Old Sep 25, 2012, 01:47 PM
hallstudio is offline
Find More Posts by hallstudio
Pilot not Drone Operator
hallstudio's Avatar
Marietta Ga.
Joined Apr 2005
Loaded up Shane's update to KK's software and it works. If you try flipping it on at a weird angle it can lock at a strange angle. Nothing I was not able to work with. Flip it off and back on and it was fine. You CAN NOT loop with this turned on. I got to stress test my frame when I slammed into the driveway tail boom first. Broke 3 props and a bent motor mount. Took almost 3 minutes to fix.
KK2 board with Shane Colton 1.2 on the cheap easy tricopter (3 min 56 sec)
hallstudio is offline Find More Posts by hallstudio
Old Sep 25, 2012, 02:07 PM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Originally Posted by tech69x View Post
I also recognized that scolton updated his mod and added it to the flashtool. The first mod will be removed to avoid any confusion.
Originally Posted by Matt Halton View Post
Thanks for your time to write that for me, very much appreciated
I have installed the cables exactly as stated, noting the orientation of the board with the photo on the HK link you posted.
I just attempted a fw upgrade, but had errors. I have captured shots from my screen which explains the problems. My laptop automatically found a USBasp driver on line and installed it, but the error says I need to update the driver?
Please let me know your thoughts on this.
Matt
Does the LCD backlight go on when you plug the usbasp into the PC? Then you read the pin out mirrored.
Christian
LazyZero is offline Find More Posts by LazyZero
Old Sep 25, 2012, 02:09 PM
Matt Halton is online now
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
Well guys, it's time to give up on this...I checked my wiring again(ugh) and found it was just one wire interposed with another-I swapped them over and tried reflashing, this time it erased data then wrote the new data (fw) onto my board!
This was encouraging I thought, removed from my laptop, went over to my T'Copter and re plugged the RX and ESC wires back in.
Armed easily enough, but worryingly the tail servo again deflected whist connecting the flight pack...I went into receiver test, and found that there is still no aileron signal..
Really annoying, that's board number three (this was the first KK2 board) so now will just wait for HK to post me out number 4..
Anyway, my screen capture shows the fruits of mine (and all of you good guys who helped me) labours, spent all day on this, but had to be tried..Now another waiting game with everything crossed that I will finally have a luck breakthrough, lol we'll see!!
Thanks again everyone.
Matt
Matt Halton is online now Find More Posts by Matt Halton
Old Sep 25, 2012, 02:15 PM
Wannabe B-26 pilot!
Joined Nov 2002
I'm not entirely sure what you're saying there Christian, but yes the LCD backlight did come back on when I plugged it into my PC, would that have made my board worse? I did manage to get a successful write onto the board with the firmware though, but as I said above, still no change, it behaved exactly as it did before the FW upgrade Lol am depressed now! Just hate waiting and waiting...
Old Sep 25, 2012, 03:07 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Did you change the controller back to a tricopter setup after you flashed it? Default is quad copter which will drive your servo off.
Steveis is offline Find More Posts by Steveis
Old Sep 25, 2012, 03:35 PM
Steveis is offline
AVR Dude
Joined Jul 2011
I'm pretty sure you said you connected the RX aileron output to the fc elevator input to prove when you moved the tx aileron the fc registered it as elevator moving.
Have you connected up the aux input to switch self levelling on and off? If you can check that works, perhaps some kind soul would compile a custom code for you to use the fc aux input for aileron instead. It's a simple change in readrx.asm (change IntRoll rx6: to pinb,0 and comment out IntAux). Sorry but I can't compile the code.
In fact, can you connect the aileron signal to the aux input to see if it sees it change.
Old Sep 25, 2012, 04:25 PM
Wannabe B-26 pilot!
Joined Nov 2002
Hey Steve, many thanks, I'll have another try tomorrow, I can't remember if I reset it into tri mode again (have done it so many times the past few days) so will look at that first, and if there is a kind soul out there who can offer me a code, even better.
Will try the aux input for aileron control too, so once again, thanks
Matt
Old Sep 25, 2012, 04:28 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Sorry to here it did not work Matt but it was worth a try.
This is my First KK board and has worked great, very easy to set up with the on board screen.
Never used previous versions of KK so no help with your previous two issues, does seem a bit weired you had same arming problem on two of them.
Maybe one of the geniuses here has an idea, it could get you flying whle awaiting new KK2.
I would RMA this duff one as it seems it is seriously messed up.
Del
Del-Dredd is offline Find More Posts by Del-Dredd
Old Sep 25, 2012, 04:47 PM
Wannabe B-26 pilot!
Joined Nov 2002
Del
Hi Del
I did try and try to get the previous 2 boards to arm with zero success, but I'm thinking, I might try firmware changes on them tomorrow, got nothing to lose have I?
Who knows, my luck may still change!
Yep, will go for that. I am aching to get my tri flying, I guess it will feel even better when it does!
I may still pick your brains yet...
Matt
Old Sep 25, 2012, 05:56 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
http://www.youtube.com/watch?v=prttXocII4s
http://web.mit.edu/scolton/www/kk2_1V2_modS2.zip
Did you use this version
tech69x is offline Find More Posts by tech69x
Old Sep 25, 2012, 06:34 PM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Need help: Tricopter servo not operational
Just installed a new KK2 board on a tricopter and loaded the tricopter motor setup, calibrated the ESCs, but the servo is not responding (this is when the throttle input is applied). To eliminate if the servo is bad, tested the servo on a different rig and it work fine.
LittleG is offline Find More Posts by LittleG
Old Sep 25, 2012, 06:45 PM
superdave42 is offline
Find More Posts by superdave42
Designer
superdave42's Avatar
morgan hill california
Joined May 2004
check the output "rate" for that channel, I think you have 2 settings, fast and standard. if you are using a digital servo then it could be set to fast
superdave42 is offline Find More Posts by superdave42
Old Sep 25, 2012, 07:53 PM
ntc is offline
ntc
Find More Posts by ntc
ntc
Australia, VIC, Melbourne
Joined Sep 2011
anyone know if the KK2 is going to be updated with a camera gimbal addon function that works with the quadcopter, unlike openero that is a standalone camera gimbal?
ntc is offline Find More Posts by ntc
Old Sep 25, 2012, 08:50 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Hot damn you are good at flying.
rcjose is offline Find More Posts by rcjose
Old Sep 25, 2012, 09:33 PM
LittleG is offline
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Resolved issue with the servo not operating
Figured out that the servo was not getting any power. Unlike the KK board, the middle pins (V+) of M1 is not connected to M2-M8 on the KK2. However, M2-M8 are connected.
