Slovenia, Ljubljana
Joined Sep 2011
Slovenia, Ljubljana
Joined Sep 2011
Kev [edit: They are HK Blue 20A esc's, and my DMM showed 4.95V at all times. It was a cheap meter so maybe there were spikes I didn't see. AC read less than the tolerance of the cheap DMM.] |
Joined Jul 2012
here you are ^^ :
Firmware 1.2 Pi == Roll/Pitch 30/100/15/20 Yaw 30/20/50/10 Mode Settings ============ Aux/Stick/Yes/Yes/No Stick Scaling =========== 30/30/50/86 Misc ==== 10/0/30/0/0 Self Level (not used) 70/70/0/0 CCPM (not used) 1/2/3/4/5 Mixer Editor (automatic with choice Quadricopter X) 100/-71/71/100/0/Esc/High HK Q450 (880g with battery 2200 3s - autonomie 10mn) Moteurs 1400 Kv Esc 18/20A Bec 2A Hélices 8x4,5 Carte KK2.0 |
Slovenia, Ljubljana
Joined Sep 2011
My next paragraph depends on the interpretation of the drawing. By "PPM" do you mean a combined PPM stream with all channels on ONE wire? I call this CPPM to avoid confusion. Or is it just conventional one-wire-per-channel PWM signals? (If multi-wire PWM) In the top-right drawing, your ESC on M1 will fight your BEC on the RX, via the KK2 and the RX connections. This is not recommended and will not help your KK2 or RX. The RX will work just fine powered with the KK2 via M1. The RX generally has better line filtering than the KK2. (If CPPM) In the top-right drawing, the BEC is only powering the RX. This is nice, but I think unnecessary. Placing a resistor where indicated on the ELE input loads the ESC on M1, not the KK2 or BEC. All the gyros and accs have their own 3.3V regs coming from the M1 5V line. This means the load on 5V can only affect the ESC supplying that power. I have no idea why you see the affect on your KK2 board. I suspect the gyros failing is something intermittent that is coincidental with your power experiments unfortunately. |
Austria
Joined Jan 2004
I'm using the same ESC, but I did flash them (this did change from night to day for my quad). If you don't want to flash them ... take care to: Configure all as : No Brakes, NiMh, HardTiming, 16KHz ESC calibration from KK2 will not work ... so just ignore it. All ESC will be needed to configured one by one ... so better you take the esc and 1 test motor out for do this operations. Use low value of PI ... and expect slow stability ... Else ... you can flash with SimonK firmware and your Quad will be ready for be in a different level Tchuss e_lm_70 |
