Old Aug 08, 2012, 10:36 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Don't bother trying to read code from KK2 board - HK policy is to set fuses to protect the code...
you can ofcourse try just incase they missed one
Mike Barton is offline Find More Posts by Mike Barton
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
There's lots of OT discussion about simonK. There's a better place for that here:
http://www.rcgroups.com/forums/showthread.php?t=1513678
Kev
Truglodite is offline Find More Posts by Truglodite
Old Aug 08, 2012, 10:37 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
+1, LOL I try every one I get just in case.
Kev
Old Aug 08, 2012, 10:59 AM
bobepine is offline
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Originally Posted by jabu32 View Post
http://www.hobbyking.com/hobbyking/s...dProduct=26497
is this right?
what programmer do i need? is there a pinout diagram? will i really notice a difference from the plush esc's im using now?
These are the blue series, yes. Notice how they are blue, not red? These do not have the pads in a row so they are a bit harder to flash. These ones are the RED ones as per elm70 images above, and they have the pads in a row so much easier to flash. http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
The 30 amps are backordered now but the 20 amps are in stock.
Not sure if they will be better than your Plush ESCs. Perhaps it won't be really noticeable. I really don't know, I never used Plush and I never used Simonk ESCs, either.
About 5 pages back or so, tech69 posted a video tutorial for flashing the above ESCs. It works. I followed the instructions and I managed to flash 4 ESCs tonight quite easily. I have not tried them yet, though.
Best,
Chris
bobepine is offline Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Aug 08, 2012, 11:02 AM
bobepine is offline
bobepine's Avatar
Joined Jun 2011
Originally Posted by HappySundays View Post
Great, I have all the tools but I've never actually tried to reflash ESCs... I'll take note of what you do...
Well, Sir, just follow the video posted by tech69 earlier and all should be fine. Easy peasy. I'll be installing them tomorrow for a test flight. I will report back on how they compare with my Skywalker non flashed ESCs.
Oh, and thanks to Tech69 for all the help.
Best,
Chris
Site Sponsor
gkovachi is offline
Find More Posts by gkovachi
United States, FL, Micco
Joined Apr 2007
Kev
I attempted to read the code using the eePe programmer for my transmitter, Turnigy9x/er9x. After setting the MCU to mcu328P and then adding the argument -F I was able to create a hex file. Either this was not a viable read operation or the file looks as if not much code resides on th board. I apologize if I'm way off base but my knowledge of programming and available resources is fairly limited.
gkovachi is offline Find More Posts by gkovachi
Old Aug 08, 2012, 11:04 AM
bobepine is offline
bobepine's Avatar
Joined Jun 2011
Originally Posted by e_lm_70 View Post
You speak about this: http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
I order some few weeks ago, and I have some from over 1 years ago ... all are same with the 6 pin in the row ... the 20A is same as 30A ... just use different FET
This is a photo from the 30A, that is exactly as all my 20A :
Tchuss
e_lm_70
Are you color blind? LOL Thems are RED, dude.
Chris
Site Sponsor
Old Aug 08, 2012, 11:08 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
New FW for the KK2.
CHANGES:
1: Removed: LCD contrast adjustment: Not necessary.
2: Removed: "I of PI" on/off mode: No practical use found.
3: Removed: I part of self-level: Does not work with slow reacting ACC.
4: Changed: default gains to 50/50/50 (roll/pitch/yaw) P-term, and 25, 25, 50 I-term.
5: Added: beep (short beep, 2 sec delay) when armed and throttle closed, for extra safety. Makes the KK2 a bit more noisy when armed so the user does not forget it is armed.
6: Added: longer arm/disarm beep.
7: Added: ACC trim. Use it to adjust self-level attitude, no need to recalibrate sensors. Adjust in "Self-level Settings" menu.
8: Added: factory reset.
9: Added: status messages on the "SAFE" screen. The KK2 will not arm unless it says "OK.". Error messages can only be reset by cycling the power, except for the "sensors not calibrated" message, which is reset after a successful sensor calibration. Error messages include lost RX connection.
10: Bug fix: wrong offset in flying wing mix table.
11: Changed: doubled self-level stick response. Let you have more control in self-level mode.
12: Added: CPPM (sum PPM) mode. Turned on/off in "Mode Settings" menu. Also the assignments of the CPPM channels can be changed in "CPPM Settings".
13: Added: Y4 and V-tail layout.
14: Added: shows battery voltage on the "SAFE" screen.
15: Added: lost aircraft alarm. Starts to beep (1 sec on and 4 sec off) after 30min of no activity (arm/disarm).
16: Added: LP filter on servo outputs. Adjust in "Misc. Settings". A good start value is 50.
17: Added: auto-disarm. The KK2 will disarm itself after 20 sec if throttle is at idle. For extra safety. Can be turned on/off in "Mode Settings" menu.
Download it below. You only need the "kk2.hex" file. The source is also included, with a license.
REMOVE PROPELLERS BEFORE FLASHING!!!11one0x31
(At least throw a blanket over the propellers if you are to lazy. )
Also check for correct operation before mounting the propellers.
Note that all settings is returned to default.
Have fun!
kapteinkuk is offline Find More Posts by kapteinkuk
Old Aug 08, 2012, 11:09 AM
gkovachi is offline
Joined Apr 2007
sorry for the miscue. I'm about as well versed in posting as I am in understanding how to read code. I used the programming software I had available for flashing my Turnigy/er9x transmitter which provides for a "read" function. I set the mcu for m328p and the argument -F. It appeared to read and I received a hex file which I can't decipher except for a bunch of F's. Next I'll try to figure out how to post this file ... it may mean something to someone.
Old Aug 08, 2012, 11:15 AM
bobepine is offline
bobepine's Avatar
Joined Jun 2011
Originally Posted by kapteinkuk View Post
New FW for the KK2.
CHANGES:
Have fun!
Woah!!!! NIIIIICE!!!!
Awesome work. 3rd one arrived today, fourth one on the way.
Thank you, Sir.
Best,
Chris
Site Sponsor
Old Aug 08, 2012, 11:36 AM
bobepine is offline
bobepine's Avatar
Joined Jun 2011
I just tried flashing KK2.hex with avrude but it did not work. It's getting the wrong signature and there's an error setting fuses. Is the KK flashtool not ready yet for this update?
Chris
Site Sponsor
Old Aug 08, 2012, 11:37 AM
jabu32 is online now
Find More Posts by jabu32
Who put that tree there?!?!
jabu32's Avatar
Indianapolis, IN
Joined Jan 2011
Great.
jabu32 is online now Find More Posts by jabu32
Old Aug 08, 2012, 11:41 AM
oddcopter is offline
Find More Posts by oddcopter
Quadcopter Addict
Joined Nov 2011
Any changes to the self-leveling algorithms other than the stick response change?
Thanks!
oddcopter is offline Find More Posts by oddcopter
Old Aug 08, 2012, 11:44 AM
Rotorhead0207 is offline
Find More Posts by Rotorhead0207
Joined Dec 2007
Thanks Rolf aka kapteinkuk a gold star hangs over the Gates for your effort!
Rotorhead0207 is offline Find More Posts by Rotorhead0207
Old Aug 08, 2012, 12:10 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
New FW for the KK2...
Thank you very much for all the great changes and hard work Kaptein!!!
rcjose is offline Find More Posts by rcjose
