Old Nov 29, 2012, 04:33 PM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Scott,
Thank you for the complement, you will like yours as well. IMHO on of the more sexy subs out there!
When you set the pieces on a table deck down, do they line up then? (Remember to prop up the fore and aft pieces because the center portion has the conning tower key in it)
I am on the road and when I stop tonight I will post some pictures.
Peace,
Tom
tchalfant is offline Find More Posts by tchalfant
Old Nov 29, 2012, 07:53 PM
laser110 is offline
Find More Posts by laser110
Just Limin'
laser110's Avatar
United States, NJ, East Brunswick
Joined Nov 2008
Tom,
See the pics attached. I put the aft peice on the hull which is fitted in place and set by the notch underneath that aligns and holds in place. If I put the middle piece butted up next to it and then the front peice to align with the hawser opening at the bow, I have the gap you see in pic 1.
If I put the bow peice on and butt the middle deck peice up to it, I have the gap you see in pic 2 between the middle and aft piece.
Something I am not doing right here?
Scott
laser110 is offline Find More Posts by laser110
Old Nov 30, 2012, 10:28 AM
tchalfant's Avatar
Joined Aug 2011
Scott,
I see what you mean.
On my build, the deck was glued together first. I also removed most of the under structure. If you are going to R/C this keep whatever is above the waterline as light as possible. Especially if you want to get to a waterline for surface running.
Description:
Description:
I do not know how you are going to separate your deck. My deck comes off and used the pins in the front to slide the deck onto. There are a lot of people that will cut along the waterline.
Description:
On mine there is a end cap at the aft end to receive a screw. The hole is counter sunk to allow the screw to be flush. I hope this info helps.
Description:
Description:
Once the deck is glued together, then I did the sides.
Description:
Here is the gap I ended up with. I was going to put some styrene card stock in and close this up, but I ended up not doing that (I do not remember my reason - lazy or it was not that important)
Description:
So, IMHO if you end up with a gap, it is better to keep that gap in the front, at the bow, smallest area to work on.
Old Nov 30, 2012, 09:57 PM
War Fish is offline
Find More Posts by War Fish
War Fish's Avatar
USA, TX, Cypress
Joined Aug 2005
Tom,
Would you mind adding a pic of the full hull so I can see what all you cut away? I'm curious how much of the upper cross-members you can leave and still get a caswell wtc in there.
War Fish is offline Find More Posts by War Fish
Old Nov 30, 2012, 11:22 PM
tchalfant's Avatar
Joined Aug 2011
Sure Paul!
Here is a rough in. I knew that weight was important so
i kept snipping away
Description:
This is the finished hull.
Description:
Description:
Description:
Old Dec 01, 2012, 10:11 PM
laser110 is offline
Just Limin'
laser110's Avatar
Joined Nov 2008
Tom,
Think I solved the issue by being able to move the aft deck up a little bit. This closed the gap. I am not R/Cing the boat. The lake I sail at is known to eat subs. I am doing a very detailed static model. I am using photoetched deck plates which over lap slightly the plastic area, so any small gap should be covered.
Scott
Old Dec 01, 2012, 10:49 PM
War Fish is offline
War Fish's Avatar
USA, TX, Cypress
Joined Aug 2005
Tom, thanks for the pics! That was what I was hoping to do with mine -- now I know it will work.
Old Dec 01, 2012, 11:19 PM
tchalfant's Avatar
Joined Aug 2011
Scott, I would really like to see your sub finished, please share! I can not use much brass because weight above water line.
Paul, really glad to help. Likewise, I want to see your sub, I am looking to building another Gato.
Old Dec 05, 2012, 03:43 PM
laser110 is offline
Just Limin'
laser110's Avatar
Joined Nov 2008
Tom,
I have a thread here. Been doing work the past few days and will add pics to it.
Scott
Old Apr 22, 2013, 10:07 PM
tchalfant's Avatar
Joined Aug 2011
There are those small nagging things that you want to take care of, but seem to put it off. Since I have taken a break from the Aluminaut build (there is stuff brewing there) and I have not jumped into the Moebius Skipjack yet (probably this coming weekend) I have taken the time to work on some of those things. One of those was the periscope on the Gato. Earlier I posted about casting them. Well, now it was time to install and test.
To install I used clear silicon, CA did not hold well. I fully expect to knock this off many times, but I wanted something to finish off the tube (and keep it functional). The tube aft of the periscope is a tube that can be removed. right now it serves no purpose other than protect the main periscope. Originally I was going to top both tubes off, but I like the drama of one scope piercing the water surface.
The scope does not look bad and certainly will look perfectly acceptable at sea.
Name: Revell Gato Periscope 01.jpg
Description:
When I put a little light on the subject, you can see the area opened up to let air into the SNORT system.
Name: Revell Gato Periscope 02.jpg
Description:
I tested the sub in the inflatable submersible test tank. She did well. Ran for 40 minutes and no issues this is hopeful.
I also removed the riser under the 20mm. Although some subs had that, a lot did not. It always thought it looked funny.
Name: Revell Gato 20mm Deck Gun.jpg
Description:
Pool time this weekend!
A dear friend gave my son and I a Type XXIII, did a little cleanup on the WTC (a Modified Small World Models WTC - which are brilliant WTC designs)
Name: Small World Models WTC.jpeg
Description:
and tweaking to get it to work on my radio. Got it wet
My son was captain. The sub handled well and he really handled it well.
Description:
Description:
Throw in Cub Scouts and secret plans on the lathe and that mostly catches up on the happenings around this house.
Old May 29, 2013, 01:24 AM
tchalfant's Avatar
Joined Aug 2011
O.K. worked on a case for my 808 keychain camera.
Here is a little video to share.
Revel Gato 1/72 Underwater Film (2 min 56 sec)
Hope you enjoy!
Old May 29, 2013, 05:53 PM
War Fish is offline
War Fish's Avatar
USA, TX, Cypress
Joined Aug 2005
Wow, Tom. She really handles well.
Old May 29, 2013, 08:39 PM
tchalfant's Avatar
Joined Aug 2011
Thanks Paul. Yours will too! I love the Gato. How is your build coming along?
Old May 31, 2013, 04:14 PM
ThorDesign is offline
Find More Posts by ThorDesign
Wichita, Kansas
Joined Jan 2004
Its a shame that Dave Manley no longer produces his kits and cylinders. They were all top notch and very reasonably priced.
ThorDesign is offline Find More Posts by ThorDesign
Old Jun 01, 2013, 02:27 AM
tchalfant's Avatar
Joined Aug 2011
I agree with you. I have a WTC in my 32nd Parallel Type XXIII that is a Small World Models. It is simply brilliant in its design. I sound like a broken record about this wtc, but the more i play with it, the more i see some really well thought out designs. This Gato is using a D&E Sub-Driver which is also really cool, it would be fun to do a comparison. Has anyone done comparison tests?
Description:
Description:
I will test the 808 camera on the Type 23 soon.
Discussion Scale Brass Propellers for Revell 1/72 Type VII C redboat219 Submarines 23 Jun 24, 2012 08:50 PM
Wanted stock plastic deck for 1/72 Revell type VIIC Reckless Boats (FS/W) 0 Jun 05, 2012 09:49 PM
Discussion Engel Akula and Revell Gato Rick227 Submarines 0 Jan 14, 2012 07:28 PM
Discussion Selling my Revell Gato project Steve2381 Submarines 0 Sep 22, 2011 05:50 PM
