Old Jun 21, 2012, 01:01 AM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
It lists "Singlecopter 1M 4S", does that mean it could be used on say a Trex450?
danger_mouse is offline Find More Posts by danger_mouse
Old Jun 21, 2012, 01:14 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Congratz kapteinkuk this is awesome got mine ordered just in time!
Kris... is offline Find More Posts by Kris...
Old Jun 21, 2012, 01:20 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
My order just moved from the "IN PRINT QUEUE" to "PRINTED" status!
Erknie is offline Find More Posts by Erknie
Old Jun 21, 2012, 01:39 AM
midelic is offline
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
Come on.We have support from Kaptain K himself for this board.It is his baby, it will not let us down.So I have no doubts about it.
Originally Posted by BenHayat View Post
They're going to make a lot of these boards and they will offer discount again. Let's just hope it works right :-)
midelic is offline Find More Posts by midelic
Old Jun 21, 2012, 02:27 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by kapteinkuk View Post
Hi all, I designed this one to be easy to use for the noobs, and still be better than the KK1.
The gadgets-freaks will not pitch a tent over this one, It is the same, tired old AVR-chip. (Sorry TC ) However, it runs on a 20MHz crystal, so output resolution and jitter is better than before.
Some improvements:
-No confusing potmeter directions.
-No gyro reversing needed since the FW is for a fixed HW setup.
-Self-leveling. It uses acc tilt-angle measurement. Later I will try to add a full AHRS algorithm like the big boys use since it is better. (less delay)
-No PC necessary. All adjustments and multicopter type selecting is done with the LCD and buttons.
-The transmitter setup can be checked before first test. (channels and direction)
-low drift gyros.
-graded low-voltage-alarm, adjustable in 0.1V increments.
-motor numbering and propeller direction is visible on the LCD.
-Custom mixer.
It will become open source when the first update is available. But beware, it is still written in Evil Assembly!!
Here is a buddycode, get it for $19:
http://www.hobbyking.com/buddy.asp?c...2-7C1628251969
Thank you godfather of quads!
er9xuser is offline Find More Posts by er9xuser
Old Jun 21, 2012, 02:33 AM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
where do you found buddy code?
titeuf007 is offline Find More Posts by titeuf007
Old Jun 21, 2012, 02:44 AM
Erknie is offline
Joined Nov 2011
Have you read post one in this thread?
Old Jun 21, 2012, 02:56 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Originally Posted by tc3wins View Post
KK , you are the man, the board looks really nice. I did notics though, that one config was missing. the Y4 setup for people that might want to use this on a V-tail quad. either way though it will be great for the new guys.
Y4 will be added. Also you can enter it yourself in the custom mixer. I will post more details on that later.
Originally Posted by HappySundays View Post
I just bought three with the buddy code
OK kapteinkuk, I realise you will open source it eventually but can you release the circuit to save me the effort reversing it? Pretty please?
What about the LCD? Can you point to any datasheets about driving it?
Any help is much appreciated.
I will send you a PM.
Originally Posted by rcbif View Post
This is great! The "stick scaling" will make this great for those without expensive computer radios! Multicopters are getting so easy to get into!
And a ?
What are the flight characteristics with the autolevel? Do you still have control when it is on, or does it take control like an autopilot and level the multi until you turn it off?
Autolevel makes it very docile. But there is settings to adjust it.
Originally Posted by Trulsen View Post
Nice! Ordered two.. Is it possible to write FW on this controller to use as standalone Camera gimbal like the multiwii?
Camera gimbal will come.
Originally Posted by rcjose View Post
Has anyone read the manual that is available online? It's well written!!!!
hehe, it is written by me
Originally Posted by SpeedMaster View Post
How does the low voltage alarm work? I can not see any connections for input V. ? -Nice board by the way!
The Battery voltage input is the unpopulated hole to the left of the yellow component.
Originally Posted by msev View Post
Does the aeroplane mode also include autolevelling? or is that only available for copters?
It is available for planes too, but that combination is not tested. I will do it when I get more KK2's
Originally Posted by simonk View Post
Hi, kapteinkuk! Good to see that it has a 20MHz crystal and an ESC calibration mode! I'd probably want to add CPPM input mode so that we can just buy a simple receiver and only connect the one signal wire. It needs reordering support for some radios, but it's not that difficult otherwise.
Are the lines drawn between the motors not quite perfect in the picture, or is that just bad image scaling?
I will try to add CPPM mode. Round-off error
kapteinkuk is offline Find More Posts by kapteinkuk
Old Jun 21, 2012, 04:35 AM
Joined Jun 2006
yes i did
but i don t understand how does it run???how can i have buddy code?
very great board
an another good choice for all beginners
Old Jun 21, 2012, 05:54 AM
Nerm is offline
Find More Posts by Nerm
Quads Helis Planes Cars
Nerm's Avatar
Canada, ON, Brampton
Joined Aug 2009
yes i did
very great board
Sign in to HK and then click on a buddy code link posted in this thread
Nerm is offline Find More Posts by Nerm
Old Jun 21, 2012, 06:07 AM
Friar Fnord is offline
Find More Posts by Friar Fnord
Climbing the learning curve!
Joined Jan 2011
Ooh that's a good question. Kapteinkuk?
Friar Fnord is offline Find More Posts by Friar Fnord
Old Jun 21, 2012, 06:24 AM
Trulsen is offline
Find More Posts by Trulsen
Joined May 2010
Nice Looking forward to test that!
Trulsen is offline Find More Posts by Trulsen
Old Jun 21, 2012, 06:35 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Nop, this is a singlecopter
Singlecopter (2 min 33 sec)
LazyZero is offline Find More Posts by LazyZero
Old Jun 21, 2012, 06:55 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Why not ?
There are some configurable mixing possible, so maybe the 120S or 90S can be configured with the 1S
Looking forward to get this KK2 ... and looking to see the source code open up
Tchuss
e_lm_70
ps: The new chip in the KK2 has 2 serial port ... are these again unusable like it was with the original KK ? Looking at the HK photos, I even don't see the pin exposed for some custom changes ... at least old KK from HK was able to allow it ...
e_lm_70 is offline Find More Posts by e_lm_70
Old Jun 21, 2012, 06:58 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Haha one of those serial ports could be connected to a gps
msev is offline Find More Posts by msev
