Old Nov 09, 2012, 01:03 AM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by jabbey71 View Post
Just wondering if anyone could tell me what the latest update out is for the kk2 with lcd screen, and also if any tutorials are available for it for newbies to the quads.
Hey the latest is 1.5 but 1.2 is what comes on the board and is great as is.
have a look on page 1 fro some great info.
Here a link to 1.5 as KK has not edited his first post to include it yet!
http://www.rcgroups.com/forums/showp...postcount=6371
Cheers
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Nov 09, 2012, 01:06 AM
GSD is offline
GSD
Find More Posts by GSD
GSD
Productions
GSD's Avatar
Greece
Joined Oct 2012
kapteinkuk, you are surprising us almost every day!!!... But i can still see people, to ask this, to ask the other... etc!!..
Ok guys... cann't you see it? KK is active and warm!... Just THANK him!!!.. I believe that he will reach this board at the END of hardware limits and maybe more! I am no more than 3 weeks on this section (multicopters & KK2) and i am amazingly surprised because i made the BEST decision/buy to start.. the KK2!!!
BIG THANKS to KK! (and all others who contribute like Colton!)
GSD is offline Find More Posts by GSD
Old Nov 09, 2012, 03:20 AM
jabbey71 is offline
Find More Posts by jabbey71
United States, NC, Greensboro
Joined Mar 2011
kk2 updates
Cheers
Thanks for the info, I believe when I receive my board, i'll fly with it a little while and get adjusted to it before I go attemping to update. Which I would probably be satisfied with the 1.2 version. thanks
jabbey71 is offline Find More Posts by jabbey71
Old Nov 09, 2012, 04:46 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Update board as soon as possible.
er9xuser is offline Find More Posts by er9xuser
Old Nov 09, 2012, 04:47 AM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
Ive been flying with 1.2 on a 450 quad and love it, and am now setting up a hex with 1.4, on initial test it wants to spin on the yaw axis as if the gyro is reversed. The receiver test directions show all ok, so I was wondering if there's a way to reverse a gyro direction?
Haych is offline Find More Posts by Haych
Old Nov 09, 2012, 05:48 AM
nordwest is offline
Find More Posts by nordwest
knows the last digit of Pi...
Joined Sep 2009
Well spoken/written GSD - totally agree.
I wonder what ppl sometimes seem to expect - functionality of a 1000+ USD FC at the price of a few bucks? ;-)
Big thanks KK, love your boards (and the great support of the ppl here in this thread)
nordwest is offline Find More Posts by nordwest
Old Nov 09, 2012, 06:22 AM
pabmadi is offline
Find More Posts by pabmadi
pabmadi's Avatar
Joined Feb 2009
Originally Posted by Rotorhead0207 View Post
if you play with the height damping gains you can accomplish the same as a mix to throttle.
#9
Q: Could you explain in detail how does the Height Dampening and Limit works?
A: "Height Dampening" in "Misc. settings" uses the Z accelerometer to dampen vertical movements caused by wind or tilting the craft. "Height D. Limit" Limits how much power available for dampening. Try 30 for the "Height Dampening" and 10 (10%) for "Height D. Limit".
So, "Height Dampening" only works with AutoLevel ON ?
pabmadi is offline Find More Posts by pabmadi
Old Nov 09, 2012, 06:28 AM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Would have thought prop rotation wrong if on a Quad but Hex not sure.
Gyro reversed same as on Tricopter.
Go into Mix Editor and on Channel 4 Yaw change rate to -100 from +100 or visa versa.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Nov 09, 2012, 07:41 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
No, it operates independently of self-level. It's a very basic function that takes the change in heigh as measured by change in gravity's force on the craft ( Z axis of the accelerometer ) and uses that to modulate the throttle.
EDIT: The description is also not 100% accurate. The limit is not a % value, but just a travel limit, just like the PI limits. Easiest to give an example, If AccZ = -5 and H Dampening = 30 then it would add 150 to Throttle ( neg(AccZ)*HDamp ), but you probably have a limit of 30, so it only adds 30. So HDamp is the "strength" of the modulation and HDamp limit is the "window/range" where it's most effective. This effectively fights your throttle control of the craft as well, so don't think you can just crank it up and have no side effects.
brontide is offline Find More Posts by brontide
Old Nov 09, 2012, 10:11 AM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
If your motors spin the wrong direction you will have this problem. Reverse direction of all your motors and try again.
Do not perform the Gyro Reversal as if it were a tri... it will not work the same
AcroFPV is offline Find More Posts by AcroFPV
Old Nov 09, 2012, 11:01 AM
ssoap is offline
Find More Posts by ssoap
ssoap's Avatar
Joined Apr 2008
Originally Posted by partzee View Post
I finally got it to work.I don't understand why, but I had to install java 64 bit but go back to IE9 32 bit browser on a win 7 64 bit OS to get it to work.
Many thanks to all who helped me.I was just before throwing in the towel.
partzee
I sure wish I could get it to work. Do you mean your board came back to life. I still have no display but the back light works. I got another KK2 in the mail yesterday and I think I will put it on the Talon V2 that I killed and fly with 1.2 until I can get the dead board either flashed or return it for credit.
Sudsy
ssoap is offline Find More Posts by ssoap
Old Nov 09, 2012, 11:20 AM
Gavinxman is offline
Find More Posts by Gavinxman
Gavinxman's Avatar
Joined Aug 2011
How do I program auto level with my dx8 ? I have the 5th servo wire to a aux ch but what set it up to work , not that's it's that great with the 1.2 but I've heard it's better with the new firmware . Thanks and it's great fc . Waiting on a new 475 for my cc3d but I still need to get this set up 1st . It's already been flown before it was sent to me but I wasted 10hrs messing with a POS 9x now I have a NEW DX8 should be the real deal now lol thanks
Gavinxman is offline Find More Posts by Gavinxman
Old Nov 09, 2012, 11:25 AM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Make sure in the the menus that AL is set to AUX and not "stick".. then in your radio Aux is flaps, so make sure your EPA's are not messed up...pull your flap switch and it should go into auto level
Old Nov 09, 2012, 11:29 AM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
If your DX8 has a gear switch, use that channel instead on the receiver That way you just hit the gear switch on the tx. No mixing involved.
You also have to set the self level in the misc setting menu to use AUX instead of stick. The AUX setting is just a reference for the firmware. It will work on any channel connected to the pin header #5 on the KK2 board.
rcjose is offline Find More Posts by rcjose
Old Nov 09, 2012, 11:31 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
sounds to me like the problem wasnt the "pos 9x" but maybe a problem with the operator.
