Old Sep 29, 2012, 01:21 PM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Originally Posted by iCrap View Post
I flashed my KK2 with the newest Shane Colten FW yesterday, but now my quad is occilating and dosen't always respond... Pi gains are set to like 45. It worked yesterday but now its doing odd stuff, which is... odd. Also my Tx is on low battery, but i don't know if that affects it.
What should i do?
I would re-flash it. Sometimes flashing fails. I know because this has happened to 2 people I know. One of them is Partzee who posted a couple posts above yours.
Best,
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Sep 29, 2012, 01:22 PM
zokizo is offline
Find More Posts by zokizo
Joined Mar 2011
Hi all!
i fly today and i put unarmed quad for 3 mins after that i wanna to arm it and nothing
i disconnect battery connect it again display shows nothing just backlight is on
disconnect it again connect it again and again nothing
after few times everything its fine
now iam little scared to fly
what is possible reasons for this?
zokizo is offline Find More Posts by zokizo
Old Sep 29, 2012, 01:45 PM
iCrap is offline
Find More Posts by iCrap
iCrap's Avatar
United States, MD
Joined May 2012
Best,
Chris
A failed flash would cause the odd behavior? I would think it would just cause it to not work at all.
iCrap is offline Find More Posts by iCrap
Old Sep 29, 2012, 02:04 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Flash the stock 1.2 and see if it fixes your issue.
If so, then re-flash Shanes 1.2 over stock 1.2.
AcroFPV is offline Find More Posts by AcroFPV
Old Sep 29, 2012, 02:08 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
I'll give that a try.
Old Sep 29, 2012, 02:10 PM
NtiT is offline
Find More Posts by NtiT
Joined Sep 2012
Hey guys, I'm having a problem with my KK2 not responding to AIL/ELE input. These channels show up fine in the reciever test page, but absolutely nothing happens when I move the stick when the copter is armed. Yaw works fine.
I'm going to re-flash and see if it helps.
NtiT is offline Find More Posts by NtiT
Old Sep 29, 2012, 02:11 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Is auto-level on???
Old Sep 29, 2012, 02:24 PM
RC911 is offline
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsų
Joined Aug 2012
Did you get your USBasp working on Windows or are you using Linux?
RC911 is offline Find More Posts by RC911
Old Sep 29, 2012, 02:26 PM
bobepine's Avatar
Joined Jun 2011
Well, what you would think isn't quite right. After all, flashing the boards resulted in "odd" behavior for the person who asked, didn't it?
Ask Partzee.
In any case, re-flashing takes only seconds so it's worth a try.
Best,
Chris
Site Sponsor
Old Sep 29, 2012, 02:50 PM
NtiT is offline
Joined Sep 2012
Is auto-level on???
Autolevel is not on. I just flashed stock 1.2 and I have the same issue.
I got it working on Windows. Using the back USB port fixed it.
Ugh, I hope this isn't a HW problem, I was hoping to fly this weekend.
Old Sep 29, 2012, 03:10 PM
RC911 is offline
8 bit is more fun
RC911's Avatar
Joined Aug 2012
Did you run a sensor test?
How did you confirm that yaw is working OK?
Old Sep 29, 2012, 03:25 PM
NtiT is offline
Joined Sep 2012
Sensor test is OK. When I move the manually move the quad while throttled up, it resists the movement.
So I can throttle up fine, it lifts up, and can yaw around, but absolutely nothing happens when I use the right stick.
Old Sep 29, 2012, 03:54 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
Ask Partzee.
Best,
Chris
A reflash worked great!
Old Sep 29, 2012, 04:04 PM
RC911 is offline
8 bit is more fun
RC911's Avatar
Joined Aug 2012
Is your stick scaling set to zero for pitch and roll?
Did you select the correct motor layout?
Factory reset?
Old Sep 29, 2012, 04:28 PM
NtiT is offline
Joined Sep 2012
Factory reset?
Stick scaling is all 71/-71. I selected the right layout, Quad X. Although I have the same issue when I select, say, Quad +. I'll try a reset... doubt it will help.
