Old Nov 15, 2012, 04:12 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Originally Posted by COCO2010 View Post
...check this out.
http://youtu.be/I8RN8wMnQpg
Thanks man !!
kaz1104 is offline Find More Posts by kaz1104
Old Nov 15, 2012, 04:17 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Edit
flohio117 is offline Find More Posts by flohio117
Old Nov 15, 2012, 04:18 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
Best - lego - ever!!!!
rcroadtrain is offline Find More Posts by rcroadtrain
Old Nov 15, 2012, 04:44 PM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Since everyone else is showing off flight video's, here is one from today.
Testing some new camera equipment, and my FPV gear:
The HellaCopter - Camera Test #1 (1 min 32 sec)
AcroFPV is online now Find More Posts by AcroFPV
Old Nov 15, 2012, 04:59 PM
Nightstone is offline
Find More Posts by Nightstone
20 years on the Internet
Nightstone's Avatar
Joined May 2012
Need Some Help
Brand new KK2 board. Worked for one day through the setup. Never actually put props on. Turned it on last night to do a last check and i'm getting the following error.
Errors. No yaw input.
Menu will not work and flash utility will not recognize it ( Tried to reflash ).
I have switched out esc's, Batteries, receivers etc. Quadruple checked all connections.
I'm hosed right? I had reservations from the beginning on the cheap HK equipment. If this had screwed up in flight I would have been out some $$.
Any better quality alternatives that don't have to be sent to china for returns? or is this where its at till things go a bit more main stream.
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Nov 15, 2012, 05:00 PM
jonesy40001 is offline
Find More Posts by jonesy40001
jonesy40001's Avatar
Australia, QLD, Meadowbrook
Joined Sep 2012
[QUOTE=JohnVH;23271867]Tonights flight, anyone know how to stop it from being so wobbly coming down? Its worse than the KK2.1 board that was in there.. Any other setup tips greatly appreciated.QUOTE]
Hey John.
I know its a couple of days old but I just watched your vid. As mentioned earlyer it is very common for all multi rotors to wobble on the way down, it drove me crazy trying to stop mine from doing it. I'm still learning to fly and I've done a lot of reading about PID loop controll and yours appears to be well tuned. I notined on the first descent there was considerable wind noise indicating a little speed. Movement in any direction (forward, sideways etc) equal to or greater than the rate of descent will stop the wobble i.e. a glide ratio of more than 1:1. I have my quad tuned deliberatly to have a slight ossilation during descent and when in the ground effect layer. This gives me a quad that is very stable in normal flight. If you want to play with you gains, leave the P gain high and increase the I gain until your airframe snaps to attention. when you tilt from hover and return the stick to center the air frame should stop and hold that positoin very quickly not gently come to rest at the new set point. If there is a slight over shoot reduce the I gain by 1 or 2 points at a time. there is a Wiki Doc on PID Loop controll, it is long and for the most very heady, I read through it 4 times but it is well worht it, for me , it removed a lot of the questions you see on this thread day after day.
Now, I go looking for physical solutions before even thinking about tuning my FC to fix a problem and so far its been things like vibration, booms out of alignment or loose screws. Hope you get it sorted.
Pete.
jonesy40001 is offline Find More Posts by jonesy40001
Old Nov 15, 2012, 05:01 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
If you plug one ESC into the throttle channel you get a responce?
You have tried replacing the servo cables from the receiver to the KK?
brontide is offline Find More Posts by brontide
Old Nov 15, 2012, 05:10 PM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
...this thread.
I only see 70 pages in this thread!!!
Update...
I found it on page 68 of this thread.
Page numbers are relative to how many you display.
harrym is offline Find More Posts by harrym
Old Nov 15, 2012, 05:11 PM
Joined Sep 2012
Originally Posted by jonesy40001 View Post
total saving... 5 bucks and it will be at my door before the weekend.
As expected. Just got a knock at the door and guess wot??? The postie with my new KK2, 4 days after ordering from my local HK warehouse. gotta love that.
Old Nov 15, 2012, 05:16 PM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
Originally Posted by Greebo View Post
Seriously?
You didn't think to even TRY looking in this thread?
Yah I seriously looked at this thread I wasn't born yesterday!
Old Nov 15, 2012, 05:21 PM
brontide is offline
Joined Sep 2012
If you change the default posts per page don't get upset when people give you page number that don't line up; they did also give you the post numbers.
Old Nov 15, 2012, 05:25 PM
RC911 is offline
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsų
Joined Aug 2012
@subaru4wd: Nice V-tail you've got there. What (on-board) camera did you use in this video?
RC911 is offline Find More Posts by RC911
Old Nov 15, 2012, 05:34 PM
Nightstone's Avatar
Joined May 2012
If you plug only one esc into M1 position the result is the same. Even with only one connection on M1 ( No Receiver ) its the same. LCD lights up and you get the no yaw error.
Replaced everything cable wise. Same result. Even tried that long reset sequence.
Nightstone
Old Nov 15, 2012, 05:47 PM
Fidy$Trainer is offline
Find More Posts by Fidy$Trainer
USA, GA, Atlanta
Joined Sep 2008
Nightstone
I think I had this problem too. Make sure your reciver is bound to your radio and MAKE SURE your RADIO is turned ON when you plug in your battery. Let me know if that fixes it.
Fidy$Trainer is offline Find More Posts by Fidy$Trainer
Old Nov 15, 2012, 06:00 PM
Nightstone's Avatar
Joined May 2012
Yep... Tried that too. Connects fine. Arms fine. Yaw error remains and the menu buttons do not work. Cannot access menu or flash.
Nightstone
