Old Jun 19, 2012, 10:43 PM
Bearsa LLC is offline
Find More Posts by Bearsa LLC
F550 Hex, Blade mQX
United States, CO, Colorado Springs
Joined Jun 2012
Question
How does a Direct Drive Variable Pitch Multicopter Achieve Yaw?
ASs stated, there seem to be several Direct Drive (Single Motor driving all props through gears/belts) Variable Pitch Multicopters, but i am confused as to how these obtain yaw motion.
I know that on independent drive multicopters, each motor can spin at a slightly different speed to achieve the desired yaw, but a multicopter with a single motor cannot achieve this through the same method.
Not sure how variable pitch could achieve a yawing motion either on a direct drive.
So, how does a Direct Drive Variable Pitch Multicopter Achieve Yaw?
Bearsa LLC is offline Find More Posts by Bearsa LLC
Old Jun 19, 2012, 11:20 PM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
more lift created by increasing pitch is the same as increasing rotor speed on a fixed pitch multicopter
SGsoar is offline Find More Posts by SGsoar
Old Jun 19, 2012, 11:58 PM
F550 Hex, Blade mQX
Joined Jun 2012
I know about the lift, and providing more lift in one side of the aircraft would provide pitch and roll, but still not yaw.
Old Jun 20, 2012, 01:10 AM
tdriedger is offline
Find More Posts by tdriedger
USA, CA, San Carlos
Joined Apr 2003
Increased pitch on one pair of rotors and decreased pitch on the other pair. This creates the torque difference to yaw the multicopter.
Don't ask me how to control yaw at 0 pitch.
tdriedger is offline Find More Posts by tdriedger
Old Jun 20, 2012, 05:19 AM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
Well at 0 pitch with cp heli blades you're either on the ground or heading there fast
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Old Jun 20, 2012, 10:05 AM
USA, CA, San Carlos
Joined Apr 2003
Stall turn?
Old Jun 20, 2012, 02:04 PM
machina is offline
Find More Posts by machina
Linux Compatible
machina's Avatar
United States, DC, Washington
Joined Dec 2007
This is it.
It's all about creating that resultant torque. There isn't anything intrinsic about the motor speed that would *require* a differential to create the torque needed to yaw.
machina is offline Find More Posts by machina
Old Jun 20, 2012, 02:11 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
The easiest way I have found is to use a V-Tail although I am not using it right now for variable pitch. Otherwise, it would require a sensor to detect when the pitch is positive or negative then adjust the motors' speed accordingly or on a tricopter, reverse the rotation angle..
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jun 20, 2012, 02:28 PM
Joined Aug 2009
P.S. IMO, there is little or no need to worry about Zero Pitch. If the the Pitch remains there for any length of time, the copter is going to drop like a rock. Now ask me how I know this. LOL
Question What does Direct Drive really mean when referring to rc electric motors? easystarfpv4 Electric Plane Talk 6 May 06, 2013 01:56 PM
Discussion How does Winglet toe-angle affect Yaw stability alexlb Flying Wings 4 Apr 09, 2012 06:57 AM
Discussion Longest FPV flight ever achieved by multicopter? Freakazoid FPV Talk 14 Feb 15, 2012 06:05 AM
Discussion How does the real osprey control yaw? RCvertt VTOLs 9 Jan 30, 2012 11:54 AM
Wanted GWS 1060 Direct drive AKA GWS 10x6 Direct Drive Alex Schauer Aircraft - General - Miscellaneous (FS/W) 0 Jan 16, 2012 07:29 PM
