Old Nov 23, 2012, 07:59 PM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
I've been thinking about enhancements to the KK2. I don't know if there is enough room for more code, but a level calibration screen like ApenAero2 has would be a nice feature.
harrym is offline Find More Posts by harrym
Old Nov 23, 2012, 11:25 PM
AlxFly is offline
Find More Posts by AlxFly
Joined Nov 2012
Hey guy's,
Quick Question re FW 1.5..
ESC calibration?. Where did it go on the menu.?
Obsolete, redundant, covered earlier?
Sry, I'm also a noob here and 1.5 has been the first and only flash I've done on the
KK2
Also. Re, Flashing with windows.. I found this
If you have a 64 bit windows version, You may have both a 32 and a 64 bit Internet explorer browser installed.
Download Java with 64 bit IE open or there could be conflicts that stop the flashtool
from opening.
Cheers.
AlxFly is offline Find More Posts by AlxFly
Old Nov 24, 2012, 01:02 AM
jonesy40001 is offline
Find More Posts by jonesy40001
jonesy40001's Avatar
Australia, QLD, Meadowbrook
Joined Sep 2012
From what I read earlier I dont think there is room for a silent fart left in the FW but the level feature from AA2 would be nice. When mounting the FCB I use long M3 screws with a small section of silicon fuel tube under the board so I can adjust the level of the board by squashing the silicon and the level bubble would be a great addition.
jonesy40001 is offline Find More Posts by jonesy40001
Old Nov 24, 2012, 01:51 AM
LegendLength is offline
Find More Posts by LegendLength
Australia, NSW
Joined Sep 2006
Hold down buttons 1 and 4 while you turn the unit on and keep them held throughout the process (with the TX throttle full of course).
LegendLength is offline Find More Posts by LegendLength
Old Nov 24, 2012, 03:21 AM
AlxFly is offline
Joined Nov 2012
Cheers mate.. Still a three handed job then.
Ta
Old Nov 24, 2012, 03:30 AM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
Ta
Actually no.
There is a short time window after you connect the battery like 0.5-1sec to start ESC calibration.
You just need to press the outer buttons before board will boot itself,.
shafter is offline Find More Posts by shafter
Old Nov 24, 2012, 03:34 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Originally Posted by jonesy40001 View Post
Mate. that looks like typical P gain shake but..... first thing you need to do is double check Prop and motor balance. That shaking is also typical of excess vibration. Once you have done that, and the problem persists, set your P gain at about 50 and reduce the P Limit to 80 (most ppl run at 100) and see if it improves. failing that increase your I gain through the roof until the quad becomes "doughy" you probably wont see any "low speed oscilations" more of a " flying down the toilet bowl" feeling, then drop the I Gain slowly until you regain controll, Increase I Limit until the toilet bowl feeling comes back then reduce it to regain controll again. I have no trouble doing that with my quad but that is about the best my tiny brain can explain it to you.
Pete.
Hi Pete thanks for that all the props are balanced ( good thing I purchased 6 sets though going through them like a pig in a apple store) I will recheck I can only feel high frequency vibration along the upvc arms which is slight ( less than my tri using Multiwii ) going to try and use a iphone vibe app to get some measurement I think , @ p50 the quad is unflyable I have to take the p up to 150 + to get it stable as in the video I will try dropping the limit down as I did think the motors may be over compensating ???
Jeff
Upup is offline Find More Posts by Upup
Old Nov 24, 2012, 03:44 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by Upup View Post
Thanks it is a little clearer any chance of a wiring digram
Regards Jeff
No, but there is a link to a tutorial in this post.
No, only six fingers are needed. It was removed from the menu, since it was just instructions.
Fred
flarssen is offline Find More Posts by flarssen
Old Nov 24, 2012, 04:32 AM
Upup is offline
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Fred
Hi Fred Thank you I missed that
Jeff
Old Nov 24, 2012, 06:28 AM
Paps1984 is offline
Find More Posts by Paps1984
Slovenia
Joined Jun 2008
Is there a problem with voltage monitor in 1,4 and 1,5?
I use 4S and i made the monitor to beep at 150. But it starts way sooner. I think at about 160 or so.
Paps1984 is offline Find More Posts by Paps1984
Old Nov 24, 2012, 07:07 AM
flarssen is offline
Son, Norway
Joined Sep 2004
150 would be 3.75V/cell. It's not unusual for the voltage to drop that far under load.
Fred
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
As far as I can tell there is no change at all in the voltage monitor code. Double check your settings and maybe bring a voltmeter with you to see if the reading is accurate.
brontide is offline Find More Posts by brontide
Old Nov 24, 2012, 09:05 AM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
From what I read earlier I dont think there is room for a silent fart left in the FW.......
I don't think all the screens are needed that show how each motor is rotating on the motor layouts. One screen showing all the motors is enough. Maybe this would free up some room for more code.
Old Nov 24, 2012, 09:17 AM
Paps1984 is offline
Slovenia
Joined Jun 2008
Fred
Yes i know that. But i get the constant beep at the higher voltage. Even in steady hovering.
Old Nov 24, 2012, 09:36 AM
rukie is offline
Find More Posts by rukie
rukie's Avatar
Philippines, Central Luzon, Marilao
Joined Jun 2008
Guys how do you set the voltage monitor? Im using 3s lipo should i set it to 150?
rukie is offline Find More Posts by rukie
