Joined Nov 2012
I do this first time. There was no menu for ESC calibration on older version. I have programing card for ESC if this is OK?.
But there is no motors response if i dont make calibration of ESC? Thanks. p.s or i dont need this menu i just made likeon videos? |
Not for calibrating the ESC's. Refer to your ESC owners manual, read the section on "throttle range calibration" |
Where is everyone finding screws that will fit the KK2 PCB mount holes?
A 6-32 screw is 3.2mm dia. which is just a little too big and no one in my part of the world has anything smaller. A 4-40 screw would be perfect. I might have to open up the holes in the KK, but I'll have to be very cautious because there are very tiny traces really close to a couple of the holes. My power distribution PCB also has the same size holes as the KK so I'll have to open them up too. |
Joined May 2012
Auto Leveling with KK2 board mounted upside down
Hello KK and all. I have the board mounted upside down on my tricopter. I did the sensors calibration with it being upside down. When I hit the auto level switch it still wants to level the tricopter upside down. How/can the board be programmed to autolevel corectly the way it is mounted? Or does it only work when is oriented with the screen facing up? I would really like to have the auto leveling working as well. Thanks!
I've been flying stock firmware waiting for my programming board to come in. Updated to 1.4 (skipping 1.5, I think it's just camera gimbal support) and then got it somewhat tuned. The winds were really strong 30mph at times and I was able to fly with little effort! It did get sucked up to about 100ft and then west about 75yards. Got it back to me and landed it rough, but I didn't freak out and throw it away. It was my 5th time to take it flying and is my first RC aircraft, so that should tell you how good this update is.
United Kingdom, Scotland, Midlothian
Joined Oct 2008
Hi, I'm hoping I can get some clarification on the use of my H.K. Turnigy Usb Linker, to use to flash Turnigy Plush (6A & 30A)and AE -25A esc's, fitted with the Silabs C8051/F33x chip instead of the Atmel chip.
I have got confused/overloaded by information , limited in detail, on the pdf in the files section of the H.K. website and the many multi-page threads on esc flashing/firmwares.![]() Specifically, the pdf fails to explain which 3-pin cable attaches to the Linker; ( I had initially assumed it was just the esc's rx (servo type) cable and that the Silabs esc's could detect when a firmware flash was being sent instead of the normal PWM throttle pulses making it an easy task to perform)! I guess that is not the case, and now think that the Linker has to be connected to 3 of the 4 pads on the esc via a seperate servo lead from the linker soldered or clamped onto the relevant pads. Diagrams I've seen show the relevant pads circled in black,red and white and would hope that they correspond to black(-), red(+) and orange(pulse) marked on the 3 pin o/p of the Linker. Or is my original assumption correct (as the Linker markings might imply)? Also, just to confuse me further, the PDF instructions say to download firmware from github/sim/tgy, but all of those are firmware of Simon Kirby's for Atmel chipped esc's!!! And I can't find the appropriate Silabs ones there at all(the ones in green for Silabs escs on the Rapidesc database by Tom Snow. I've found some BL-heli firmware by Steven Skaug but only for the 6A esc & not too sure if it will work with the linker and if it's mainly for Helis rather than Multis that I want it for. HELP Please
