Yep, that is why I wrote the added functionality in as a lot of people are having problems arming their KK2. http://www.rcgroups.com/forums/showthread.php?t=1743395 Plus one to Sudsy's request for a ( on my part ) DUMMIES GUIDE) 32 bit with XP Steveis could you oblige I would like to try and revive my dead KK2 with your code but no clue how Jeff |
![]() Jeff |
So has anyone used the board for anything other than a multicopter setup? A friend was over the other day and I was showing him my first quad and he sent me a text asking me to ask if anyone has used it on a cp heli for instance. I know in the settings there are many other flying setups to choose from. Just wondering if anyone has actually tried it. He was asking and thinking about trying it out on his trex.
United States, FL, Spring Hill
Joined Apr 2002
![]() Mike |
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Great Info
I had always figured that the FC was also being somehow calibrated, so wondered why doing them one at a time with the RX was still OK. Now I know. Thanks again. cheers, Andrew PS. Was just thinking about this, I know KK was concerned about props, but an individual output "pass through" test mode would be handy. Could use it to cal an individual ESC, or test the throw on a servo without unplugging stuff (which sometimes seems to lead to hard to diagnose problems when reconnected in error it seems). |
Joined Dec 2011
ESC Problem
I am having trouble with my KK2 board in that I try calibrating the ESC's and there is no Upper limit beep after the initialization tones...When I try to fly it, it will run for a while then motors 1 and 3 slow and stop. they are all ESC's with built in bec 30a
2212-13 motors |
France, RA, Roche-la-Molière
Joined Sep 2012
No news about that ?? ![]() Thanks |
United States, NY, Albany
Joined Sep 2012
Has anyone experienced a wobble at medium to slow flight speed, when the motors are unloaded, as in a slight descent?
I am flying a tri with 1.2 firmware. The model is VERY stable and has never had this problem using a original KK board with Pololu gyros, running Mike Barton 1.5 firmware. With the original board the model is extremely stable in calm to light wind. I have set up the KK2 with the same stability, (tested hand holding) and when I fly it I get this wobble. I have reduced the amplitude of the wobble a bit by turning off I gain and reducing P but then the model flies “sloppy’ and at that setting seems to hunt in pitch and roll. I have switched boards back and forth to eliminate any variables. This is what I get with the original KK and Mike Barton’s firmware just to show the model is airworthy.
I have downloaded the Flash Tool. I can't find the new code in the list for the KK2 board. I have downloaded and unzipped the new code from Steveis and have it in my downloads list. I can't figure out how to get the code from my PC to the board. Sudsy
If you downloaded the FW from the net somewhere. You have to open it in the file drop window. find it(where ever you saved it to) i.e decktop. once you have selected it. then you proceed to hit the green flash button and it well flash the FW for you... On lazyzero.de/en/modellbau/kkmulticopterflashtool there are lots of vid'son how to do it. ![]() If you already have the flashtool installed and the correct drivers etc...start watching around 5min mark... http://www.youtube.com/watch?feature...n75SOIw#at=275 |
Well the problem was that I changed the stick scaling on the rudder. I had it up at 60. I put it back to the default (30) and all is fine. Moral of story. Stop fooling with stuff! (yea right) Sudsy
ARMING question
I just watched the videos at this site:
http://scolton.blogspot.com/2012/09/...0-modding.html Does it make a difference if you ARM the board with self leveling on or off? Does ARMING with self leveling on make it more stable? I checked function on my first flight and I landed and turned self leveling on and made sure it didn't do anything weird. It flew fine. I have of course done the sensor calibration on a level surface. Also does the firmware I am flying (v 1.2)include the firmware this guy talks about? I just got the board from HK and they say it has the latest firmware (v 1.2). I am not Flashing anything since I have everything working well enough to fly. I guess I'm more of a Hardware guy and this Flashing the board kinda scares me. I will wait until I get my next two boards so I have a spare. How about the numbers for Height Dampening, anyone have a ballpark setting? Sudsy
