Old Jul 12, 2012, 09:30 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Probably also heavily influenced by the frequency of the vibration and the rigidity of the frame, and therefore sympathetic vibrations/flexing that is induced .... etc. May not be a flexing frame as such, but more a specific torsional rigidity that amplifies vibration and or forces already present ..........
I am flying the crappest flexy nylon type frame (not dji), and a board that doesn't like vibration, plus 1800kV motors and badly balanced 6x3, 3 blade propellers .... yet the quad flies great without having to lower the gains.
Seems the vibration is not amplifying, and/ or not at a frequency that is bothering the board.
Anyway ... wandered off topic ....sorry
kaz1104 is offline Find More Posts by kaz1104
Old Jul 12, 2012, 10:47 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Personally I don't care who makes my frames (normally myself).
Banging on about a brand is just annoying.
So can anyone that had 9 minutes to spare tell me what that final video showed the source of the problem with that wayward Quad-X?
Apologies for bone laziness but I'm coding...
HappySundays is offline Find More Posts by HappySundays
Old Jul 13, 2012, 12:14 AM
Percalotor - Quad_Addict is offline
Find More Posts by Percalotor - Quad_Addict
Joined Jun 2012
dji frame works for people with crappy low torque motors. such as dji motors. the frame is garbage and a bust thus why the price is going down to liquidate the inevtory for there new frames. all the people confused are just vitcums
Percalotor - Quad_Addict is offline Find More Posts by Percalotor - Quad_Addict
Reply With Quote  (Disabled)
Old Jul 13, 2012, 12:21 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Why are we still talking about frames?
I would like to know if the KK2 firmware has a LPF in it to dampen motor/prop vibrations, if so what's the cut off frequency?
Erknie is offline Find More Posts by Erknie
Old Jul 13, 2012, 12:49 AM
Joined Jun 2012
cuz it would be a bad choice for kk2 so ye dont buy it lol
Old Jul 13, 2012, 02:13 AM
rizky_p is offline
Find More Posts by rizky_p
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
Lol i am such a newbie that i asked a stupid question didnt mean to start a brand war. Apologize.
Did you try the test with the piece if string in the video on the first post of this thread to work out if it's P or I wobble?
Yeah i did that but it doesnt seems to look like P nor I gain wobbles.
Originally Posted by rolin View Post
Any success?
Have you seen my video? Does it look like your problem with the wobbles?
Yup it is simillar, it does wobbles at slow interval but really annoying. Look a lot different than PI wobble this one is like 3-4 seconds interval wobble. Otherwise a stable platform and i can see it hovers really well.
Later i tried using 2 x 2S 6000mah battery in series for 4S total and the wobble is gone Wow what a stable hover i can almost hands-free i am not sure whether the weight of the battery, the higher voltage, or the higher headspeed that helps, since 2 2S 6000mah also weight a lot for the frame.
I will try 2 x 3S 2200mah in paralel too see if the additional weight that helps.
UPDATE: tried 2 x 3S 2200 Pack in paralel. Wobble is still there although now a minor. I'll post a video soon. I guess the weight does helps.
rizky_p is offline Find More Posts by rizky_p
Old Jul 13, 2012, 03:55 AM
mashi is offline
Find More Posts by mashi
Joined Jul 2012
Reverse one or more motors
Another newbie question: Am I right there is no way to reverse one or more motors direction in software on this thing? I soldered all motor connections and now it looks like I'll have to redo three motors x 2 wires.
mashi is offline Find More Posts by mashi
Old Jul 13, 2012, 04:12 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
no !
FC does not send any direction info, just speed ....
Mike Barton is offline Find More Posts by Mike Barton
Old Jul 13, 2012, 04:19 AM
Trulsen is offline
Find More Posts by Trulsen
Joined May 2010
Originally Posted by Trulsen View Post
Now the only issue I have is that motor not starting correctly. I am flying X6 and than it is motor 3 not working properly. Have to give it som left aileron when taking off than in the air it works like a charm :-) Also tried to reflash that ESC with correct firmware and calibrated throttle once more without any improvements. Was thinking about to try it on another motor just to check if it actually is the board, ESC or motor trouble.
The ESC on this motor went up in smoke. Good it happened on the ground :-)
Trulsen is offline Find More Posts by Trulsen
Old Jul 13, 2012, 04:28 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by blade strike View Post
$45 for a DJI f550 and $34 for a FS450, imho that's not very much! Why would you want a clone at those prices?
I have q450 frame from HK...DJI clone. For 13 is the best price and it is very good frame with PCB. So why would I buy original.
er9xuser is offline Find More Posts by er9xuser
Old Jul 13, 2012, 06:22 AM
mikemijal is offline
Find More Posts by mikemijal
Westland Michigan.
Joined Jan 2012
I received notification. KK2 back in stock.
mikemijal is offline Find More Posts by mikemijal
Old Jul 13, 2012, 06:34 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
R,
Yep. What you have discovered is that changing the weight of a multicopter changes the hover motor/prop RPM which changes that particular multicopter build's vibration frequency and amplitude. Your adding the weight of the Lipos and mounted very tightly to the arms also has a damping effect on the transmitted vibrations. All frames vibrate at different frequencies. If those vibration frequencies are in the resonant ranges of the gyros and particularly the accelerometers,then the data the FCB uses from them can be corrupted by that noise. Some frames and designs use materials that tend to amplify these vibration frequencies and cause higher amplitude harmonics. Multicopter FCBs that have accelerometers are particularly susceptible to the noise these vibrations cause in the the data the FCB uses from the sensors and therefore has to filter the noise to maintain proper level. Gyro only FCBs not so much. Note that the DJI and Sheng Tian modules have the IMUs suspended and weighted to provide the sensors an environment that is somewhat less susceptible to frame vibrations. Therefore those modules are less susceptible to the vibrations some of those plastic type frames tend to modulate. Note that there have been several changes to the plastics in those types of frames since they were introduced and also in the variety of the clone types being sold by various Vendors. YMMV
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jul 13, 2012, 06:53 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Hi folks,
Ordered my KK2.0 first day I saw it on HK sites. Glad that I was quick because in the evening it was just out of stock..
Yesterday I have received it, and with no delay I switch old KK board to new one.
The entire initial setup took less than 5 minutes. So i did it a try. On my frame it flew like on rails out of the box with default PI values.
For autolevel to work properly had to calibrate sensors many times until quad was holding Horizontal position. Acc is showing for me x=616 and y=621 when it level in air, but it not so level on a level surface
Next in the line will come Self Leveling tuning.
Cheers,
schumixmd
schumixmd is offline Find More Posts by schumixmd
Old Jul 13, 2012, 07:41 AM
rizky_p is offline
rizky_p's Avatar
Joined Apr 2007
Thanks for the explanation, i think i understand most of it
Do you have tips on how should i proceed next to dampened the vibration?
Originally Posted by jesolins View Post
R,
Cheers,
Jim
Old Jul 13, 2012, 08:12 AM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Check your ESC's as some have a reverse feature that can be activated via programming. If it has it, you will need either a programming card for the ESC or it can be programmed via your transmitter.
rcjose is offline Find More Posts by rcjose
