Old Aug 10, 2012, 01:34 AM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Originally Posted by viper522 View Post
Tried that, as well as OpenAero2.hex - fails at the same point with the same error.
Can you post a screen shot of your flashtool when you're ready to hit the flash button?
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Aug 10, 2012, 01:35 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Originally Posted by georgez View Post
Anyone know where I can get the drivers for Windows XP for USBasp? Hobbyking has a list that includes Windows 7. Can someone point my in the right direction. Thanks.
See the driver section on my homepage for the link to your programmer.
http://lazyzero.de/en/modellbau/kkmu...tool?&#drivers
Well that's just it, I'm not using a standard AVR programmer. I'm using a Ardruino Uno, a breadboard, some jumpers, couple servo cables...
But I'm pretty sure it's right. The LCD on the FC works fine. I referenced the other pins off the VCC and GND locations.
Wasn't there a issue with the reset of the Uno when using as a ISP adapter, I think I can remember you have to add a resitor and a electrolyt capasitor?
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old Aug 10, 2012, 01:38 AM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
Chris
I'm using avrdude from commandline. It looks like this:
C:\Users\David\Downloads\kkmulticopterflashtool_0. 63\lib\avrdude\windows\avrdude.exe -P com2 -b 19200 -c avrisp -p m324pa -U flash:w:c:
\users\david\downloads\kk2_1v1\kk2_1v1\kk2.hex:i -C C:\Users\David\Downloads\kkmulticopterflashtool_0. 63\lib\avrdude\windows\avrdude.conf -F -V
viper522 is offline Find More Posts by viper522
Old Aug 10, 2012, 01:39 AM
viper522 is offline
Joined Jan 2011
Best Christian
I read there was a heartbeat timing issue, which was corrected in arduino 1.0.1 example sketch (that's what i have on the Uno).
Old Aug 10, 2012, 01:40 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
What's the avrdude string you are using?
Are you certain you wired MOSI and MISO the right way around? What did you hook reset up to and what sketch are you using?
/EDIT nvm I took to long to post, you have already answered above.
Erknie is offline Find More Posts by Erknie
Old Aug 10, 2012, 01:46 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Found it:
On the Arduino Uno, you'll need to connect a 10 uF capacitor between reset and ground (after uploading the ArduinoISP sketch)
http://arduino.cc/en/Tutorial/ArduinoISP/
Old Aug 10, 2012, 01:51 AM
viper522 is offline
Joined Jan 2011
Interesting, I read right past that, because I was there earlier. Thanks, I will find a cap and give it a try tomorrow!
Old Aug 10, 2012, 01:57 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Been trying to flash this thing all night. Despite the fact that I'm giving avrdude the -V switch, it's still verifying. I'm using the avrdude .exe and .conf from the kkmulticopter flash tool 0.63.
I've seen this type of error before when flashing ESC's - I was using a proper programmer (AVR ISP MkII) but had the processor set as ATmega168 instead of ATmega8.
It appeared to flash OK, but then always failed on verification
<edit> just seen your cmd line, looks like you *are* specifying ATmega324 ...
Mike Barton is offline Find More Posts by Mike Barton
Old Aug 10, 2012, 02:11 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by evildean View Post
The Calibration process does not seem to occur for me... even though the menu displays "Calibrating ESCs" nothing seems to change.
Remember buttons 1 & 4 needs to be held down during the whole process.
Fred
flarssen is online now Find More Posts by flarssen
Old Aug 10, 2012, 02:22 AM
Akcopter is offline
Find More Posts by Akcopter
Akcopter's Avatar
Joined Apr 2012
Hey Mike Barton Please Come To Our Rescue And Kindly Convert This Evil Assembler To Human Understandable C-code (You See !! Assembler Can Only Be Understood By The Gods )
Akcopter is offline Find More Posts by Akcopter
Old Aug 10, 2012, 02:25 AM
Erknie is offline
Joined Nov 2011
LOL, I was looking at the KK2 1v1 source yesterday, and it's not too bad if you can remember what all the macros do. Like anything, it's what you get used to programming in, you tend to stick to it.
Old Aug 10, 2012, 02:30 AM
pinguin is online now
Find More Posts by pinguin
pinguin's Avatar
Joined May 2009
Originally Posted by e_lm_70 View Post
A servo signal is often said as PPM (that is maybe a bit wrong terminology) ... anyhow ... a servo signal is nothing else then a square wave, with a frequency of 50hz (can be more in some RX), with the time of signal logically to 1, that can be from 1ms to 2ms .. 1ms means -100 ...1.5ms means 0 ... 2ms means +100
CPPM ... is means to Compose all the signal into one signal ... up to maximum 8 (in normal cases) ...
This means the CPPM signal will send up to 8 square waves ... each with kept to logical 1 from 1ms to 2ms ... the order, means the channel.
So .. in short ... CPPM is a way to connect RX to KK2.0 using 1 single cable instead of 4 or 5 ... but you need a dedicated RX, since only few RX provide outside the CPPM signal
In other words ... if you don't know what is CPPM .. is because you don't need it ... since you probably don't have any RX capable for it
Tchuss
e_lm_70
So, CPPM is like serial bus?
pinguin is online now Find More Posts by pinguin
Old Aug 10, 2012, 02:33 AM
Fiskfan is offline
Find More Posts by Fiskfan
Sweden, Hudiksvall
Joined Aug 2012
Setting up Turnigy Plush 30A ESC
Hi
I am really new to this and has read this thread now twice....
I got almost all stuff to have my first crasch....
However, a question:
Do I need to change my ESC anything when they are new from HobbyKing? I saw in post #1184 that KapteinKUK was recomending Medium on one place... can the rest be as default or is there anything more I need to change?
Yes, I now about flashing now (since I read this thread twice) - I will do that later - first test and crasch some....
Thanks all for your inputs in this thread - VERY useful!
Fiskfan is offline Find More Posts by Fiskfan
Old Aug 10, 2012, 02:41 AM
Akcopter is offline
Akcopter's Avatar
Joined Apr 2012
Hey KK You said You would Release The Schematics For You board At The First software Update
Old Aug 10, 2012, 02:48 AM
United Kingdom
Joined Nov 2008
Ha ha.. don't think I'm going to be converting all that asm (I'll leave that to Erknie!)
Lots of work to do - just look at the 'acres' of code by HappySundays Aero2 to handle the menus
