Joined Dec 2011
I hope to get to that skill level eventually. I still have very low hours on mine, alot due to having to wait for spare parts.. but more time on my Quad will ease my skitishness on the sticks hopefully and having a frame that I'm not scared of tumbling every now and then would be a big help too. I was looking @that CF frame from GLB before... is it reccomended? I really like your frame mod... with the wooden braces it looks pretty bulllet-proof if it survived those tumbles into that freshly plowed ground! ![]() What I don't like about mine is the glass-fibre frame, it really doesn't like impacts around the motor-mounts. Thanks for posting any frame build photos if you can. |
Joined Dec 2011
I've added some photos. The carbon is more or less completely destroyed around some of the motor mounts after countless crashes (see image DSC01826). But it still holds out well. I ordered three frames so that I have quite a bit of spare parts. I guess the wood stops a tiny bit of thrust, but as you can see from the video this small thing is more than angry enough. And the wood makes it much more sturdy, and it stops the flexing that the arms on this frame originally had. |
Joined Dec 2011
And by the way, I like these props: http://www.goodluckbuy.com/5045-5x4-...blade-red.html
Much better than the two blade I have on the micro quad in the images. I am currently flying the two blade props because I'm waiting for more supply of the three blade props... Those cheap two blade props from HK are too soft. I've even experienced it breaking mid air due to some aggressive manoeuvres. |
http://www.himodel.com/plane/3-blade...e_CCW_Red.html |
Latest blog entry: Win a frame
Joined Dec 2011
![]() Much thanks for the wooden brace photos, dang she can really take a lickn.. eh?! is there a particular reason for the slot cut into the ends of the front and rear wood braces in photo DSC01830?I currently using 6045 2-bladed props and ordered some 5045 2-bladed props from GLB to give a try, I figured faster blade speed = better acro performance? I think the stock blades were 5030 3-bladed props, but I found that blades broke-off waaaay too easilly!! especially compared to the GLB 2-blades. But If you have a preference for triples and have a link to durable ones.....
Night flying with the Armattan 339
United States, NY, Albany
Joined Sep 2012
Speaking of displays, what would be the best way to reattach a loose display. While functioning fine the backlight and LCD don't stay put on my HK KK2 anymore. Dab of superglue, tape, or what will keep it from wobbling around a little? Pressing and holding will not keep it stuck to the double stick that was there originally.
Joined Feb 2009
More tests...
It performs very well calibrated! Stable auto mode is very good and has saved me a couple of crashes. At one point in the video trying to do a 360 on the shaft and I was out of control, and motor give me very up, active stable mode and achieve stably bring back without problems ... I put a keychain camera (the 808) tied a seal, but the result was horrible, vibrations everywhere, anyone have any good way to mount it without noticeable vibrations? |
United States, TX, Richmond
Joined Aug 2010
Joined Aug 2010
Barometer and KK2
I was thinking of the following and I was wondering if this would work.
Create a small board with just a baro and processor that has been loaded with firmware to read and pass the signals from the receiver to the KK2 board. The receiver and motors are first plugged into the board. RX outputs from the board go to the RX headers on the KK2 while ESC outputs on the board go to the ESC headers on the KK2. The user hits a switch on the transmitter, which the board receives. The board determines the height using the barometer, reads the current throttle signal and then takes over the throttle control from the user feeding the KK2 the proper signals as if the user was trying to maintain height. When the user deactivates the switch, it gives throttle control back to the user. During the altitude hold process, the KK2 is allowed to process the other channel signals from the user so it can still yaw for example. |
