Old Nov 18, 2012, 06:13 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Originally Posted by WiseDuck View Post
Like I said earlier, these are connectors from my Naza and they come with a tab on one side. This tab hits the LCD, can't hook them up with the signal wire pointed towards the LCD. So I reversed the wires with the tabs on both sides, on the FC and my receiver. Everything works like it should. It just looks a little odd.
You can't just cut the tab off with a sharp knife?
I am just guessing as I don't know what they look like.
Erknie is offline Find More Posts by Erknie
Old Nov 18, 2012, 06:24 PM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
Those are Futaba "J" connectors and you can just cut the tab off.
Remember that the black goes toward the edge of the PCB on the KK2.
harrym is offline Find More Posts by harrym
Old Nov 18, 2012, 06:51 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
cut the tab off... everyone else does!!
rcroadtrain is offline Find More Posts by rcroadtrain
Old Nov 18, 2012, 07:52 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Originally Posted by kaz1104 View Post
I have seen this where the ground wire on the esc burns up. Ground loops have been explained as the cause, where the esc earth is trying to carry large amounts of current to make an earth connection.
I don't understand the concept, but maybe it's a lead on the cause??
Yeah, the more I think about it the LEDs could not be the cause. The most likely candidate is a positive lead somehow rubbed against the alu frame causing it to feedback through the motors to the ESCs.
I was able to swap out the one ESC but in flight it was still trouble, ESC for M1 worked but had been giving me stutters after the incident, I think somehow its half dead; enough to get it spinning most of the time, but whenever I went to give it any throttle it went limp on that motor like it wasn't getting enough juice.
If anyone has insight I would love to hear it, but in the meantime I have already ordered 2 ESCs and 1 motor for parts. ( and a servo, hey, you never know maybe it becomes a tri! )
brontide is offline Find More Posts by brontide
Old Nov 18, 2012, 08:00 PM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
Originally Posted by brontide View Post
Yeah, the more I think about it the LEDs could not be the cause. The most likely candidate is a positive lead somehow rubbed against the alu frame causing it to feedback through the motors to the ESCs....
If you reverse the polarity of the ESC power leads it will burn the ground wire.
I've done this and cut the heat shrink back to expose the wires enough to replace it. I was lucky and it didn't fry the ESC. You might cut the heat shrink off the whole ESC and inspect it for anything that might be burnt.
Old Nov 18, 2012, 08:03 PM
brontide is offline
Joined Sep 2012
The one ESC was fried, the second one appears functional, but starts to misbehave when I apply throttle. Of course it's also a new motor, so I can't be 100% sure of anything here. ( not been a good weekend for me )
The one that is misbehaving had no obviously fried parts, I inspected it several times.
Old Nov 18, 2012, 09:40 PM
asimmetrico is offline
Find More Posts by asimmetrico
Wingbreaker
Italy, Lazio, Albano Laziale
Joined Oct 2008
Originally Posted by asimmetrico View Post
Hello,
yesterday I flashed the 1.4 Tested holding my tricopter over my head, verithing perfect.
Today I went outside and as soon as I connected the battery the alarm started sounding with "no yaw input" message.
Tested the board I found that the YAW input is shorted with the positive (my multimeter reads a 12 ohm resistance between the YAW input and the positive.
I checked all the board looking for something wrong but nothing is wrong. I routed a needle around the solder, just in case but nothing.
What could happen between yesterday evening and today? Any suggestion to gain back the control board?
Al
Another bit of information, when first happened the problem the LCD was blank. Then I reset the board (power off) and the LCD started working again but not the Yaw.
I tried also to follow the pcb but the Yaw input ends under the Atmel. Do you know to what pin it is connected?
Thanks for your help
Al
asimmetrico is offline Find More Posts by asimmetrico
Old Nov 18, 2012, 09:45 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Al
The Yaw (RUD) input goes to pin 42 (PB2) of the chip.
That's the third-last pin going counter-clockwise from pin 1.
HappySundays is offline Find More Posts by HappySundays
Old Nov 18, 2012, 10:02 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Not sure if my kk2 is the issue but I had a 250 size bambucopter that used 1510 motors and 12amp esc's. it was meant to run on 3s but found it ran pretty well on 2s when moving to 3s it would eventually go into a wobble and come down to the ground. Never did this on 2s only 3s.
Now I have a new x250 quad with new motors and esc's. also runs perfectly fine on 2s but when I try 3s it goes up smoothly for a few seconds then all the sudden completely freaks out and just convulses crazy and comes crashing down.
Any thoughts?
jlcamp7 is offline Find More Posts by jlcamp7
Old Nov 18, 2012, 11:48 PM
Joined Feb 2012
I had this 'yaw fault' on my first test flight.
I thought 'oh cr p, I got a bad board..'
but I cycled the power, and it came up good.
Old Nov 19, 2012, 12:04 AM
areon is offline
Find More Posts by areon
Nederland, Zuid-Holland, Westland
Joined Mar 2010
Originally Posted by subaru4wd View Post
Since everyone else is showing off flight video's, here is one from today.
Testing some new camera equipment, and my FPV gear:
http://www.youtube.com/watch?v=-qGCTl0pTmk
OT, but I want to ask anyway : How do you guys do picture in picture and with what software?
areon is offline Find More Posts by areon
Old Nov 19, 2012, 12:11 AM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
I use Sony Vegas for all my video productions. Its what I use to put picture in picture.
AcroFPV is offline Find More Posts by AcroFPV
Old Nov 19, 2012, 01:01 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
How did you connect the LEDs?
Fred
flarssen is online now Find More Posts by flarssen
Old Nov 19, 2012, 01:16 AM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Any thoughts?
Try reducing your gains a little.
kaz1104 is offline Find More Posts by kaz1104
Old Nov 19, 2012, 02:06 AM
Rotorhead0207 is offline
Find More Posts by Rotorhead0207
Joined Dec 2007
Any thoughts?
possible vibration with the motors running at a higher rpm that doesn't show up at a lower speed with a 2S pack.
Rotorhead0207 is offline Find More Posts by Rotorhead0207
