Old Oct 10, 2012, 03:22 PM
RC911 is online now
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsų
Joined Aug 2012
Originally Posted by Sudsy View Post
I have one. Do you think a new "flash" will recover this board?
When I last flashed a board (KK v-3) I had a terrible time with my 64 bit machine. I then used a 32 bit laptop and it worked fine.
Is it just me?
Sudsy
I remember someone having a similar problem earlier in this thread. He could not get any input from pitch NOR roll. Re-flashing and doing a factory reset several times solved his problem. Maybe worth a try...
RC911 is online now Find More Posts by RC911
Old Oct 10, 2012, 03:23 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Gah, LCD light turns on, but nothing on the display and no response to inputs. Stripped all connectors and just tried one ESC at a time and I get the same behavior, lights on but nobody home.
What gives?
brontide is offline Find More Posts by brontide
Old Oct 10, 2012, 03:52 PM
CO2X is offline
Find More Posts by CO2X
CO2X's Avatar
United States, CA, Hayward
Joined Oct 2010
Vtail fleet
...just wanna share some pix of my bad boys on my fleet...both are flying really good.
CO2X is offline Find More Posts by CO2X
Old Oct 10, 2012, 03:57 PM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
Vtail final set-up
....my latest one...will not go for further improvement...this is the final set-up.
RC911....would you mind sharing your VTAIL Settings ? I'm using the Vtail configuration that tech69x that he shared to me.Just the rest of your kk2-1.2v settings. PM me when you have time...Thanks
Old Oct 10, 2012, 03:58 PM
Sandman43 is offline
Find More Posts by Sandman43
Sandman43's Avatar
United States, TX, Nassau Bay
Joined Apr 2012
What gives?
If you have the flash cord plug it into your computer and see if it comes on
Sandman43 is offline Find More Posts by Sandman43
Old Oct 10, 2012, 04:02 PM
gkovachi is offline
Find More Posts by gkovachi
United States, FL, Micco
Joined Apr 2007
What gives?
Many of us have had this issue with the display and have been unable to correct it (see earlier posts). After much grief with customer support at Hobby King I mailed the board back ($7.50 with no tracking ... tracking would have cost more than the board). A few weeks later, and only after several posts on their "Complaints" forum I received a credit to my account for the price of the board but no shipping compensation. Someone posted that they had the same problem and obtained an RMA number via the HK website and not through customer service chat line as I did. I would go that route instead ... it'll save you further delay and frustration.
George
gkovachi is offline Find More Posts by gkovachi
Old Oct 10, 2012, 04:12 PM
brontide is offline
Joined Sep 2012
Sometimes it will come to life, but then freeze up again on another screen. So the display is still functional, but nothing feeding it. I will try flashing it to see if that makes any difference.
Old Oct 10, 2012, 04:18 PM
Sandman43's Avatar
Joined Apr 2012
I know from experience you can plug your esc in backwards and the board will light up but no text. It obviously won't hurt it because mine still works. If it works through you computer you ether have something plugged in wrong or you are not getting power through you M1 plug
Old Oct 10, 2012, 04:38 PM
Sudsy is offline
Find More Posts by Sudsy
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
Originally Posted by Upup View Post
hi all I need some advice my esc on my quad will not arm they just keep beeping about three times a second the if i then press menu on the kk2 the beeping slows to about once a second the rx led flashes rapidly I have re bound the rx several times I expect this is something simple
dx61
18 amp hk ss esc
Jeff
I can't be of much help but I have had the same problem.
Sudsy
Sudsy is offline Find More Posts by Sudsy
Old Oct 10, 2012, 04:49 PM
Sandman43's Avatar
Joined Apr 2012
Hk ss 18 esc
I have the same ones. I had to to do a throttle calibration through the rx throttle plug individualy. then I did it again through the KK2 and it worked.
Old Oct 10, 2012, 04:55 PM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Originally Posted by TheFernMan View Post
i think ive seen something like this before... something about bad eeprom.. you can try flashing it with the Happy Sunday Aeroplane firmware and back to KK2 firmware but TRY IT AT YOUR OWN RISK.... i dont know .. maybe search for the bad eeprom thing..
Did it but the problem remains.
It will run for few moments (from 2" to 15") and i can browse the menu during that period.
Then it will freeze up and i must recycle the power for it to work.
Now i am back to KK2 V2.1 but no luck.
I guess is busted.
The annoying thing is that this think could have happened while airborne!!!!!!!!!
teopbako is offline Find More Posts by teopbako
Old Oct 10, 2012, 05:40 PM
brontide is offline
Joined Sep 2012
I guess is busted.
My symptoms are similar and its bad enough that power cycling no longer clears it, but waiting 10 minutes I might be able to bring up the version number.
Old Oct 10, 2012, 05:44 PM
RC911 is online now
8 bit is more fun
RC911's Avatar
Joined Aug 2012
I didn't change any setting except for the mixer values. I must be extremely lucky I guess...
Old Oct 10, 2012, 05:52 PM
RC911 is online now
8 bit is more fun
RC911's Avatar
Joined Aug 2012
I guess is busted.
If you push down on the bottom of the LCD (i.e. where the flexible cable from the main board is attached to the display), will this bring back the text?
Someone else reported this problem earlier in this thread.
Old Oct 10, 2012, 05:54 PM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
Vtail
Ok. That's what I did too...changed the mixer values and just playing around with the Self-level setting every now and then.What # you have on the self level settings ? What 'bout height dampening ? Mine is flying good but ,just curious 'bout your settings..My Vtail is 2.720 lbs.,how heavy was yours ?
