Old Nov 28, 2012, 11:27 AM
helizrnew2me is offline
Find More Posts by helizrnew2me
helizrnew2me's Avatar
United States, PA, Slatington
Joined Sep 2010
well i think i may have fried my kk2 board now .trying to reflash it and the flash goes fine and it finishes but i would just get blank screens .
after doing this several times i tried to flash with lipo hooked up and started to see smoke .
not sure if it was the kk or my receiver .?
the smoke came from the receiver wire section .
the kk still lights up and i can even run the flash tool on it to completion but nothing ever shows up on the screen .
my receiver doesnt power up now either .
guess i fubarred it pretty good .
helizrnew2me is offline Find More Posts by helizrnew2me
Old Nov 28, 2012, 11:50 AM
rceccleston is offline
Find More Posts by rceccleston
Joined Feb 2009
Originally Posted by flarssen View Post
It is, but it has no CPPM output.
If the Orange receivers has CPPM but no stock output pins, what soldering is required to access the stream?
rceccleston is offline Find More Posts by rceccleston
Old Nov 28, 2012, 12:09 PM
nordwest is offline
Find More Posts by nordwest
knows the last digit of Pi...
Joined Sep 2009
Is a AR7000 able to provide CPPM signal? On what pin?
nordwest is offline Find More Posts by nordwest
Old Nov 28, 2012, 12:18 PM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
I didn't say it had CPPM. It was just that three posters used the term CCPM, which in our hobby is something completely different.
flarssen is online now Find More Posts by flarssen
Old Nov 28, 2012, 12:50 PM
Sudsy is offline
Find More Posts by Sudsy
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
The same thing happened to me. I have a board with no display
now too. I am waiting for a new USBasp to arrive from HK. I will try to revive the board but don't hold out too much hope.
My MultiWii Pro should arrive in the same box.
Sudsy
Sudsy is offline Find More Posts by Sudsy
Old Nov 28, 2012, 01:03 PM
snipeworm is offline
Find More Posts by snipeworm
Snipe the Skies!
snipeworm's Avatar
United States, CA, Roseville
Joined Feb 2012
Hey guys, question for you. If I use the KK2 in my airplane will the auto level work on all 3 axis? Obviously there is no need for rudder auto level but I haven't seen anywhere stating that elevator auto level is possible combined with aileron auto level. Thanks!
snipeworm is offline Find More Posts by snipeworm
Old Nov 28, 2012, 01:08 PM
Joined Sep 2010
i have fixed the receiver power .a ground trace burned along the edge of the board .
i soldered a jumper in and now the receiver has power again .
still nothing on the kk screen though .
i have tried the lazy zero tool and the extreme burner with same results .
how many volts should the usb be providing the board?when the lcd was working it looked to be under 3 volts . maybe thats the issue?
theres a surface mount resistor on this programmer that looks to be setting the voltage .
Old Nov 28, 2012, 01:25 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by vivazapata View Post
Hello
Can you tell me if your propellers are those ?
Sorry for the late response, but no I was using these:
http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.hobbyking.com/hobbyking/s...5Pcs_Bag_.html
Cheers,
Kev
Truglodite is offline Find More Posts by Truglodite
Old Nov 28, 2012, 01:42 PM
vivazapata is offline
Find More Posts by vivazapata
France, RA, Roche-la-Molière
Joined Sep 2012
Originally Posted by Truglodite View Post
Thanks a lot
vivazapata is offline Find More Posts by vivazapata
Old Nov 28, 2012, 01:52 PM
Joined Sep 2010
well i am done for today .i think my board is fubar. tried everything . i should have left well enough alone ,but i wanted to try the 1.4 firmware .
Old Nov 28, 2012, 01:57 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
heliz... 3V should be 5V. Try disconnecting everything but the KK2 from the circuit. That way the USB only has to deliver enough current to run the kk2. 1.4 firmware is worth your efforts; night and day difference. Amtel chips are tough... I've hooked them up every backwards way you can imagine and have yet to permanently brick one. Good chance your kk2 is still alive and just needs a proper flashing.
Kev
Old Nov 28, 2012, 02:00 PM
Joined Sep 2010
ok i`ll try again quick .but when i power up and put my finger on the chip i cant hold it there long ,gets pretty hot,enough to burn a finger .
Old Nov 28, 2012, 02:13 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
I would say that confirms it knackered.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Nov 28, 2012, 02:15 PM
Joined Sep 2010
Kev
tried ,didnt work ......but thanks anyway . quad down.....
Old Nov 28, 2012, 02:45 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Thanks a lot
be careful with the GWS, I'm going to have to abandon the HD8040x3's because they become brittle in the cold and have, essentially, been exploding mid-air. Cutting down on my flight time by ending real quick. From now on I would not use anything without fibers of some sort. They will bend but should not become quite so fragile in the cold.
brontide is offline Find More Posts by brontide
