Old Sep 04, 2012, 01:26 AM
ffinybryn is offline
Find More Posts by ffinybryn
Crash or unscheduled landing?
Joined Dec 2011
Originally Posted by quinchu View Post
Yea, I'll swap it out tomorrow evening and see if that does the trick. Last ditch effort ya know. Good call for the motor, I'll post it up tomorrow and let y'all know.
or swap "bad" motor to another position to see if the problem stops or reverses.
ffinybryn is offline Find More Posts by ffinybryn
Old Sep 04, 2012, 01:35 AM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
Hi,
I just want to ask if we have the config of Gimbal only for this KK2 board. I love to used it as Gimbal control board. Thanks
caotri is offline Find More Posts by caotri
Old Sep 04, 2012, 01:44 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Originally Posted by tech69x View Post
I wish this board had one
If you need a magnetometer, then buy a board with one, there countless varieties.The people that buy the KK2 board don't need a magnetometer, just like they don't need a GPS, or they would have bought a board with one in the first place.
Erknie is offline Find More Posts by Erknie
Old Sep 04, 2012, 01:56 AM
Tengil is offline
Find More Posts by Tengil
Joined Jul 2012
Hej, I had a strange problem that I thinkshould be shared.
Me and my friend was putting two 450mm quads togeather with KK2 and Simonk ESCs.
We both have RCExplorer Tricopters with KK2s and they fly fantastic with Plush ESCs.
First thing I did was to flash both our bords to V1.2
My bord was stock 1.0 and my friends was already 1.1
Assembly, balansing,calibration etc. Time to fly!
I was however confused with the quad as I could not increase the P gain higher than 30 befure I got bad ocilations. My friend with a identical build could easy go above 150...
Time for some head scratching... Rebalance the props, remount the board, check all settings but no differance.
So finaly I decided to reflash (LazyZero) the board. And just like that the quad fly absolutly FANTASTIC!
I do not understand why this helped but it did.
Maybe this will help someone else.
Thanks for all your fantastic work, KK, LazyZero, SimonK!
Tengil is offline Find More Posts by Tengil
Old Sep 04, 2012, 02:09 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
The main improvement from 1.0 to 1.1 is the servo handling ... and 1.0 was already reported to don't work very well on a tri-copter.
1.2 it is only a bug fix of 1.1 about the calibration procedure ... so nothing added about stability functionality.
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Sep 04, 2012, 02:28 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by jer291113 View Post
Okay, thank you Rotorhead.
I'm using an ER9X and was thinking of increasing the tension a little bit, maybe that might help????
It will. I have done that and it works.
er9xuser is offline Find More Posts by er9xuser
Old Sep 04, 2012, 02:40 AM
Fordy1980 is offline
Find More Posts by Fordy1980
Australia, NSW, Caringbah
Joined Aug 2012
Hi Chris
Just changed the I gain on the yaw, didn't make any difference, unfortunately I don't have another board, might buy another one and see how that goes, in the mean time might reflash the firm ware and see what happens.
Thank you very much for your time, if I ever work out the problem I will post it up.
Fordy
Fordy1980 is offline Find More Posts by Fordy1980
Old Sep 04, 2012, 02:42 AM
icah is online now
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
Originally Posted by e_lm_70 View Post
I guess nobody care to have a stable quad in ground effect situation ...
I do care. This is always also part of my tests.
If the quad is stable in ground proximity it won't do sudden strange things in the air during hard maneuvers.
This is also a good point to check whether one has vibration problems.
If the quad oscillates just above the ground but it flies smooth 1m higher there is still too much vibration reaching the FC.
icah is online now Find More Posts by icah
Old Sep 04, 2012, 02:51 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Ok ... good points ... a bit in the direction of be ultra perfectionist ... but ... yes good points.
The airflow in some quad could have a mayor alteration in the ground effect ... it depends how "tall" are mounted the propellers ...
I have a old HK V1 framework, the one made of wood, designed with camera mount ... and this has almost no ground effect ...
Tchuss
e_lm_70
Old Sep 04, 2012, 02:59 AM
er9xuser is offline
Slovenia, Ljubljana
Joined Sep 2011
I you have flashed esc's with simonk fw-there is no ground effect.
Old Sep 04, 2012, 03:10 AM
icah is online now
Joined Oct 2010
Sir, yes, sir! I have
But besides the escs, it depends on the frame, the props, how "tall" are they mounted and the PID settings, even the battery mount position.
I am having almost no GE, similarly to e_lm_70 but with this frame, and I tell you it was not easy to set it up, I have made a lot of tests.
As you know the Q450 has quite a long bottom plate and it does not really help fighting the turbulences.
Old Sep 04, 2012, 03:18 AM
er9xuser is offline
Slovenia, Ljubljana
Joined Sep 2011
Correct.
Old Sep 04, 2012, 03:21 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
When can we expect self-leveling with accelerometers, not just gyros?
hefest is offline Find More Posts by hefest
e_lm_70 is offline
Austria
Joined Jan 2004
It is there already ... since 1.0
Old Sep 04, 2012, 03:24 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Im on the brink of ditching these RCTimer 2820/14 motors together with the adapters and props. Seems to me i can't find adapters machined well enough to reduce the vibration. Even the adapters that are screwed directly to the motor bell are too tall multiplying vibrations. Are there any cheaper motors than DJI with similar mounting mechanism? The ones that have propellers close to the motor itself?
