Well! about the self levelling being on all the time... it would be good for someone leaning to fly..but i can't imagine once you get the hang of it, your are going to want and actually fly the thing. In SL mode everything is null'd down. I think stock it 30P and 30I you have a bit of control with those settings . but the less you have the less control you have. As i said in my last post i like 20 20. No no need to flash with anything other then the firmwares that KK has put forth to us. Im still using 1.2 ![]() If you want a acro just bump your Stick scaling up to 90 pitch and 90 roll I would highly recommend adding at least 40% expo cause its very sensitive... Here is what i did. While In H/R's on my TX, i set my stick scaling to 90 and 90 with 100% epa's and 40% expo on my radio. Then i went in and toned down my AIL and ELEV L/R's to 50% and re set my expo to 10%(normal expo i like) I assigned both to my Ail D/R's switch so i enable both with one flip. No i can fly around in normal flight mode on L/R's then go into arco with a flip of the switch... always remember to flip the switch before attempting a flip/roll. ![]() I caught my self while i was inverted and still in L/R's...at 15ft i managed to flip in to acro saving my newly built quad |
Joined Jul 2012
Canada, ON, Midland
Joined Jan 2012
im wondering its just something as simple as the the board needs to adjust to the lower temp, and be recalibrated at that lower temp to fly ok... components expand and contract with variations in temp.. im going to try it out... going to leave my quad outside for aprox 20 mins, power it on.. check for errors. recalibrate the senors if there is an error and see if clears the issue or not...
My tri has 3 identical props (it's a cheap option!) |
United States, CA, Rocklin
Joined Aug 2012
But I agree... only person who deserves any of our donations is Mr.KK himself, Rolf Bakke! I would hope the donation link used, links to his paypal. |
