Old Sep 01, 2012, 10:46 AM
jhi is online now
jhi
Find More Posts by jhi
jhi
jhi's Avatar
Norway, Sogn og Fjordane, Naustdal
Joined Jun 2009
Originally Posted by zokizo View Post
yes, thanks
I don't think setting the alarm to zero is a good idea! Listen to "janekx" and set it to ab. 10.5 - 10.8V. Experiment and check voltage when KK2 is unarmed, that is a good indication how much juice is left. Voltage drop when motors are running is normal.
/Jan
jhi is online now Find More Posts by jhi
Old Sep 01, 2012, 10:53 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
yep if i land with my quad alarm stops beeping
so what i need to do turn it off?
and set up timer on my TX
Set it to a level that makes more sense, like 10V for a 3S pack. The best voltage threshold depends on many factors, like battery and actual current draw.
Fred
flarssen is online now Find More Posts by flarssen
Old Sep 01, 2012, 11:28 AM
pbmax is offline
Find More Posts by pbmax
pbmax's Avatar
United States, WA, Olympia
Joined Jan 2004
I use (for 3s packs) 10.8v on my quads and 11.1v on my tri. The less you discharge a lipoly the longer it'll last. If you're okay with slightly shorter life, then use a lower value. Personally, I wouldn't go below 10.5. At 10.8v alarm my batts are below 10% charge according to my balancing charger; that's pretty low.
pbmax is offline Find More Posts by pbmax
Old Sep 01, 2012, 01:12 PM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
Has anybody had their auto stable mode go crazy when switched on, but it flies fine with that mode off?
viper522 is offline Find More Posts by viper522
Old Sep 01, 2012, 01:58 PM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Have you read the thread? Please read before you post. I know it's a long thread and you can't be expected to read the whole thing... But still... There are countless posts about this. The answer is YES... Many people have had issues with auto level. Things are improved with the latest firmware version and auto level trims have been added to the LCD programming options.
Best,
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Sep 01, 2012, 02:06 PM
viper522 is offline
Joined Jan 2011
Best,
Chris
Chris, thanks for replying. My issue isn't just poor auto level performance, it's that auto level worked well (enough) and then stopped working well - and by that I mean it tries to flip the craft over if I turn it on now. I must have put a dozen batteries through it in auto level "stable" mode before shelving it while I worked on my EasyStar plane.
Old Sep 01, 2012, 02:17 PM
bobepine's Avatar
Joined Jun 2011
Oh... Sounds like moisture got to your ACC to me.
Good luck!
Best,
Chris
Site Sponsor
Old Sep 01, 2012, 03:39 PM
pbmax is offline
pbmax's Avatar
Joined Jan 2004
Have you tried recalibrating the sensors? Do they all read OK in sensor test?
Old Sep 01, 2012, 04:06 PM
viper522 is offline
Joined Jan 2011
I read your post and tried recalibrating and checking sensors, all says OK. Still no good, though. The back two motors overpower it (though the fronts are spinning fast too) and it tries to flip forward every time - even if I hold it in my hand. It's pretty well balanced front to back and flies very controllable in non-level mode.
Old Sep 01, 2012, 04:24 PM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Best,
Chris
Once again you are making disinformation
Autolevel with mr. Kk firmware, with a properly working quad an kk2.0 bord, and properly calibrated it is works fine
Kk2 autolevel s not state of art, nor ultra fast, nor precise in windy situations ... but it does not cause any problem
People that reported problem did use either an experimental firmware, or had some other issue
Tchuss
E_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Sep 01, 2012, 04:27 PM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
Something like my problems? http://www.rcgroups.com/forums/showthread.php?t=1723732
janekx is offline Find More Posts by janekx
Old Sep 01, 2012, 04:29 PM
e_lm_70 is offline
Austria
Joined Jan 2004
You may have some wrong configuration ... or some problem on the kk2.0 board
The kk2.0 board use "analogue" accelerometer, these pin with accelerometer signal are exposed on the back of the board ... check that all is clean, and no contact to some carbon or cable is on the back of the board
Look also the sensor test, and check that acc value make sense when you move the quad
Excess vibration can also conflict with the sensors ...
Tchuss
E_lm_70
Old Sep 01, 2012, 04:35 PM
e_lm_70 is offline
Austria
Joined Jan 2004
Originally Posted by janekx View Post
Autolevel will not stop a quad, if there is wind ... if the quad was going forward ... and as well if the cg is not in the exact center ... in all these situation autolevel will keep level the quad but it will not hold in position
Position hold need either a camera (kds stabilization system have it) or gps
Tchuss
E_lm_70
Ps: basic of physics: acceleration is a change in the speed, accelerometer measure speed changes, not the speed
Old Sep 01, 2012, 04:39 PM
janekx is offline
janekx's Avatar
Joined Aug 2012
CG ? there was no wind and if i undestand work of self level it should keep quad leveled by the calibrated values so have to goes up not to run on any side.
Old Sep 01, 2012, 04:50 PM
e_lm_70 is offline
Austria
Joined Jan 2004
If the center of gravity is not in the center of your 4 motors ... like a battery not in position ... Keeping level the quad will induce a lateral speed
Anyhow, autolevel is not for keep the quad stuck in one place ... it is only for keep it level ... on top the kk2 algorithm is a rudimental one .. so it will autolevel slowly with some possible small inaccuracy
Like a disk on a flat ice ... it is level ... if you give a kick (excluding the instant acceleration) it will move without sense any lateral accelerations
