Old Sep 02, 2012, 07:48 AM
yanto32 is offline
Find More Posts by yanto32
Joined Jul 2012
Originally Posted by Skewp View Post
I was using "Octocopter + config" stock settings, I made no changes. After updating to V1.2 and using the "Octocopter + config" stock settings I get almost no yaw right response somehow.
this has happened to me a few times using quad x mode, i found that you had to have your transmitter on before you power your board up otherwise it comes up with no yaw input on the safe screen
yanto32 is offline Find More Posts by yanto32
Old Sep 02, 2012, 07:49 AM
Skewp is offline
Find More Posts by Skewp
In progress...
Skewp's Avatar
Estonia, Tartu County, Tartu
Joined Jul 2012
My transmitter is always ON before connecting battery to my copter. Tried factory reset, problem still stands.
Skewp is offline Find More Posts by Skewp
Old Sep 02, 2012, 08:03 AM
bobepine is offline
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Did you unplug the ESCs from the board when you flashed the new firmware? Perhaps you have the the ESCs not connected back to the same place? Just thinking out loud, here.
Recently, user Partzee updated the firmware on his Xcopter and after flashing, his quad did not fly well. I suggested that he flash it again just to be sure and it fixed it for him. Apparently, something did not flash right the first time even though avrude appeared to have successfully flashed the new firmware.
So try that. I suggest disconnect everything from the KK2 board and flash it again. It might just work for you, too.
Good luck.
Best,
Chris
bobepine is offline Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Sep 02, 2012, 09:15 AM
Skewp is offline
In progress...
Skewp's Avatar
Joined Jul 2012
Yes, I unplugged everything before firmware change. All ESC's were connected as the should be, double checked before and after flight.
I'll try reflashing it. Is there a stock firmware file somewhere incase V1.2 will not work for me?
Old Sep 02, 2012, 09:56 AM
pbmax is offline
Find More Posts by pbmax
pbmax's Avatar
United States, WA, Olympia
Joined Jan 2004
And you're sure you went and re-loaded the octcopter config after updating the board to 1.2? I read your post above, but it wasn't 100% clear that you did that.
pbmax is offline Find More Posts by pbmax
Old Sep 02, 2012, 09:59 AM
Skewp is offline
In progress...
Skewp's Avatar
Joined Jul 2012
Yes, I loaded Octocopter + config right after flashing it.
Old Sep 02, 2012, 10:10 AM
pbmax is offline
pbmax's Avatar
Joined Jan 2004
Hmm. Unfortunately there isn't a stock firmware available... you could try 1.1, I suppose, but that has a ESC calibration bug.
Is it possible self level mode got turned on somehow?
Old Sep 02, 2012, 10:17 AM
Skewp is offline
In progress...
Skewp's Avatar
Joined Jul 2012
Since V1.2 has only ESC calibration update compared to V1,1 they are basically the same.
I am more than 100% sure that self level function was not on. I even did not have AUX cable installed and even if self level was on, there should still be yaw movement. As far as I know, only right stick (on mode 2) is assosiated with self-level. There should be no changes to throttle/rudder stick. Could someone tell me the default values of PI in stock version? Is it possible, that V1.2 octocopter + config has programming defects?
Old Sep 02, 2012, 10:30 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Have you tryed to reload your motor layout
tech69x is offline Find More Posts by tech69x
Old Sep 02, 2012, 10:38 AM
Skewp is offline
In progress...
Skewp's Avatar
Joined Jul 2012
Tried twice.
Old Sep 02, 2012, 02:37 PM
Del-Dredd is online now
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Default PI values for original firmware are at the end of the manual, at least the one I downloaded anyway.
Default PI editor settings
Roll/Pitch Axis:
Pgain = 150
Plimit = 100
Igain = 50
Ilimit = 20
Yaw Axis:
Pgain = 150
Plimit = 20
Igain = 50
Ilimit = 10
Del-Dredd is online now Find More Posts by Del-Dredd
Old Sep 02, 2012, 02:53 PM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
I think I saw that if you have self level set to trigger from the aux channel (rather than stick) but don't have a wire hooked up that it defaults to on. FWIW (while things are at the "grasping at straws" phase :-).
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Sep 02, 2012, 04:03 PM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by bobepine View Post
Have you read the thread? Please read before you post. I know it's a long thread and you can't be expected to read the whole thing... But still... There are countless posts about this. The answer is YES... Many people have had issues with auto level. Things are improved with the latest firmware version and auto level trims have been added to the LCD programming options.
Best,
Chris
You are one seriously annoying poster, elm, and after this reply I shall ignore your posts because it's really not worth it to have to always correct you because you can't read English.
I did not say that the auto level doesn't work. But this is what you're reading in my posts, replying to, and thus, wasting everyone's time with your gibberish.
The other person did not ask if the auto level works or not. Learn to read for crying out loud. He asked if other people had issues with it. The answer to that question is YES. In the earlier version, most people experienced a drifting that could not be corrected and sluggish stick response. KK improved the stick response and added ACC trims to the LCD interface to address these issues in a subsequent firmware release.
So NO, I did not post false information. YES, many people have had issues with the auto level function (you'd know if you were able to read...), and YES, KK did make some improvements to the auto level in the recent firmware.
I am so done with you. PFFT!
And by the way, "Disinformation" is not even a word!!!
Chris
The problem is not the English, the problem is you saying wrong stuff, and instead admit it, you try to make 'noise' ... often it means you also attack
Autolevel works fine, nobody before reported that a quad got crazy when autolevel is switch on
Also, complains about autolevel is same as general configuration, some people make something wrong in the set up, and then blame autolevel
Anyhow, you are a master of disinformation ... and a very arrogant person
Tchuss
E_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Sep 02, 2012, 04:21 PM
e_lm_70 is offline
Austria
Joined Jan 2004
I dont think the issue is with autolevel
When you use 4ch only, and you set autolevel based on stick, in practice the quad will fly always , independently by the sticks, in a different way
With autolevel in stick mode, +100% elevator means to set the quad vertical, keep +50% elevator it means keep the quad at 45deg
If autolevel is controlled by aux, and is off, +100% elevator it means maximum rotation speed forward, +50% means rotation speed forward but half as before
So, in autolevel mode, it is not only to return in flat position, but as well control the angle by a fix stick position
Anyhow, yaw should bee partially independent from autolevel, and this anyhow dont explain why the problem is only in one direction
As most important check, i would enter in rx test page, and check if the reading of ch4 is correct, and left and right show same absolute value, but with a different sign (+/-)
As well ... double check all ch are properly center, changing tx and/or rx, the center position can be lkst
Kk2 does not learn the center tx/rx position at power up, but it is expected to be as hardcoded in the kk board, most probably around 1.5mSec
Tchuss
E_lm_70
Old Sep 02, 2012, 04:23 PM
e_lm_70 is offline
Austria
Joined Jan 2004
Roll/Pitch Axis:
Pgain = 150
Plimit = 100
Igain = 50
Ilimit = 20
Yaw Axis:
Pgain = 150
Plimit = 20
Igain = 50
Ilimit = 10
This are default for 1.0 firmware
Latest firmware has different default value
Tchuss
E_lm_70
