Old Jun 19, 2012, 08:30 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
power source at field?
I sometimes have no power source at events and fields that I fly at.
I need some source of 12 volts. What are you guys using? I was looking into a 100 dollar harbour freight generator or a 12 volt marine battery. What would be better. I normally fly 2200 mah 3 cell batteries.
thanks Rich
rcrich is offline Find More Posts by rcrich
Old Jun 19, 2012, 08:33 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Get a big ASS deep cycle battery or 2.
Don't waste your money on a cheap generator.
They are not good for our chargers and your neighbors will hate you for it.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jun 19, 2012, 09:03 PM
typeRA is offline
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
I use a Honeywell 1400W inverter generator; it's quiet enough at the other end of a 50-foot extension cord.
A non-inverter generator is an option, but I would use a power conditioner with it to clean up the AC.
typeRA is offline Find More Posts by typeRA
Old Jun 19, 2012, 09:05 PM
DrV is online now
DrV
Find More Posts by DrV
DrV
Joined Jan 2006
Get Big Deep cycle battery or spend more money for a quality generator like a Honda EU2000. Do not buy the cheap 2 cycle HF generator, you will ruin your power supplies. It does not have a clean 120AC output.
DrV is online now Find More Posts by DrV
Old Jun 19, 2012, 09:16 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Could not disagree more.
I use the Harbor Freight - it works fine for chargers and have used it for many years. It is a bit loud and uses a 2 cycle engine - so no question it makes some noise. I use a good power supply and have no issue with voltage and zero issues with the chargers.
At the field nobody will care about the slight noise - the glow engines will drown this out. It works great for fly-in events and this use. Don't expect much else out of it - maybe a few lights or small appliances in a power outage. At events I have power 8 or 9 50-200w chargers.
I am not sure when my power supplies will be ruined but I am still going strong.
Deep cycle batteries last about 3 years here in the TX heat. And they are VERY expensive and VERY heavy. So save your money. Use a generator/inverter.
I would love to have a 2000w inverter but those run about $800-1k. But they are much more useful if you camp or have an RV or want to use it for appliances in a power outage. If you can hack the price the Honda is really tough to beat and puts out very clean AC power.
Old Jun 19, 2012, 11:07 PM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
I went with with 2 costco deep cycles. They are 45lbs each so need to watch the back when lifting them. I put them in a milkcrate and use a small fold away dolly. I never discharge them below 50% so I should get 3yrs no prob. AT $85 each and 3yr lifespan, it would take 15+ years to break even on a 2000 watt Honda so I'm pretty happy with my setup for now. Don't get me wrong though.. I would love one of those Honda's.
TheTick is offline Find More Posts by TheTick
Old Jun 19, 2012, 11:09 PM
Rich Ness is offline
Find More Posts by Rich Ness
United States, MN, South St Paul
Joined Dec 2000
Check your local surplus stores for big lead acid batteries. I have a 100 amp hour battery that cost me $29.99. I've been using it for at least 7 years. The deep cycles I was using in the past would only last a year or so and cost much more.
If you can't find a surplus battery I have been happy enough with this battery that I would buy a new one at full retail.
A slightly different battery, but easily available would be the Optima deep cycles. Imthink you can even getnthese at Sam's club.
Rich Ness is offline Find More Posts by Rich Ness
Old Jun 19, 2012, 11:42 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Sealed lead acids rock! They are commonly used in power wheelchairs and very affordable if you get the smaller ones. Great for charging 3-4s 2000's.
Old Jun 20, 2012, 12:32 AM
typeRA is offline
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
I would go with LiFePO4 over lead-acid; if only for the huge weight advantage.
Old Jun 20, 2012, 04:23 AM
crashdaily is online now
Find More Posts by crashdaily
crashdaily's Avatar
Down Under
Joined Mar 2008
I use a 12 V Pb spare car battery. I know that many will disagree, but it depends what you are flying.
I fly el. gliders using 2200 mAh batteries and I have 3 packs. If I charge them at home I have 3x 30-60 min flights, then I can charge each at the field for another 3x 30-60 min. Enough for a day flying.
But if you can afford a deep cycle battery or a generator - it's definitly a better option.
crashdaily is online now Find More Posts by crashdaily
Old Jun 20, 2012, 07:17 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
No argument here
My field charging requirements are similar to yours. I'm in my 3rd season using a NAPA garden tractor battery that after rebate, set me back about 22 bucks, and doesn't break my back As soon as I get back home, I hook it up to the little 1.5A Schummacher float charger and it's fully charged for my next trip to the field.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jun 20, 2012, 09:11 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
An alternator puts out a “pure” sine wave, an inverter does not! Better/expensive inverters get close and are called pure sine wave; most are modified sine wave.
The alternator in a cheap generator still puts out a “pure” sine wave whose frequency is directly proportional to the rpm! The problem is that they have poor/no control of rpm with changing loads.
I’m guessing that there something that make an Inverter Generator cheaper & lighter than one with an alternator. And the electronics maintain the frequency better. Also think that they get the DC off a magneto and inject that high into the block diagram shown below.
Maybe cheaper inverter generators are modified sine wave; pure from more $$?
The question really become – is modified good enough?
Most all of us take alternators to the field!
In my case 2007 Ford Explorer – it has a 120A unit.
Note – switching power supplies run just fine w/o issue off a modified sine wave!
So, go for a inverter and PS off your car.
I have been using my MasTech 5020 power supply with a Vector 2000W modified since wave inverter for quite. The engine doesn’t flinch or change rpm when doing a 1000W from the inverter .
Also use an extension cord from to get the power to the pits.
jrb is offline Find More Posts by jrb
Old Jun 20, 2012, 07:16 PM
tsymonds is offline
Find More Posts by tsymonds
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
Best piece of field gear I've ever had.
tsymonds is offline Find More Posts by tsymonds
Old Jun 20, 2012, 10:33 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
It's a Honda so I know it's good but it has a high price tag for me
Old Jun 21, 2012, 07:39 AM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Got mine used. They can be found for a reasonable price if you go that route.
Discussion Power source from Dell server power source jjudd DIY Electronics 4 May 17, 2012 07:47 AM
Discussion I need a new field battery for charging at the field Wild Bill Batteries and Chargers 10 Oct 18, 2011 03:39 PM
Discussion OT: Slumming at the power field surfimp Slope 81 Jun 26, 2007 01:42 PM
Discussion Power loss at the field. mustangjbb Batteries and Chargers 3 Feb 05, 2007 06:34 AM
AT Computer Power Supply Conversion for use with field chargers LostMyPlane Batteries and Chargers 21 Feb 24, 2005 09:24 PM
