Old Sep 26, 2012, 01:20 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Originally Posted by ziggy95 View Post
Oh ok . Acc trim roll and pitch not modified : 0
Ok thanks I moved mine up to 20 couldn't tell any difference
tech69x is offline Find More Posts by tech69x
Old Sep 26, 2012, 01:28 PM
scolton is offline
Find More Posts by scolton
scolton's Avatar
United States, MA, Cambridge
Joined Aug 2012
Originally Posted by tedrobphoto View Post
Hi Shane
As a long time follower of the development of these Quads (and I post this link as one of the first amazing shots by Jast and Co at MIT year 2006!) I just had to but in and ask are you working along similar lines at MIT? as I saw in the background of one of your videos a reference to MIT.
The work that those guys did (SIX years ago!) amazed me then (AND STILL DOES)
You certainly seem to be on top of the game and even though the script appears not to be written in your usual language you are making steady progress.
I'm an old guy in UK and just bought one of these boards (a heck of a lot cheaper than my last board which relied on differential I.R. emission for stability )and I'm hoping I can make a stable quad out of it using your latest firmware.
Congratulations on your work to date and keep up the good work
Link http://www.youtube.com/watch?feature...&v=Csti6mHZNF4
Ted
I must admit I'm a relative newcomer to multirotors, so I hadn't seen this before, even though I was around MIT in 2006. Looks great! I guess that was just before the parts got really cheap.
Thanks!
scolton is offline Find More Posts by scolton
Old Sep 26, 2012, 01:33 PM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Originally Posted by Haych View Post
when I calibrate (by holding the 1st and 4th buttons) my motors spin up and "calibrating ESCs" is on the LCD. I cannot hear any beeps as the motors are spinning up. I can hold in the buttons for ages with the words "calibrating ESCs" on the LCD. Is there something I can change to make it work as I imagine it should?
I'm seeing the same issue. F30a escs with SimonK with NTM2826 1000kv motors. They all calibrate individually through the receiver but I get nothing through the kk2 board.
H
shelterock is offline Find More Posts by shelterock
Old Sep 26, 2012, 04:01 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Originally Posted by Matt Halton View Post
Hey Steve, many thanks, I'll have another try tomorrow, I can't remember if I reset it into tri mode again (have done it so many times the past few days) so will look at that first, and if there is a kind soul out there who can offer me a code, even better.
Will try the aux input for aileron control too, so once again, thanks
Matt
Hi Matt, attached is a modified KK2 hex file for you. It swaps the aileron and aux input. I've just flown with it. Now connect your rx aileron to the aux input on the KK2 board and see if the receiver test works.
Steve.
Steveis is offline Find More Posts by Steveis
Old Sep 26, 2012, 04:23 PM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
H
thanks for reply. I now know its not just me...
Have you used any other esc on your KK2 that does calibrate correctly through the KK2? Do you feel its the SimonK that is the difference?
I guess as long as the motors respond at the same time it will be OK. My Tricopter seems to fly fine, so as they say, if it ain't broke, don't fix it!
Haych is offline Find More Posts by Haych
Old Sep 26, 2012, 07:14 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Nice one steve hopefully Matt will find it of use.
Although with his Yaw servo moving when board is safe and motors not spinning makes me think board is kaput.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Sep 26, 2012, 10:37 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
what program do u use to view assembly code?
TheFernMan is offline Find More Posts by TheFernMan
Old Sep 26, 2012, 11:17 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Notepad will do or any text editor.
Erknie is offline Find More Posts by Erknie
Old Sep 26, 2012, 11:28 PM
TheFernMan's Avatar
Joined Jul 2012
thanks, i figured i could view the code like that. i just also wonder if there's tools for compiling also. kinda like how there's Eclipse for Java. you could write and view Java in notepad but running it is a pain in command line (not really)
Old Sep 26, 2012, 11:33 PM
Erknie is offline
Joined Nov 2011
AVRstudio is what you need.
Old Sep 27, 2012, 12:23 AM
TheFernMan's Avatar
Joined Jul 2012
Thanks!
Old Sep 27, 2012, 12:37 AM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
So today I had a fatal failure, while testing my tricopter at its highest altitude yet. Long story short, I came crashing down and my KK2 board broke free from the body mount. It was mounted using nylon nuts & bolts & the force was enough to break all 4 nylon nuts clean.
Of course the KK2 board no longer works. I get "NOT OK" on all the ACC. I know I'm not the first to have killed one of these boards. Is it hopelessly dead or has anybody been able to revive one of these things?
AcroFPV is online now Find More Posts by AcroFPV
Old Sep 27, 2012, 12:52 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Yea someone did I forget far back in the thread
Old Sep 27, 2012, 01:29 AM
TheFernMan's Avatar
Joined Jul 2012
The acc maybe came loose. Maybe the same person tech9x is referring to resolder a bad point from the acc and it was "ok" again. He figured it out when he push down on the acc and doing so read "ok" status on the test screen.
Old Sep 27, 2012, 01:30 AM
TheFernMan's Avatar
Joined Jul 2012
You could always just fly gyros only
