Old Sep 26, 2012, 08:25 AM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Originally Posted by Haych View Post
Im starting to wonder if its the RCTimer ESC (pre flashed with SimonK F/W) im using... Has this been noticed previously?
Using flashed ESC's on mine and still get the beeps with no motor spinning during calibration.
TX at full Throttle, connect battery and hold buttons 1 & 4 down, get beep then lower throttle to min, get another beep, then switch off.
Have you checked on Rx Test that throttle is operating in the correct sense ie 0 at min throt and 100 plus at full throt.
If using V1.0 you have to have butoons down when connecting battery.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Sep 26, 2012, 08:41 AM
tedrobphoto is offline
Find More Posts by tedrobphoto
Joined Jun 2006
Originally Posted by scolton View Post
Yep, I really like the way the fast auto-level flies. It's as good or better than some other much fancier flight controllers I've tried. Just wanted to reiterate that none of the theoretical work is my own - it's all in the v1.2 source code so KK deserves all the credit. I hope it makes its way into a stable release, maybe with a fix for the fast-yaw-while-tilted problem too...it will be awesome!
Hi Shane
As a long time follower of the development of these Quads (and I post this link as one of the first amazing shots by Jast and Co at MIT year 2006!) I just had to but in and ask are you working along similar lines at MIT? as I saw in the background of one of your videos a reference to MIT.
The work that those guys did (SIX years ago!) amazed me then (AND STILL DOES)
You certainly seem to be on top of the game and even though the script appears not to be written in your usual language you are making steady progress.
I'm an old guy in UK and just bought one of these boards (a heck of a lot cheaper than my last board which relied on differential I.R. emission for stability )and I'm hoping I can make a stable quad out of it using your latest firmware.
Congratulations on your work to date and keep up the good work
Link http://www.youtube.com/watch?feature...&v=Csti6mHZNF4
Ted
tedrobphoto is offline Find More Posts by tedrobphoto
Old Sep 26, 2012, 08:43 AM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
Hi, thanks for the reply.
Yes, I flashed my mates KK2 and his did the correct beeps, he uses Plush, I use RCTimer...
my throttle is set right, it even flies right, (tricopter) its just this calibration that I cant get to do what I want it to do.
I just flashed to Shanes Rev2 F/W from KK2 1.2 previously, both respond the same with calibration...
Haych is offline Find More Posts by Haych
Old Sep 26, 2012, 09:55 AM
ziggy95 is offline
Find More Posts by ziggy95
Joined Jul 2012
I tested the alternative firmware KK2_1V2_modS2.
Self level works great ! Values 70/30 in my HK Q450
ziggy95 is offline Find More Posts by ziggy95
Old Sep 26, 2012, 10:15 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Have you messed with the trim setting
tech69x is offline Find More Posts by tech69x
Old Sep 26, 2012, 10:23 AM
ziggy95 is offline
Joined Jul 2012
(Sorry for my english)
I have trimmed nothing.
My Quad was moving itself after i drop the sticks (in self level mode) until i input an higher value in Pgain and PLimit (70/30)
Pgain in Roll/Pitch/Yaw is only 30 for information
Old Sep 26, 2012, 10:31 AM
CO2X is offline
Find More Posts by CO2X
CO2X's Avatar
United States, CA, Hayward
Joined Oct 2010
3 blade props
Originally Posted by spudandretti View Post
GWS- 9050, bought them from RcDude a long time ago and just bought some more in the for sale thread. Can get them at a lot of places. I like running three blade props on my quads, seems to run smoother for me but that's probably just me.
Thank you sir !
CO2X is offline Find More Posts by CO2X
Old Sep 26, 2012, 10:54 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
I've been dying to fly again but I'm currently re building my quad with new motors and ESCs. Using smaller lighter stuff.
Keda A20-50 motors
HK BlueSeries 12a
1500mah 20c bat.
Using a DIYMulticopter frame.
Oh and of course the KK2 board
TheFernMan is offline Find More Posts by TheFernMan
Old Sep 26, 2012, 11:15 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
I am talking about the trim setting on the self level settings and your English is just fine
Old Sep 26, 2012, 11:17 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Keda A20-50 motors
HK BlueSeries 12a
1500mah 20c bat.
That sounds like a nice setup got any pic
Old Sep 26, 2012, 11:21 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
This is my DJI 450 with emp 750 kv motors hobbywing 40 amp Esc's and the kk2.0
My Project 5 (1 min 41 sec)
Old Sep 26, 2012, 11:38 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
If anyone in the us needs props this is a good place to get them
http://diyquadcopters.3dcartstores.c...Props_c_9.html
Old Sep 26, 2012, 11:47 AM
TheFernMan's Avatar
Joined Jul 2012
I see your "cheap US props site" and raise you a even cheaper site for props under 10"
RCPlaneBuilder
Old Sep 26, 2012, 11:53 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
RCPlaneBuilder
It's not my site and you might want to repost yours because it want open
ziggy95 is offline
Joined Jul 2012
Oh ok . Acc trim roll and pitch not modified : 0
