Latest blog entry: Win a frame
For anyone who isn't sure how to set up the curves, here is a very quick walkthrough for those of you already somewhat familiar with er9x. I am not going into every detail, just the general steps. First, go into the curves menu and set up all the curves you plan on using. Choose any of the first 8 slots for 5-position curves, or if you need a more complex curve, use slots 9-13 for a 9-point curve. Once your curves are set, go into the mixer menu. You will be adding 3 entries under your throttle channel. All 3 will use the same source and multpx settings. Source: THR Multpx: Replace Then choose which curve gets assigned to each switch position. Curves: c1 (or any other curve you choose) Switch: ID0 Curves: c2 Switch: ID1 Curves: c3 Switch: ID2 ID0 is the top or N position of the 3-pos switch. ID1 is the Center or position 1 ID2 is the lower or position 2 I recommend assigning ID0 to the curve you use most often, so you don't get switch warnings every time you forget to set it back to default. While you are there, you can also program the throttle cut switch to work as it should by adding a 4th entry to your throttle channel mix. Source: Half Weight: -100 Switch: THR Multpx: Replace |
Canada, ON, Ottawa
Joined Jun 2009
It flies quite well with auto level off though. Just keep it off until KK comes up with a fix/enhancement. Regards. |
United States, OR, Portland
Joined Apr 2011
I like taking off with the auto-level on. I have a new quad that I haven't gotten around to making landing gear for so it sits a little uneven... So I just feed in throttle and it levels itself out, then I take off and start heading off, then switch it off. I have a tiny back patio that I'll take off and land from when I'm too lazy to go outside to fly and taking off/landing with the auto-level on makes it a LOT easier (especially with the reduced stick scaling). Other than that I've used it a few times to save it when I couldn't see.
Austria
Joined Jan 2004
As well nobody report crash due to autolevel on using the Mr. KK firmware Actually for a properly calibrated and configured quad, having autolevel on does help on having a more relaxing flight, definitely to be used for fpv In case of strong wind, autolevel off may work better A part from it, strongly suggest to keep it off... it is a wrong advice, ... wrong as saying that it is bugged ... it is just simple and slow at this stage ... but if it is left on in the firmware it means it is totally safe Tchuss E_lm_70 |
M. |
Canada, ON, Ottawa
Joined Jun 2009
![]() The author knows its limitations but the fans ignore them. There are actually blocks of improved code in the released 1.2 zip file but they were commented out due to other unresolved issues. While there was no change in auto level code in between V1.1. and V1.2, fans reported that auto levelling had improved in v1.2. That happened all the times in real life. The limitations are there, it is fine as long as you haven't hit them. I hit it several times with auto level on. It crashed violently upside down every time. It actually levels but it can act up violently rapidly under wind or even quick pilot actions. If the power available on board is limited, the acting up may be somewhat not so deadly and may be considered safe to use. As I suggested before if we turn the level gain way down, say to 1 or 2, it may cap the violent act up down, but the RX inputs do not scale and the quad would be deadly slow in terms of control. Anyway it is up to us to decide what to use and to believe. That is the fun part. I am still on this thread to check if Mr. KK has issued any fixes/improvement. I'll unsubscribe and scan the thread once a month instead. Bye now and make the best use of what is available. Good luck. |
"I will have to agree with you on this one"
Me too, I fly my Tri with it on nearly all the time unless I want to do Acro or some aggressive manouvres. It flies around great with it on and is still responsive, never had any glitches with it yet. (Using Flashed ESC's in case it makes a difference and P gains above 110). If trying to do aggresive manouvres or Acro with Auto Level on you deserve what you get in my book. |
There was somebody else using the board for stabilistion in a Flying wing who had it working I believe, do a search on thread and maybe PM him. |
