Good luck! |
why didn't you update repository 2 days back?!
Joined Apr 2012
I made a switched battery extension lead.. so now I hold 1 and 4 with one hand then just switch on...to calibrate
mind you I still cant work out all the beeps, my ESC's setup beeps don't seem to go at the same time so its well confusing.. Ive two KK2 quads on the go ,and on one I ended up calibrating each esc, one at a time, through the receiver direct.. that sorted it out fine.. all now work together through the board and the quad is stable .. something for newbies like myself to learn on.. the V929 from WL toys is only £30-40 and it works well and will give you a way to practice before you commit your main model |
Singapore
Joined Sep 2012
I did follow the method and also watch the video but both beeps from my ESC giving 2 beeps even the confirmation beep. After Armed the board, the 2nd motor (I'm on Quadcopter X mode) is not turning even when the throttle is at max. The rest of the motors turning fine. Could it due to improper calibration of ESC? |
Slovenia, Ljubljana
Joined Sep 2011
Australia, VIC, Melbourne
Joined Mar 2010
when I calibrate (by holding the 1st and 4th buttons) my motors spin up and "calibrating ESCs" is on the LCD. I cannot hear any beeps as the motors are spinning up. I can hold in the buttons for ages with the words "calibrating ESCs" on the LCD. Is there something I can change to make it work as I imagine it should?
Joined Mar 2010
This is your first quad. If so please be carful they are a lot of fun but they can hurt you to.
Latest blog entry: Win a frame
