Old Sep 25, 2012, 06:51 AM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Originally Posted by dopplet View Post
Would love to see some pictures of your setup, I've been burning through arms on my HK F450 after going through 5 kits, I've got plenty of plates which are super strong haven't damaged one yet. Would be great to see how you got the alum towel bars mounted and what size they are.
Andrew
Thanks. I have a video coming up showing the details of the quad.
Jose
rcjose is offline Find More Posts by rcjose
Old Sep 25, 2012, 09:06 AM
RC911 is offline
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsø
Joined Aug 2012
Originally Posted by Matt Halton View Post
Relatively a noob at this Del, so not any of that yet..Just finding a diagram with the correct orientation on the flash cable is what I'm aiming for now, any ideas where I can get this info from?
You can find this information at HobbyKing. Look under the 'Files' tab for the KK2.0 product page. Additional details can be found on the product page for the USBasp programmer.
RC911 is offline Find More Posts by RC911
Old Sep 25, 2012, 09:44 AM
Matt Halton is online now
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
I did find that, but the images are a little confusing, One of them shows 7 ports, but there should only be 6 wires?
If I could figure out the correct sequence then there is no risk of destroying my board..I have ordered another USBasp with the correct 10-6 cable (sent me the wrong one on my first buy)
I have attached the images below.
Matt Halton is online now Find More Posts by Matt Halton
Old Sep 25, 2012, 09:56 AM
DrEvil is offline
Find More Posts by DrEvil
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
where do you see 7 wires ?
The first picture you link is correct.
DrEvil is offline Find More Posts by DrEvil
Old Sep 25, 2012, 10:00 AM
Wannabe B-26 pilot!
Joined Nov 2002
Oh yes!! Sorry about that, one of the lower ones in red, looked black to me, I can see it now, I have poor colour sight. Thanks. Edit: No it was actually the second image that shows 7..
So how do I connect up these wires in the correct order, some of the names on each port don't have corresponding names on the 6 port..Can anyone guide me to the correct corresponding sequence, wire by wire please?
Old Sep 25, 2012, 10:17 AM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Originally Posted by onlyifamppowered View Post
Has anyone else tried the new 1.2 Shane Colton edition yet ????
After reading his blog ( and I admit not really understanding it all) I am keen to try it but has the flip over problem been sorted?
The videos look amazing. I plan to try in on a big tricopter that I have flying well but just no so great on the autolevel.
Rob
Yup. Try it out and you will love it!! I heard the flip problem has been fixed and there is a new .hex you can download. I have only experienced the flip problem once, and that was after a crash. A quick power cycle fixed the issue.
Im going to load the new "fixed" .hex today and test it.
AcroFPV is offline Find More Posts by AcroFPV
Old Sep 25, 2012, 10:35 AM
pbmax is offline
Find More Posts by pbmax
pbmax's Avatar
United States, WA, Olympia
Joined Jan 2004
His blog page says that the yaw decoupling problem hasn't been resolved yet... so don't yaw while you're tilted.
pbmax is offline Find More Posts by pbmax
Old Sep 25, 2012, 11:24 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Ahhhhh... is that why my tri wanted to yaw like crazy after a while?? I thought I bumped my Yaw servo or something.
Old Sep 25, 2012, 11:26 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Where is the Kaptain????????????????????????????????
teopbako is offline Find More Posts by teopbako
Old Sep 25, 2012, 11:28 AM
RC911 is offline
8 bit is more fun
RC911's Avatar
Joined Aug 2012
'NC' means 'Not Connected' so this pin is not in use. You need to bring the six red pins in the first picture over to the smaller connector on KK2.0 like this:
MOSI -> MOSI = Pin 1 to pin 4.
VCC -> VCC = Pin 2 to pin 2.
RST -> RST = Pin 5 to pin 5.
SCK -> SCK = Pin 7 to pin 3.
MISO -> MISO = Pin 9 to pin 1.
GND -> GND = Pin 10 to pin 6.
Remember that your images depicts the male connectors (top-down view).
The picture below shows the KK2.0 ISP connector pin-out.
http://www.hobbyking.com/hobbyking/s...3X13752X49.jpg
Old Sep 25, 2012, 11:31 AM
scolton is offline
Find More Posts by scolton
scolton's Avatar
United States, MA, Cambridge
Joined Aug 2012
The yaw problem is what KapteinKuk describes in the previous post: If you are tilted at a steep angle and then you yaw quickly, the gyros can't update the pitch and roll angles. Imagine pitching up 30º, then yawing left quickly 90º. The true state is now roll left 30º and pitch 0º, but the pitch and roll gyros haven't recorded any rate of change, so the pitch and roll angles are only slowly corrected by the accelerometers.
In no case should that cause uncontrollable yaw. If anything, it will cause problems with pitch and roll.
scolton is offline Find More Posts by scolton
Old Sep 25, 2012, 11:39 AM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Like this:
Old Sep 25, 2012, 12:36 PM
Wannabe B-26 pilot!
Joined Nov 2002
Thanks for your time to write that for me, very much appreciated
I have installed the cables exactly as stated, noting the orientation of the board with the photo on the HK link you posted.
I just attempted a fw upgrade, but had errors. I have captured shots from my screen which explains the problems. My laptop automatically found a USBasp driver on line and installed it, but the error says I need to update the driver?
Please let me know your thoughts on this.
Matt
Old Sep 25, 2012, 12:41 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Matt
You can get a win7 driver from Hobby Kings website. There are two available, and it took me a little trial & error to get one to work right.
Old Sep 25, 2012, 01:46 PM
RC911 is offline
8 bit is more fun
RC911's Avatar
Joined Aug 2012
Matt
You may be using the wrong driver as user subaru4wd mentioned.
Did your KK2.0 board power up as you connected the programmer?
Do you have a receiver and/or ESCs connected to your KK2.0? If so, try removing these.
Some laptops have problems providing enough power through USB so you may want to use one of the rear USB connectors on a stationary PC or an USB hub with external 5V supply.
USB cables should be avoided.
