Old Oct 24, 2012, 07:14 AM
trinco is offline
Find More Posts by trinco
☢ ɴᴏᴏʙ ☢
trinco's Avatar
Malaysia
Joined Mar 2012
some 0.5-1.0mm shims/spacers under your motors will do the trick
trinco is offline Find More Posts by trinco
Old Oct 24, 2012, 09:29 AM
CO2X is offline
Find More Posts by CO2X
CO2X's Avatar
United States, CA, Hayward
Joined Oct 2010
Tri servo
Originally Posted by magic_marty View Post
this might be a crazy question but where do i plug in the servo on the yaw on the tail? trying to get this set up and it has me a bit confused...i did get all my esc's flashed with simonk firmware..just trying to finish things up and tiddy up wires ect...haven't got around to setting up the board or mounting it...kind of trying to find the best way to mount the board with what i have on hand...i think i am going to use the square sponge packing the board came in tho...
On my Tri the tail/yaw servo is plug-in into M4 and the connection for the rx going to the kk board is as normal .
CO2X is offline Find More Posts by CO2X
Old Oct 24, 2012, 10:05 AM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
Vtail
Originally Posted by RC911 View Post
Flies great!
Thanks ! I don't know what's next....I'm getting bored of it...thinking to build a HEX....
Old Oct 24, 2012, 10:10 AM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
Tri
Originally Posted by Banjo5 View Post
FWIW, my tri flew without auto-level. In fact I never set to to get it calibrated (when I rebuild the frame to get flying again I'll give it a shot). I got as far as switching it on when I was flying and the tri headed out left and forward so I switched it off.
I was got into trouble with it when I inadvertently turned it on. Had insufficient control to get the tri home (it was windy though). I think the stock AL settings are quite tame.
I was using all stock 1.2 FW tri settings. http://www.rcgroups.com/forums/showp...postcount=5455
You'll nail it. I found it easier to take off when I just gave a good shot of throttle to "spring" into the air. I did find when I was being "tentative" that the tail (usually) would sometimes seem to lift first. Getting into the air quickly seemed to let the KK board start doing it's stuff and levelling things. In the not quite airborne mode, it does an adjustment, which doesn't change things because of the ground contact, so it does more (I think).
You'll get there!
This video doesn't show taking off, but it was where I was at.
cheers,
Andrew
http://youtu.be/SK92fhFo3QM
PS. Meant to add, your skids should change the CG, although there are two up front, they are closer to the CG so it all should pretty much balance out.
Nice flying Andrew....lucky to have your wife to do the video !
Old Oct 24, 2012, 11:50 AM
Skewp is offline
Find More Posts by Skewp
In progress...
Skewp's Avatar
Estonia, Tartu County, Tartu
Joined Jul 2012
I am still having problems with KK2 Yaw control. I'm using it on an octocopter. I've flashed KK2 with V1.2 and using the "+" mode. Somehow the copter has problems with yaw. Yaw left is perfect but yaw right has almost no movement. Settings are stock. There was no problem with yaw control on the stock firmware with the same copter. What could be the reason of this problem?
Skewp is offline Find More Posts by Skewp
Old Oct 24, 2012, 12:03 PM
teccer1234 is offline
Find More Posts by teccer1234
safer on the ground
teccer1234's Avatar
wilts, United Kingdom
Joined Jul 2006
I've just flown my new tri with the KK2,1.2v board it flew great all except for the fact it wanted to yaw right, I had to keep my finger with slight pressure on the stick to stop it turning right, I managed to trim in flight to set it up central from then on it flew perfect, but then when I went to disarm the board it wouldn't until I reset the trim, what now?
TIA
ray
teccer1234 is offline Find More Posts by teccer1234
Old Oct 24, 2012, 12:04 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
TIA
ray
Make sure your servo is centered properly.
Also increase the Yaw P Limit.
AcroFPV is offline Find More Posts by AcroFPV
Old Oct 24, 2012, 01:04 PM
safer on the ground
teccer1234's Avatar
Joined Jul 2006
thanks for that, I'll sort it out tomorrow
ray
Old Oct 24, 2012, 01:20 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Do you have the correct configuration loaded, i.e. quad vs hex?
Is auto level turned on? On my quad I lose control while in autolevel.
rcjose is offline Find More Posts by rcjose
Old Oct 24, 2012, 02:30 PM
jonesy40001 is offline
Find More Posts by jonesy40001
jonesy40001's Avatar
Australia, QLD, Meadowbrook
Joined Sep 2012
TIA
ray
Sub Trim
jonesy40001 is offline Find More Posts by jonesy40001
Old Oct 24, 2012, 02:38 PM
Skewp is offline
In progress...
Skewp's Avatar
Joined Jul 2012
I have Octocopter "+" configuration loaded. No, autolevel is off.
Old Oct 24, 2012, 02:56 PM
RC911 is offline
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsų
Joined Aug 2012
Originally Posted by jonesy40001 View Post
Hey Fella's.
While were on the subject of the mix edditor. what do the settings do exactly? I dont want to touch mine incase it all turns to poo. My quad has a couple of interesting querks I would love to sort out but PI and AL settings are not going to fix them. Also, KK or anybody else who knows the subject. Is it possible to write "D" gain/controll into the FW or is this a hard ware Thing?
The numbers listed in the mixer editor tells how much influence your input signals (throttle, aileron/roll, elevator/pitch and rudder/yaw) will have on the selected output channel. Direction can be reversed by making a positive number negative and a negative number positive. I am no expert on this so maybe someone else can explain it better, but I have used the mixer editor a few times to make my T-shaped copters fly properly. Default VTail and Y6 mixer values did not work for me.
RC911 is offline Find More Posts by RC911
Old Oct 24, 2012, 03:16 PM
Sudsy is offline
Find More Posts by Sudsy
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
Sub Trim
I had that problem after I increased the YAW Stick Scaling. I had to take the Scaling back to the original setting and solved the YAW with a check and adjustment of the motors to level and I also increased my Rudder travel on my transmitter.
Sudsy
Sudsy is offline Find More Posts by Sudsy
Old Oct 24, 2012, 04:06 PM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
Auto level ON
KK2.0 ....ANOTHER PROBLEM
This problem is happening on my Tri right now.
Usually ,when I want to turn on the self level,I 'll moved the cyclic stick all the way to the right then arm the kk2 by moving the rudder stick to the right and and the other way to turn self level off...or unplug lipo and self level turns off.
Now, WITHOUT moving the cyclic stick all the way to the right and I just want to arm the kk board,the self level will turn on by itself at same time without giving it a command to turn on and if I will turn it off by stick command it won't turn off ,unless I unplug the lipo....this is a problem for me due to I don't fly with auto level on.
ANYBODY KNOWS WHY THIS IS HAPPENING...NEED SOME HELP !!!Thanks
Note: On the RECIEVER TEST,Is the AUXILLIARY supposed to be On ? On my Y6 , Vtail and Miniquad it's on OFF ? How do I turn it off ?
Old Oct 24, 2012, 04:40 PM
RC911 is offline
8 bit is more fun
RC911's Avatar
Joined Aug 2012
Do you have the AUX channel assigned to a switch on your transmitter?
