Joined Dec 2011
![]() The dual props and prop-savers look to be a good update for better acro. I'll probably stick with the Tri-blades when I build mine until I get used to the wee beast, thanks for posting your settings and such... it'll be a great help for tuning my build. I have 2 pick-ups @the post... could be my X250 and the RX802! but I'll still need my KK2 and LiPos... c'mon HobbyKing! can't let y'all here have all the Fun.
Joined Dec 2007
[QUOTE=g00bd0g;22308675]Thanks, it's a good thought, but I'd rather not unbalance my packs every flight. Other ideas?
how many LED's are you running that it'll unbalance your packs? if you balance charge it won't make any difference. I've done this for years with up to 8 LEDs and still use the packs after 4 years no problems. |
Joined Dec 2007
Canada, ON, Kincardine
Joined Feb 2009
I am having an odd problem.
My Tricopter flew very well (other than autolevel) with the factory default settings. I decided to try tuning it to get the autolevel working well enough and now I have an unflyable machine. I have reversed all of the settings that I have changed but now regardless of the Pgain I get uncontrollable oscilations when trying to take off. The motors seem to act like the input to them is very delayed so on start up they all spin up and then when one side dips low it suddenly gets a large input that seems to oscillate from motor to motor. Is there a way to get the factory firmware to undo whatever software problem I seem to have caused? |
Joined Dec 2007
Joined Jun 2011
My new KK2 shipped two days ago so I'm in the same boat as you waiting on Hobby King at the moment. I also ordered some more powerful motors, I think it will be a sick setup. Cheers, mate! Chris |
Joined Nov 2007
Hey, Chris what is the equipment set up on your 250 what kv motors to run on three cell, props size speed control size ect. Did you get the frame from Xheli.com? Thanks steve |
Joined Sep 2011
why is my roll and yaw sticks swapped?
Hey guys,
I fly mode 2, and with the new KK2 board when I plug everything in according to the appropriate positions, ie rud to rud, ail to ail, I end up with my aileron control on the left stick and the rudder control on the right stick, surely this is not how it is meant to be right?, a person said to swith the rud and aileron servo cables around and on the screen just treat the ail as rud and rud as aileron. I wanted to know if all mode two flyers are doing this or is it just me. I use a turnigy 9x with er9x firmware. any help or views are greatly appreciated! |
