From Subaru4wd
"read this: http://oddcopter.com/2012/07/24/sett...-quadcopter-x/ M1 = motor 1. M2 = motor 2. M3 = motor 3. M4 = motor 4. "You can connect up to 8 motors to the KK2 board. Or 4 motors and 2 servo's for gimbal. Or 3 motors and 1 servo for a tricopter. All the data is stored in the KK2 board (as far as motor layout and prop direction). You only need to read the first post of this thread... not all 7000 replies to it" Awesome, this is what i was looking for.... |
United States, TX, Richmond
Joined Aug 2010
4 tilt quad
FPV around 400 years old tree
Seems there are a lot of newbies so I like to share this.
If you haven't balanced your motors yet here is a how to. I don't have a smart phone so I did it using my fingers just touching the motor arm. and moving the tape around. It made a huge difference in the amount of vibration in the airframe. One step further is to install the props and dynamically balance the motor/prop combination. http://www.youtube.com/watch?feature...&v=_yLRGF5_4XU |
Configurable failsafe behaviour wish
Dear KK,
A few weeks ago I was thinking about how cool it would be to have a configurable failsafe behaviour feature in the KK2 firmware so that users can decide if they want to: - set a hold period of x seconds - or set a throttle only hold (or slight increase) period combined with autolevel - or do nothing (default) Failsafe can be detected using a free channel or higher or lower than normal throttle range for example. Failsafe detection can be indicated by a continuous beep. Having that feature can save your multicopter when flying low (especially over water) or around obstacles (tree trunks, poles, etc). Unfortunately, a few days ago, it was just this wish that could have saved my tricopter. I was flying over rocks 100m away when I descended just slightly out of LOS. I had a short failsafe of around half a second (motors shut down), after which I regained control but that was long enough to cause my tricopter to fall completely out of LOS and crash on the rocks below. I hope this is the right place to post KK2 feature wishes. Thanks |
