http://en.wikipedia.org/wiki/PID_controller
If you really need to know how they work, try the link.....happy reading |
The Netherlands, ZH, Rotterdam
Joined Mar 2007
Here a flight video of my KK2.0 with HK DJI PCB frame i hope you like it
I also don't see it mentioned here too often and I didn't realize I could ""SAFE" the KK2 (and the KK v3) by simply moving the rudder full left at idle. I have had a quad with all the props on go full throttle after I decided to see what would happen if I turned the transmitter off. I was of course holding the quad over my head. It takes a few seconds for the throttle to go back to idle after you turn the transmitter back on. I suggest everyone try this on their models. I can't imagine watching my quad disappear into the sky on a failure. Or have it jump up in your face after landing because you bumped the throttle while walking with your transmitter on a strap. Sudsy |
Latest blog entry: Win a frame
Australia, VIC, Melbourne
Joined Mar 2010
Im fairly new to the KK2, but I have flashed it and it flies OK, I am trying to tune it now and notice that when hovering say 4-5 feet high, it sometimes surges and thus climbs, it seems to not sit at the same level for long. Drift seems not so much an issue as the surging...
Is this settings, or vibrations (either in props or FC) or something else maybe? Currently I have "P"75/100 "I"40/40 Height damp 10/10 no auto level not used (on aux- switched off) Flying a SM450 quad |
These setting you have now ,are they what you came to after tuning your P and I gain in the proper manner?
It could be just your movements of your Thr stick? Trying tuning like posted in the First page and check out the tuning video. In a Nut shell Turn your Hight damp and limit to 0 for tuning... Turn your I gain to 0 Bring your P gain up 5-10 points at a time until your see the fast oscillation. Once you do, back it off until it smooths out. Then start bringing your I gain up.Seeing you are at 0 start at 50%of what your P gain is. Then same as before start up'in ituntil you see the oscillation. But this time it is a slower, more like a wobble lol So once there, back it off as you did with the P gain. Then you can set your Height damp and Limit back to how you like. That should workout the prob you are seeing ,unless it is your Throttle movements. Video may help ;0) |
