Old Jun 19, 2012, 08:03 PM
Ditchdiger is offline
Find More Posts by Ditchdiger
LikeABoss
Ditchdiger's Avatar
Canada, SK, Fort Qu'Appelle
Joined May 2012
Question
What do pinion sizes mean?
Hey This is a newb question sorry for that but I need to know what is the difference between pinion sizes??? Does the lower make it go faster but less torque and the higher more torque less speed? Or vise versa? Thanks, zach
Ditchdiger is offline Find More Posts by Ditchdiger
Old Jun 20, 2012, 08:15 AM
LaTuFu is offline
Find More Posts by LaTuFu
LaTuFu's Avatar
United States, VA, Bedford
Joined Oct 2011
The smaller the pinion, smaller speed, smaller heat buildup. Larger the pinion, bigger speed and more heat.
A larger pinion will also reduce acceleration and run times. These statements are "generally speaking"
If you change the spur gear, the changes are opposite. Smaller to go faster. The changes are less noticeable, too. (A one tooth change on a pinion has a much bigger effect on your setup than a 1 tooth change on the spur)
Any time you are messing around with gearing changes, especially if they are a huge change to your setup (like, say, going from a 12/50 to a 15/50) you should get a digital temp gun to monitor your temps. The wrong setup will kill your electronics if you aren't monitoring temps.
LaTuFu is offline Find More Posts by LaTuFu
Old Jun 20, 2012, 08:29 AM
traxx de maxx is offline
Find More Posts by traxx de maxx
traxx de maxx's Avatar
uk
Joined Nov 2010
The temp gun is a vital tool to have and should be in everybody's toolbox.
traxx de maxx is offline Find More Posts by traxx de maxx
Old Jul 01, 2012, 11:40 PM
LikeABoss
Ditchdiger's Avatar
Joined May 2012
What would be a Size more on the fast side???
Old Jul 01, 2012, 11:42 PM
LikeABoss
Ditchdiger's Avatar
Joined May 2012
But not too fast and hot
Old Jul 02, 2012, 04:32 PM
Jeremy Kamutzki is offline
Find More Posts by Jeremy Kamutzki
Obeying the law of gravity
Jeremy Kamutzki's Avatar
Canada, ON, Cambridge
Joined Jul 2011
It completely depends on your car. What car do you have? For my rustler xl-5, a 16 tooth is necessary in the summer to keep temps down. In the winter I run the stock 19 tooth. Generally, the pinion that comes in the car is O.K., but not Ideal.
Jeremy Kamutzki is offline Find More Posts by Jeremy Kamutzki
Old Jul 06, 2012, 09:09 AM
LaTuFu is offline
LaTuFu's Avatar
Joined Oct 2011
What truck do you have? What size motor? What esc? What kind of batteries are you using?
Old Jul 06, 2012, 05:28 PM
uk
Joined Nov 2010
and what do you define as fast, Quick acceleration, or high top end.
Discussion What do these mean Pete1232 Electric Heli Talk 4 Jun 20, 2012 10:07 AM
Question What do "type a, b, c, d" propeller mean? DL8698 Engines 0 May 30, 2012 07:05 AM
Discussion The Most Popular Helis on RCG - What Do The Figures Mean? zadaw Micro Helis 14 Sep 25, 2011 09:16 PM
Question What do all these sizes mean? (300 size, .60, etc) Flying Dutchy Micro Helis 11 Jun 09, 2007 10:23 PM
