Old Oct 15, 2012, 03:40 PM
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Originally Posted by momofx View Post
Ok guys I got my quad 450 flying but I was wondering something - is the quad suppose to handle similar to a CP type helicopter?( ie. if you make it go in one direction it will keep going that way until you change the stick position). Sorry for the noob question - kinda in a hurry so I did not search lol.
In regular, non self leveling mode, yes presuming it is tuned properly.
brontide is offline Find More Posts by brontide
Old Oct 15, 2012, 04:48 PM
crashology student
Ontario, Canada
Joined May 2008
KK2.0 v1.2 won't arm
What a frustration ... took a very long time to troubleshoot - reading all the v1.2 arming posts/solutions; but I found one that worked for me ...
Program in a Rudder TRAVEL ADJUSTMENT of 108%, both left and right. VOILA!!
rshep is offline Find More Posts by rshep
Old Oct 15, 2012, 04:50 PM
GeezerGeek
Sudsy's Avatar
United States, MD, Lusby
Joined May 2012
What kind of radio system do you use?
Sudsy is offline Find More Posts by Sudsy
Old Oct 15, 2012, 05:12 PM
Joined Sep 2012
I would try recalibrating the sticks on the Tx. Also the big fixed kk1.2 has the added arming test to the receiver test screen that would have diagnosed this problem.
Old Oct 15, 2012, 06:34 PM
crashology student
Ontario, Canada
Joined May 2008
Sudsy, a Spectrum DX7. brontide, you make it all so simple ...
Old Oct 15, 2012, 06:48 PM
Custom quad builder
tech69x's Avatar
United States, TX, Spring
Joined Apr 2012
Hey guys look what I found and I'm not the seller nor do I know him just tought I would let y'all know
http://www.rcgroups.com/forums/showthread.php?t=1752075
tech69x is offline Find More Posts by tech69x
Latest blog entry: Win a frame
Old Oct 15, 2012, 07:22 PM
Canada, ON, Merrickville-Wolford
Joined Jun 2012
First Flight
Finally got my tricopter flying again. This is the second flight with a revised yaw setup and servo. The KK2 is basically stock 1.2FW, think I raised the yaw scale stick a bit based on a comment I saw here. Had to switch to low rates on roll & pitch while I get the hang of it.
Tricopter 2nd Flight (1 min 44 sec)
Blowing a gale today so I couldn't fly. Tried one flight tonight, thinking it might have calmed a bit (not much). Flew OK once I realized I'd inadvertently switched on auto-level & turned it off. Wondered why all of a sudden I had insufficient control. Fortunately the crash landing after getting blown downwind didn't damage anything. I think I'm going to switch it to the side spoiler lever to make inadvertent engagement less likely.
I broke the yaw servo on the first test flight when I clipped something. Likely my fault for using too wimpy a servo (HK 922MG with 1.8kg of torque) for the direct drive rcexplorer style yaw pivot. The new setup is close to hallstudio's, just with a motor block made of a scrap of cutting board plastic and a chunk of knitting needle as the pivot. Works great with the Turnigy MG930 servo (3.6kg of torque) and doesn't seem to flutter in flight at all, unlike the first version.
I'm looking forward to more flying and tuning if the weather cooperates.
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Oct 15, 2012, 07:46 PM
GeezerGeek
Sudsy's Avatar
Joined May 2012
http://youtu.be/SK92fhFo3QM
cheers,
Andrew
Good video. I especially liked the final comment. Walking away from a landing is a good thing. I hate the one's I have to run away from!!!
Old Oct 15, 2012, 10:11 PM
GeezerGeek
Sudsy's Avatar
Joined May 2012
Took off some lights and weighed it
I took 36 LEDs off and reconfigured the remaining.
Sudsy
Old Oct 15, 2012, 10:39 PM
GeezerGeek
Sudsy's Avatar
Joined May 2012
Height Dampening
Can anyone give me some Height Dampening numbers for a quad. Whats a good starting point and what are the setup elements? I am thinking this is throttle modulating? Or is it throttle dampening?
Sudsy
Old Oct 15, 2012, 11:22 PM
trinco's Avatar
Joined Mar 2012
testing my KK2 on RDX4
Quad FPV - RDX4 (3 min 19 sec)
trinco is offline Find More Posts by trinco
Old Oct 15, 2012, 11:41 PM
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Yep, that is why I wrote the added functionality in as a lot of people are having problems arming their KK2.
http://www.rcgroups.com/forums/showthread.php?t=1743395
Steveis is offline Find More Posts by Steveis
GeezerGeek
Sudsy's Avatar
Joined May 2012
Oh No!!
Well I got to foolin around with throttle travel settings and such on my DX7 and also turned on Height Dampening (set to 30/5) and now I can ARM with right rudder at idle but not SAFE with left rudder input at idle. Am I going to have to do the dreaded "throttle calibration" again? Should I just do each individual ESC straight from the receiver. I mean I'm retired and have nothing but time.
BTW I noticed that I was at 2/3 throttle yesterday just to hover. I did gain some rpm with the new settings. The machine just sounds more powerful now.
Should I do my P&I settings again. It rained here again today so I just slept in.
OK I just remembered the earlier post and have reset my rudder limits to 108/108. We will see if that works a little later. I may have increased the travel limits because I was not happy with the yaw rate. I checked other models on m Tx and reset throttle and rudder to defaults. I just have to stop fooling with stuff.
I think I forgot to say that it weighs 2.18 lbs without the battery pack. I am flying some 4 cell 4000 packs and they are pretty heavy. (308 grams/10 oz)
Sudsy
Old Oct 15, 2012, 11:47 PM
GeezerGeek
Sudsy's Avatar
Joined May 2012
Help
Can someone lead me to the instructions for "Flashing" this card? I have the usb interface cable from HK. I did reflash my old V-3 card but This is a new 64 bit computer and I used my old one before. I see the files. I just need a step by step procedure.
Sudsy
Old Oct 15, 2012, 11:50 PM
Son, Norway
Joined Sep 2004
Originally Posted by Dirt-Torpedo View Post
The +B hole is intended to tap into the positive lead from the flight pack and I did solder from the bottom - the wire was pushed in through the top and soldered on the back side of the board. No freaking way I would solder on the top side - too much surface mount and tight quarters.
It's always good practice to twist and tin the wire end before soldering it in place. This assures that all strands are soldered, they don't break because of vibration, and the solder joint will go all the way through the hole to the other side of the PCB.
Fred
flarssen is offline Find More Posts by flarssen
