May try it out, 1.2 is treating me well though May i suggest posting your 1.3 info in the first post! Its only been a few hours and your post well get lost in the woodworks very fast...
Joined Nov 2012
Hi there!
Tried the KK2.0 today on a quadcopter but i have a problem. 1. test: worked perfect, installing receiver and values 2. test one day later: LCD Display illuminated but no information on it, motors just making noises an little jumps, not chance to arm board. nothing i can influence... Can someone help me? Any idea why this happend? Which part of quacopter can be damaged and why? is there a kown solution? Thanks you very much!! |
I assume you motors and props are orientated and spinning the correct way? Also you said you were in autolevel, did you try with out al on? How about when you calibrated the sensors? Was the board as level as possible? Just trying to think of all the possitbitys? |
"During prolonged looping, flipping and high angle sport flying the KK2 may lose its bearing of the up and down direction and not keep level when self-level is turned on, especially if the KK2 experiences a temperature change since the last arming. Land and re-arm to fix this, no need to disarm first."
i wish i would have reat that.....i need some band-aids No disrespect to the kaptin but for my type of flying i am sticking with the Shane setup. I only use the self level for video and pictures and as long as you don’t do drastic maneuvers with self level on its fine. you can do a bunch of loops and rolls hit the switch and drink a coke flip it of and roll and loop. cant do that with 1.3 let me know if i am wrong for my type of flying. |
Norway, Nordland, Saltdal
Joined May 2012
read mr kapteins post again. turn of self level and you can do everything you want! Rolf, takk for ny oppdatering, dette skal testes
NW, US
Joined Mar 2007
I agree reading KK's info that doing some acro type flying it would be a possitblity of locking up!! Yes i re read his post 2x...So fjante could you elaburate on your post? Anyways 1.2 is working great for me. Stick scaling at 90 with 40% expo is very managable for someone who can flying the quad in noraml patterns. Then i knocked the rates down 50% with like 10% expo on the L/R's which i like for more slower "normal flight if im looking to get some shots" Ps the KK 2.0 on th back plate pf the Q450 is wotking flawlessly. kinda protects it as well http://www.rcgroups.com/forums/showthread.php?t=1759760 enjoy the testing boys ![]() ![]() hall i was wondering the other day what the "Max" scaling guys have used. Seeing theres not alot of guys here putting theres though the pace's What has the max you have bumped it up to? I was thinking 120 next time out... I found 90 wasn't fast enough while trying to do a roll/flip while in FFF. She whould kinda loose momentum. Soi was thinking 120 of either dumb down my expo to 30% Thoughts? |
