows you to disable the I as it's best to setup the copter with it turned off.
Saves having to set each number to 0 and then go back afterwards to increase.
Sensible option IMO
Mike Barton is offline Find More Posts by Mike Barton
Old Jul 14, 2012, 11:08 AM
rizky_p is offline
Find More Posts by rizky_p
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
@jesolins and @rcjose @fallingdown: Wow a lot of idea learn a few stuff today. Thank you to for all the replies, this place sure has a lot of resourceful people
Will try as you suggested, Much appreciated.
this is my second quad, i think i got bitten by the bug
rizky_p is offline Find More Posts by rizky_p
Old Jul 14, 2012, 11:23 AM
rizky_p is offline
rizky_p's Avatar
Joined Apr 2007
Would like to share mine hovering. It still wobbles slightly with 2x 3S lipo. I guess need some fine tuning for the weekend
Quadcopter Test Flight (2 min 57 sec)
Old Jul 14, 2012, 01:40 PM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
When the board is in standby (before armed) it says autolevel : off.
When I flip my autolevel switch, it still says off. Is this normal? Does it have to be armed first? In receiver check mode, it is displaying positive, then negative values when switch is flipped.
Also my yaw is the only thing giving me issues. With my pgain turned up high, my tail servo wobbles, but I take off very straight and true.
If I decrease the pgain and increase the igain, the servo wobble goes away, and I take off straight and true, but the tricopter has very annoying yawing back to straight (heading hold?).
Any tips. I've got a good mix of the two, but there is still slight right yaw on my takeoff.
current yaw setup
pgain 23
plimit 100
igain 30
ilimit 20
rcbif is offline Find More Posts by rcbif
Old Jul 14, 2012, 02:39 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
See the manual and the Q&A's in the first post.
That is a very low gain for a large quad. What ESCs do you have? Slow responding ESCs make it hard to tune.
I am going to write a new step-by-step text for the PI tuning, hoping to make it easier to understand and do.
Have you tested the fixed wing mode yet? I havent seen anyone who was able to get that working.
epyonxero is offline Find More Posts by epyonxero
Old Jul 14, 2012, 02:51 PM
Wallyfingers is online now
Find More Posts by Wallyfingers
Wallyfingers's Avatar
Grain Valley, MO
Joined Aug 2007
I would like to use my new KK2 controller on a used DJI 450 frame with stock motors and DJI 30 amp ESC's. Do I have to add a BEC or can I just use the ESC by themselves ???
Wallyfingers is online now Find More Posts by Wallyfingers
Old Jul 14, 2012, 03:03 PM
Flying Barry is offline
Find More Posts by Flying Barry
Australia, NSW, Sydney
Joined Jan 2007
Just use the 30 amp ECS you have and see how it goes no need for the BEC. No: 1 motor pins supply power to the board FYI.
Barry
Flying Barry is offline Find More Posts by Flying Barry
Old Jul 14, 2012, 03:19 PM
Grain Valley, MO
Joined Aug 2007
Thanks Barry
Old Jul 14, 2012, 03:30 PM
Joined Jan 2007
Originally Posted by davecrash View Post
It would seem very high is correct. I was under the impression it would some what work out of the box, lol. I moved them a bit but it wasn't till I greatly reduced them i got some control. I also have to have the Self level and I of PI off or it wants to flip over as soon as I apply throttle. Thank you. Now just trying to figure out what the differance between gain, limit, P & I and how does this effect it and how to set them.
Just looking at the picture of your board setup and I have noticed your buzzer is connected around the wrong way. The red wire + goes to the pin that is next to the board mounting hole see below picture if this helps. All you need to do to fix this is to remove the not used end of the connector with side cutters, job done.
Barry
Old Jul 14, 2012, 03:44 PM
bobepine is offline
Find More Posts by bobepine
Team Armattan
bobepine's Avatar
Joined Jun 2011
Barry
If that is accurate (which I believe it is), then it looks like the standoff on top of the board makes it impossible connect this properly with enough room. No wonder he plugged it in the wrong way around.
On mine, I desoldered the wires from the buzzer and I soldered female connectors directly onto the it. Works just fine.
Best,
Chris
bobepine is offline Find More Posts by bobepine
Latest blog entry: Armattan F1 Lineup Revealed
Old Jul 14, 2012, 03:51 PM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Hi,
at third attempt I reached almost satisfactory settings.
You can have a look here :
Wcopter01 - KK2 board (4 min 47 sec)
The quad is a HK wood frame equipped with KK2 stabilization board.
Motors : 28-26A-1200.
ESCs : Superbrain 20A
Propellers 9x4.7
Total weight 1070g.
Take off in manual mode.
From half video autolevel mode.
Gains PI :
roll/pitch P=30, PLimit=25, I=15, ILimit=10
yaw P=80, PLimit=20, I=50, ILimit=10
Autolevel :
P=50, PLimit=50, I=0, ILimit=0
Stick scaling:
Roll=30, Pitch=36, Yaw=50, Throttle=90
Height dampening :
Dampening=0, Limit=30
N.b. : when I tried to insert an I value for autolevel it flipped, I reset it then at zero (?!)
Could I have it better ?
Comments and suggestions are welcome
Ric
chiloschista is offline Find More Posts by chiloschista
