Old Aug 08, 2012, 08:47 PM
rcall is online now
Find More Posts by rcall
FPVing for fun...
rcall's Avatar
Joined Jul 2003
just flashed my KK2 with LazyZero's tool... everything went fine...
thanks KK, Lazy and everyone else...
rcall is online now Find More Posts by rcall
Old Aug 08, 2012, 09:11 PM
steveiewonder is offline
Find More Posts by steveiewonder
U.S.A., Sufflok county , NY
Joined Nov 2007
Originally Posted by kapteinkuk View Post
New FW for the KK2.
CHANGES:
1: Removed: LCD contrast adjustment: Not necessary.
2: Removed: "I of PI" on/off mode: No practical use found.
3: Removed: I part of self-level: Does not work with slow reacting ACC.
4: Changed: default gains to 50/50/50 (roll/pitch/yaw) P-term, and 25, 25, 50 I-term.
5: Added: beep (short beep, 2 sec delay) when armed and throttle closed, for extra safety. Makes the KK2 a bit more noisy when armed so the user does not forget it is armed.
6: Added: longer arm/disarm beep.
7: Added: ACC trim. Use it to adjust self-level attitude, no need to recalibrate sensors. Adjust in "Self-level Settings" menu.
8: Added: factory reset.
9: Added: status messages on the "SAFE" screen. The KK2 will not arm unless it says "OK.". Error messages can only be reset by cycling the power, except for the "sensors not calibrated" message, which is reset after a successful sensor calibration. Error messages include lost RX connection.
10: Bug fix: wrong offset in flying wing mix table.
11: Changed: doubled self-level stick response. Let you have more control in self-level mode.
12: Added: CPPM (sum PPM) mode. Turned on/off in "Mode Settings" menu. Also the assignments of the CPPM channels can be changed in "CPPM Settings".
13: Added: Y4 and V-tail layout.
14: Added: shows battery voltage on the "SAFE" screen.
15: Added: lost aircraft alarm. Starts to beep (1 sec on and 4 sec off) after 30min of no activity (arm/disarm).
16: Added: LP filter on servo outputs. Adjust in "Misc. Settings". A good start value is 50.
17: Added: auto-disarm. The KK2 will disarm itself after 20 sec if throttle is at idle. For extra safety. Can be turned on/off in "Mode Settings" menu.
Download it below. You only need the "kk2.hex" file. The source is also included, with a license.
REMOVE PROPELLERS BEFORE FLASHING!!!11one0x31
(At least throw a blanket over the propellers if you are to lazy. )
Also check for correct operation before mounting the propellers.
Note that all settings is returned to default.
Have fun!
need some help please, here is the down loader tool for kk boards, I imported the zipped file, but cant seem to find the proper file for the new firmware for the kk2.0
steveiewonder is offline Find More Posts by steveiewonder
Old Aug 08, 2012, 09:16 PM
jabu32 is offline
Find More Posts by jabu32
Who put that tree there?!?!
jabu32's Avatar
Indianapolis, IN
Joined Jan 2011
you have the wrong controller selected. choose hobbyking kk2
jabu32 is offline Find More Posts by jabu32
Old Aug 08, 2012, 09:26 PM
Joined Nov 2007
funny I flashed a hk2.1 board to 4.7, but can't find the hobbyking kk2 I down loaded and unzipped the file opens as fl 328.hex is this correct?
Old Aug 08, 2012, 09:32 PM
georgez is offline
Find More Posts by georgez
C'mon Man!
georgez's Avatar
United States, TX, Denton
Joined Jul 2012
Is it just me or did Hobbyking remove the KK2 off their website? I was looking to buy another one tonight but I couldn't find it. Anyone know anything? Thanks.
FOUND IT!
georgez is offline Find More Posts by georgez
Old Aug 08, 2012, 09:34 PM
jabu32 is offline
jabu32's Avatar
Indianapolis, IN
Joined Jan 2011
did you read this pdf?
http://www.rcgroups.com/forums/showp...postcount=2107
download the latest software kkmulticopterflashtool_0.63. when you go to load the file kk2.hex
Old Aug 08, 2012, 09:35 PM
jabu32 is offline
jabu32's Avatar
Indianapolis, IN
Joined Jan 2011
http://www.hobbyking.com/hobbyking/s...rol_Board.html
Old Aug 08, 2012, 09:38 PM
georgez is offline
C'mon Man!
georgez's Avatar
Joined Jul 2012
Thanks. I was looking in the wrong area.
Old Aug 08, 2012, 09:51 PM
evildean is offline
Find More Posts by evildean
Blowtorch and a pair of pliers
evildean's Avatar
United States, WI, Sun Prairie
Joined Aug 2012
Has anyone noticed the esc configuration option is missing in the new firmware?
evildean is offline Find More Posts by evildean
Old Aug 08, 2012, 09:52 PM
bigbro3760 is offline
Find More Posts by bigbro3760
Joined May 2010
OT: buddy code for lipo
http://www.hobbyking.com/buddy.asp?c...B-6DDB061E10E7
thanks
bigbro3760 is offline Find More Posts by bigbro3760
Old Aug 08, 2012, 09:53 PM
evildean is offline
evildean's Avatar
Joined Aug 2012
esc calibration menu rather.
Old Aug 08, 2012, 10:07 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
And for good reason. Well-intentioned, I'm sure, but not the safest way to calibrate ESCs.
Best to do it manually
HappySundays is offline Find More Posts by HappySundays
Old Aug 08, 2012, 10:19 PM
sberfield is offline
Find More Posts by sberfield
United States, WA, Woodinville
Joined Jun 2012
All flashed.Thanks for the help everyone.
sberfield is offline Find More Posts by sberfield
Old Aug 08, 2012, 11:17 PM
Rotorhead0207 is offline
Find More Posts by Rotorhead0207
Joined Dec 2007
Originally Posted by Erknie View Post
Flybarless is the go now. The flight controllers on them are proprietary, brain dead features usually.
http://www.hyperionaustralia.com.au/?stg=1336&view=1336
www.skookumrobotics.com/ not brain dead by a long shot. I run a SK720 on a 450 rex and a 500 rex and every thing that you could want to adjust you can. Update the firmware just like a kk board. And a really good solid selflevel. Haven't run a SK540 on a quad and don't intend to because of cost.
Rotorhead0207 is offline Find More Posts by Rotorhead0207
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Just got done flashing all of my boards with no problem thanks K.K
tech69x is offline Find More Posts by tech69x
