Let the magic smoke out...
But I'm very glad it didn't happen in flight. My bad, as shown in the photo, a strand of wire was floating around off the battery monitor and an inadvertent 4S connection seems to have taken out the analog voltage reference.
Might be repairable but why chance it. The replacement KK will be fed more carefully, probably with insulated resistor lead. |
I am using a modified VC-550 QUAD/OCTO frame from HoverThings (www.hoverthings.com) with one arm removed, so the copter will look like a T instead of an Y. I had to extend the rear arm a bit and this has taken some time (Metal work is not my forte. ). You can expect pictures and additional information in a few days.
Maybe all that is needed is some stick trim. |
First Flight
All went well. I did learn a lot. My P&I settings came out to the following with a 10 MPH wind blowing and gusting to 15. I have a video and I know these numbers seem high as compared to anything I have read so far here. This is a HK Talon V-2 with four pancake motors the each weight 67 grams. (it's a heavy unit) I fy it with four cell 4000 Mha packs. I have just turned uo the yaw P gain to 100 and the Yaw P limit to 50 but I have not flown with these rudder settings. When that #4 motor went askew it made right rudder ineffective. The yaw was sluggish at best with the default settings.
P gain= 265 P limit=100 I gain=285 I limit=50 self level P gain=65 P limit=30 I plan to recheck in calm wind but I was anxious to fly it. I have a video for YouTube I will try to get up soon. The biggest problem was things getting loose. I used locktite on all fasteners but #4 motor lollipop was very loose and all four arms needed to be retightened. I hope it's just the parts getting to "know" each other. I did add set screws (grub screws) to the lillipop ends and think that will help that issue. Sudsy
First Flight Video
Hey, it was dark. And scary.
Really it flew well. But when the #4 came loose it became a handful. I found all four arms loose post flight. Hint, take tools with you. And locktite. If I continue to have problems with the mounts and arms coming loose I will maybe add some adhesive to joints. Rubber cement perhaps.
Sudsy
Also you have to let the locktite dry. I found after letting sit for a few days the screws really didn't come so loose. |
I re tightened everything with locktite. (took em all out and re installed) I also added some grub screws to the lollipops to help keep straight. I will build my own frame next. here's another video from tonight. The #4 motor really got out of whack here. Still these things are so resilient !!! Oh yea, Did I mention that I am taking off about half of the lights! Save all around. It's just too bright.
Sudsy
