Old Oct 07, 2012, 05:53 PM
CO2X is offline
Find More Posts by CO2X
CO2X's Avatar
United States, CA, Hayward
Joined Oct 2010
Vtail COG
This is what I have on birds eyeview....got some with other opinion on the controller placement...I will try what will work but,I will try yours first and see.Thanks again !
CO2X is offline Find More Posts by CO2X
Old Oct 07, 2012, 06:13 PM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
vtail video
Originally Posted by RC911 View Post
It requires a browser plug-in, but I recommend downloading the file anyway and play it locally. Hope you'll like it.
Yes, I saw it ....very nice and I really like the way it looks and flys very good too..very cool ! Thanks for sharing....
Old Oct 07, 2012, 06:21 PM
RC911 is offline
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsų
Joined Aug 2012
Thanks! That is why I think you don't have to change your planned controller position.
RC911 is offline Find More Posts by RC911
Old Oct 07, 2012, 06:27 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
V-tail CoL & CoG
The strings are alchemy until someone produces a compelling case as to what it is supposed to represent and accomplish.
The orange dot in the attached pic is at the midpoint of the green line, which I suggest would be the center of lift for a spider frame with four level motors running at equal power/thrust levels. When you tilt the rear motors into that v-tail they will lose some net downward thrust effectiveness (since some of their total thrust is directed to the sides) and the center of lift will move forward, toward the purple dot.
Flow interaction between aft props (sucking from the same straw if you will) has the potential to further reduce their effectiveness and push the center of lift even farther forward.
Where you put the center of gravity is now up to you, and will depend on where you decide to put the rest of the heavy bits such as battery and cameras.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Oct 07, 2012, 06:37 PM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
controller
My plan was to put it where that big round hole by the middle of the frame...not much of a big change really.
Old Oct 07, 2012, 07:08 PM
Phalanx-0 is offline
Find More Posts by Phalanx-0
Hulk likes flying things
Phalanx-0's Avatar
United States, IN, Kokomo
Joined May 2008
I have been trying to fab a v tail vertical and havn't had much luck. Looking at the above thumbnails I see a simple solution to the V verticals. A model airplale aluminum landing gear. I don't know why I hadn't figured that out before.
I may try to build one again.
BTW whose picture is this? Is that Carbon Fiber or aluminum? What about the vibrations, are they dampened?
Phalanx-0 is offline Find More Posts by Phalanx-0
Old Oct 07, 2012, 08:42 PM
momofx is offline
Find More Posts by momofx
United States, IL
Joined Sep 2012
Its me again... unfortunately lol
Well thanks to you guys here I got my quad 450 up in the air .... but not for long lol - did not break it yet though Anyways, I cant figure out what to do with the adjustments and tried a few times - it seems like I cannot get it to hover at all and I am on the tx sticks like a mad man trying to keep it in the air lol.
I know its probably something with the settings (gains perhaps?) on the KK2.0? I am using the stock quad 450 settings. Is there a particular settings that anyone knows of that works well? Maybe its the settings on the 9x but which ones? Thanks!
momofx is offline Find More Posts by momofx
Old Oct 07, 2012, 08:48 PM
Rotorhead0207 is offline
Find More Posts by Rotorhead0207
Joined Dec 2007
what are your P and I setting an the stick scaling settings?
Rotorhead0207 is offline Find More Posts by Rotorhead0207
Old Oct 07, 2012, 08:50 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Well I got the LEDs on it I will post some video soon
Description: Name: ImageUploadedByTapatalk1349661040.378300.jpg
Description:
tech69x is offline Find More Posts by tech69x
Old Oct 07, 2012, 09:03 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
What are your setting? your P and I
watch these
SK450 Quadcopter Part3 Testing and Tuning (11 min 29 sec)
or
Hobbyking's KK2: QUICK START TUNING GUIDE (4 min 9 sec)
If your banging your sticks around, usually either your TX has to much expo, or the Gains are to low.
What i did was set the P gain to 50, and turned the I gain to 0. bump the P up untill you get a fast oscillation, then back of down 5 points and retest.
once the oscillation calms down its good.
then bring your I gain up 10 points at a time, until its starts oscillating again, but with I gain its a slower oscillation. Once you get that, back it down 5 points and re test as you did with with the P gain.
Not sure what your stick scaling is, but 30 is a good starting point. To low and it well be uncontrollable, to much and it well feel very touchy and responsive.
Hope this helps
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Oct 07, 2012, 09:38 PM
momofx is offline
United States, IL
Joined Sep 2012
Thanks eastcoast, I am going to closely watch those vids in a moment - my battery is low right now so its charging and its freezing cold outside right now - probably take it out tomorrow again.
Anyways, my P and I gains are the stock settings for the KK2.0 Quad X preset and the radio has the stock expo (Zero). Dual Rates are at 100% btw...
Old Oct 07, 2012, 09:59 PM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Originally Posted by Eastcoast78 View Post
shelterock
How low past 3v are your lipos? you can bring them back to life...But if they are puffed casue of the low voltage i would not.
Just charge them on a Nimh charge at the lowest charge rate. Mine(tritonEQ) is 0.1A. I had one at 2.8v before and it took 20 sec's to get it back up past 3v..that was over a year ago and its still going stong. But do at own risk! also use a lipo safe bag if you have one.With my esc's set at soft cut off, once i hit around the 3.5v it just dont have as much power. So im kinda puzzled how you manged to drain them to the point where there ruined?
But i do use a LVC alarm from ebay as well. one with the button on it that lets you adjust the lvc in the range of 2.7-3.7v i do belive!
they charge up to 12.6v but last about 30 sec of flight time. They never got low enough not to want to charge but simply have no punch left. 2 are just over a year and 1 is 8 months old, the other 6 months. If they have 20 charges on them each, I'd be surprised.
H
shelterock is offline Find More Posts by shelterock
Old Oct 07, 2012, 10:10 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
I hear ya on the cool temps in the evening..i just lite the fire in my igloo
You may want to give yourself some expo on your TX for learning. Just enough to soften the right stick up a bit. I found when i was learning. Over controlling is bad and the quad always seems to want to get ahead of your stick movement, which leads to banging the sticks around. More then likely where you are learning that is the case.
Once you get her dialled in, take your time and learn how to hover. Don't be afraid to slightly let your fingers off the stick to see how it want to drift..so you can trim it. These boards are very stable.
Also use small controls on the stick at first. left/right and forward/away from yourself then keeping the back of the quad closest to you. It takes practice
You could also bump your stick scaling down 5 points to slow the quad down a bit.
Old Oct 07, 2012, 10:11 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
H
Ohhh ic. that sucks...i was under the impression they went below 3v etc...
Old Oct 07, 2012, 10:35 PM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
Vtail on the air
....just got my VTAIL on the air...thanks for all the help guys !!!
....tuning is needed but so far I'm really happy on how it's flying.
This is just a temporary set-up...need to clean wires....
KK2.0-1.2 V * VTAIL 2ND INDOOR TEST FLIGHT (3 min 18 sec)
