Old Nov 22, 2012, 04:49 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Originally Posted by JohnVH View Post
I have never had to power up either of my kk boards to flash them
If the USBasp doesn't have a jumper for transferring Vbus 5V from the USB to the target, or the jumper is missing, the KK2 won't be powered up.
I notice that the HK version of the USBasp doesn't even have a jumper for Vbus power so maybe it is always passing 5V to the KK2.
Anyway, if the KK2 doesn't power up (one way or another) the flashing will fail.
HappySundays is offline Find More Posts by HappySundays
Old Nov 22, 2012, 04:54 PM
kaptain_zero is offline
Find More Posts by kaptain_zero
Lost in Oblivia
kaptain_zero's Avatar
Canada, MB, Winnipeg
Joined Nov 2010
For the record, my USBasp came from HK and it did have the jumper block but no jumper in place... I stole a jumper from an old motherboard (old ide hard disks would have them too) and away things went.
kaptain_zero is offline Find More Posts by kaptain_zero
Old Nov 22, 2012, 05:04 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
Im a noob when it comes to installing this type of software...
I've got usbasp installed, its recognising the programmer dongle..
but Im having trouble installing/running kkflashtool. (win7)
can anyone point me in the right direction please??
rcroadtrain is offline Find More Posts by rcroadtrain
Old Nov 22, 2012, 05:10 PM
blacksto is offline
Find More Posts by blacksto
blacksto's Avatar
Romania, Cluj, Cluj-Napoca
Joined Sep 2010
try running it from the kkMulticopterFlashTool_SERIAL.bat file
choose USBasp, http://www.fischl.de/usbasp/ (usbasp) programmer, port: usb, baud rate use defaults (19200), controller: HobbyKing KK2 (32kB flash), firmware->KK2 ->KK2.0 V1.5 by KapteinKuk and press the green button. hope it helps
blacksto is offline Find More Posts by blacksto
Last edited by blacksto; Nov 22, 2012 at 05:15 PM. Reason: forgot to write the settings
Old Nov 22, 2012, 05:26 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
For correctly flashing boards esc's etc it seems that most failures are a result of a couple of problems that are pc related. Assuming all the drivers etc are installed and functioning ...
Use a good quality usb cord
Connect to a port that will supply adequate power. Many usb ports are current limited and will crap out if put under load, and flash will fail. Usually plugging direct to the ports on the back of a desktop is the best shot. Laptops seem to be a bit of a lottery when it comes to power through usb ports.
As for esc's beeping in flight under load. Its suprising how much, even a small load on the esc's internal bec will heat up a speedy. Much more so on a tricopter if the yaw servo is tapping into that power supply. The beep is most likely the esc on the verge of shutdown. Check the temperature of the esc's and one may be hotter than the others (even without running the motors).
A stuttering esc can often be traced to the esc under load (the one supplying power to the board). OR excessive vibrations, and high gains upsetting the flight board.
Try an external UBec.
Mark
kaz1104 is offline Find More Posts by kaz1104
Old Nov 22, 2012, 05:27 PM
Sudsy is offline
Find More Posts by Sudsy
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
[QUOTE=HappySundays;23336487]You wil get that message if:
1. The KK2 is not powered when you try to program it or
2. You have plugged the 6-pin cable in backwards
I am not sure about this response. I tried "powering" the board with a separate battery pack (flight pack) and I have a board that is in the same shape. If the little jumper plug is on the USBasp adapter it WILL provide the power to the board and the display will light up. If the display lights up the board has power (5 Vdc). If you connect the six pin plug backwards the board will not light up but you will not do any damage. Flashing these boards is a pain in the butt. That's all there is to it. I was convinced my USBasp was bad so I have a replacement on the way.
I am watching this closely!
Sudsy
Sudsy is offline Find More Posts by Sudsy
Old Nov 22, 2012, 05:38 PM
Joined Feb 2012
DONE!!
Knobby1 told me where I was going wrong..
I needed java64 bit..
d/l that, and it all works fine now..
flashed the FC with 1.4, ready for my next crash!!!
Old Nov 22, 2012, 05:44 PM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
Originally Posted by pinguin View Post
You can just forget your claim......
Here's the latest from HK about my missing parts for the X525...
"Sorry for late reply. As your request, I have made a new order#000000000 to send 1x 9323000018 as replacement to you. Please kindly check for updates later."
Maybe you need to really rattle their cage!!!
harrym is offline Find More Posts by harrym
Old Nov 22, 2012, 05:54 PM
Creepy1 is offline
Find More Posts by Creepy1
Mother warned you about me!
Creepy1's Avatar
Canada, ON, Kapuskasing
Joined Mar 2012
I set my dual rate for position 0 at 50% cut, and position 1 at %100 no cut. When position 0 is active the kk board will not arm. Flick it to position 1 and it will arm. Is this normal?
Creepy1 is offline Find More Posts by Creepy1
Old Nov 22, 2012, 05:56 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Yes
AcroFPV is offline Find More Posts by AcroFPV
Old Nov 22, 2012, 06:00 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
KK can only work off the what the Rx is saying. If you cut off at 50% then it will never see the proper down and over to arm.
brontide is offline Find More Posts by brontide
Old Nov 22, 2012, 06:09 PM
Creepy1 is offline
Creepy1's Avatar
Joined Mar 2012
Maybe I should instead of -50% make it +50% as position 1? That way low rate would be my normal mode on pos0 and acro would be my pos1. Would that be better?
Old Nov 22, 2012, 06:15 PM
knobby1 is online now
Find More Posts by knobby1
Australia, NSW, Bradbury
Joined Dec 2007
Would it not be easier for you to use the "stick scaling" on the KK rather than a dual switch setup on your radio? Or am I barking up the wrong tree? As mentioned by Brontide, the KK needs to see close to full rudder travel to arm/disarm.
Cheers,
Smithy.
knobby1 is online now Find More Posts by knobby1
Old Nov 22, 2012, 06:20 PM
Creepy1 is offline
Creepy1's Avatar
Joined Mar 2012
Cheers,
Smithy.
That would work too but it's more of a hassle then a simple flick of a switch.
Can only increase to 25% more so I guess that wouldn't really work. Oh well guess I just need to leave it in pos1 then to arm.
Old Nov 22, 2012, 06:55 PM
jonesy40001 is offline
Find More Posts by jonesy40001
jonesy40001's Avatar
Australia, QLD, Meadowbrook
Joined Sep 2012
Try this vid.
Flashing the KK2: How to update your firmware (4 min 51 sec)
He is using a mac but it is the same process. I use win7 and had no probs getting it to run once I found the right file to run. The file is the KKmulticopterflashtool, its a Windows Command File of 1kb in size. a dos type window will appear... wait a few seconds and a second dos window will pop up, if the second window doesn't pop up close the first dos window and double click the file again.
Best of luck.
Pete.
jonesy40001 is offline Find More Posts by jonesy40001
