Australia, QLD, Brisbane
Joined Nov 2011
If you are sure you haven't got the wires plugged into the wrong receiver channel, then program your transmitter for the correct layout. |
Joined Sep 2011
plus can't seem to get a hold of a decent starting point for setting the gains on my SQ450 frame with the KK2 board, seam to get lots of left right banking when its about 10cm off the ground, too scared to try get it higher. anyone with a similar quad in x configuration mind posting some decent starting points. |
Joined Jun 2011
Thank you! Chris |
Joined Jun 2011
The 1510 motors are crap, though. The shaft ends up loose inside the can. I managed to mod mine using BJ weld and securing the props savers directly to the shaft and the can and it finally solved this problem. Before that, I went through a motor every few flights even without crashing. Quite pathetic, really. And not xactly cheap at around 18 bucks a pop. Here's what the mod looks like: ![]() Best, Chris |
Looks like a bad servo. |
Is your frame similar to this one? Is the motor similar to this one? The recommended prop is 5" for 3s and 6" for 2s battery. |
The jitter seems to start on a middle range of the stick movement........yet sometimes when I move the stick very very slow, the jitter does not appear..... This makes me believe that the KK2 actually picks the small movement of the servos that moves a little bit the flying wing a bit or is transmited through the foam( the servos are moving actually in small steps) and tries to counteract it...........LOL I've tried lovering the P gain down to 5 or 10 but then I have no or to little control from the sticks to the elevons and neighter the KK board move them sufficient.... I've tried to play with P limit from 50 to 500 and it seems that after say 100, the travel of the elevons is not increasing anymore......... Strange behaviour for my understanding..... |
Austria
Joined Jan 2004
Hi,
Did anybody did crash with the KK2 due to "saturated" ... Mine just end up totally out of control ... and I was not even doing any hard manoeuvre ... once recover ... on the display was showing the saturated error ... and motor was in beeping status (this help me to find my micro quad at least) No failure on the quad at all .. luckily the quad did fall on a tree, and got no damage at all ... so just replug the battery and it was able to fly again perfectly ... So .. to me it sound there is a bug in the KK2 ... in some situation go in overflow and the quad is going to sink like a brick ... I can post an on board video of the crash ... Tchuss e_lm_70 |
I was FPV hovering and it feels like one motor dropped all of the sudden resulting in altitude loss of about 2m after which it recovered. So far I'm finding it hard to control while flying FPV. even just to hover. |
Joined Jul 2008
Joined Jul 2008
Check the resistor R1, visually (it is burned?) and resistance. It is between Output#1 and the yellow capacitor. |
Joined Jun 2011
I think 2s and three 3s is a reference to 2 blades or three blades props. I'm not sure, but I think so. I used 5" three bladed props before so I figured that if I go with only two bladed props I should try 6 inch instead. I'm sure 5 inch would fly, too, and it may even be more agile. I don't have any to try, though. Best, Chris |
Joined Jul 2008
