Old Aug 08, 2012, 01:45 AM
Lpbug is offline
Find More Posts by Lpbug
United States, CA, Santa Monica
Joined Jul 2011
Hey KapteinKuk- any chance you'll release the source code for the firmware so we can all play around with it?
Lpbug is offline Find More Posts by Lpbug
Old Aug 08, 2012, 01:53 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
Originally Posted by kapteinkuk View Post
I can think of two reasons: 20MHz oscillator is not starting, or flash memory corruption.
As soon as I get my hands on a dead KK2, I will investigate.
If someone can send me one, I will pay shipping. Preferable close to Norway so the shipping will be low.
The KK2 must have died (no text, LED flash or beep), on its own. No crash or mis-wiring.
However, I can not supply a new board.
Bugger...
Do you think that it may come back to life if i flash it with your new firmware when you release it?
I have other FC i can use so its not the end of the world.
Its a shame it bricked itself as it had allot of potential.
Cheers
Ben
Borneoben is offline Find More Posts by Borneoben
Old Aug 08, 2012, 02:02 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Originally Posted by wazzer View Post
Bugger...
Cheers
Ben
Just send it back to HK under warranty.
Maybe they will send it to Rolf or analyse and give you a new one.
Erknie is offline Find More Posts by Erknie
Old Aug 08, 2012, 03:05 AM
rustymit is offline
Find More Posts by rustymit
rustymit's Avatar
Saudi Arabia, Tabuk Province, Tabuk
Joined Nov 2005
Just Callibrated my esc's using the "y" splitter method, flawless, worked realy well. I have 4, 30A Blue series and trying to cal them using the fc is a nightmare, I believe it's because there is so much lag in the binding of spektrum receivers, the esc's enter into their program mode quicker than the Spektrum can react
rustymit is offline Find More Posts by rustymit
Old Aug 08, 2012, 03:26 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Originally Posted by HappySundays View Post
LOL... and that's in assembler.
My code (written in C) is currently at about 93% program, 72% data.
I still have a few features I want to put in...
I'm sure a good C compiler is not far behind assembler size wise, or speed wise.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Aug 08, 2012, 03:32 AM
Quad Whisperer
Joined Jul 2008
Originally Posted by sharonx View Post
Any time frame for the improved SL firmware ?
No, not yet.
Old Aug 08, 2012, 03:38 AM
Quad Whisperer
Joined Jul 2008
Yes, I will do that.
Old Aug 08, 2012, 03:40 AM
Quad Whisperer
Joined Jul 2008
Bugger...
Cheers
Ben
Yes, If flash memory corruption is the problem, the new FW will fix it.
Do you have a programmer, and can check if the dead KK2 responds to it?
Old Aug 08, 2012, 04:02 AM
Joined Jan 2005
Yes i do
I will check it out and let you know
Old Aug 08, 2012, 05:49 AM
quax is offline
Find More Posts by quax
quax's Avatar
NRW, Germany
Joined Apr 2004
In deed, the code generation and the optimizer become better and better.
I think the advantage of your software is your "binary-float", that should be less code comsumptive than the standard float implementation.
If a software doesn't use floats, there may be an advantage for the C compiler over ASM meanwhile.
quax is offline Find More Posts by quax
Old Aug 08, 2012, 06:14 AM
NEAGRON is offline
Find More Posts by NEAGRON
United Kingdom, Scotland, Aberdeen
Joined Mar 2010
Flashing
Hi,Simon,why dont you get "HK",to do a flashed speed controller,and get paid royalties,and then it will make us all happy,Marty.
NEAGRON is offline Find More Posts by NEAGRON
Old Aug 08, 2012, 06:32 AM
AeroR is offline
Find More Posts by AeroR
Joined May 2012
Hi all,
I'm a bit confused about my KK2 board.
I have replaced my genuine DJI F450 frame with a home made 300mm quad frame.
I have calibrated the sensors and ESCs again as if starting afresh.
I have changed the following settings in my PI editor:
Roll/Pitch
PGain: 20
PLimit: 100
IGain: 0
I Limit: 20
Yaw:
PGain: 40
Plimit: 20
I Gain: 0
I Limit: 10
Self level is off,
Stick Scaling: Roll-30, Pitch-30, Yaw-30, Throttle-90.
It is still drifting to the left( I mean Motor #2 side) and I have put a set of new balanced props and a new quad frame.
What causes a quad to drift to one side only?Is it in the PI settings or other issues?Im lost.
It is a very easy board to learn and I have noticed it is quite stable during flight but only problem is drift.
Now onto receiver test:
I have noticed the following:
Elevator- stick movement forward, it shows (-94) a negative value on the KK2 screen!
Stick movement back, it shows +101+ a positive value on the screen.
Stick movement is correct though and corresponds to the appropriate movement.
Rudder- stick movement to the left, it shows +101, a positive figure on KK2 screen.
Stick movement to the right, it shows (-94), a negative figure on the screen.
Stick movement is correct.
Is this normal?
What am I missing?
Im using a Hitec- Aurora 9 Tx with Optima 9 Rx.
The rest, that is the Aileron and Throttle are fine and no dramas.
How do I fix this if it is wrong.
Anyone please care to explain where I'm wrong.
I really like this board a lot because of its ease to change settings on the spot.
Thanks a lot,
AeroR
AeroR is offline Find More Posts by AeroR
icah is offline
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
Originally Posted by bobepine View Post
Look at the video I posted above. That's with 110 on the stick scaling for pitch and roll. It's aggressive though. I never go full stick to flip it with 110. It will easily pull triple flips at 110. You can start at around 80 and increase if it flips too slow for you, or if you like to be able to flip closer to center stick like me.
Best,
Chris
But I do!
I am also in this business for some time. This is how it flips@110 stick scaling with full stick (go to 0:45):
HK KK2.0 diy quad crash compilation (1 min 16 sec)
icah is offline Find More Posts by icah
Old Aug 08, 2012, 06:39 AM
AeroR is offline
Joined May 2012
Yes, I agree with Neagron. It would be a win-win for all involved.
AeroR
Old Aug 08, 2012, 06:51 AM
Phalanx-0 is offline
Find More Posts by Phalanx-0
Hulk likes flying things
Phalanx-0's Avatar
United States, IN, Kokomo
Joined May 2008
Learn to flash your own, it's easy.
Phalanx-0 is offline Find More Posts by Phalanx-0
