Old Jun 19, 2012, 06:01 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
Help!
cant bind
hi all,
my JR 9303 2.4 is not binding with any of my RX,,,for a year all is fine today i wanted to set my new motor and esc but it wont bind i test it with my other planes no binding,,,used the bind plug still nothing my satellite flashes very fast but the RX lite wont come on!!!!
what is wrong,,the radio powers up all programs work....
thanks
Ben
FASTBEN is offline Find More Posts by FASTBEN
Old Jun 19, 2012, 06:16 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If the sat is flashing rapidly but not the receiver then you have receiver issues.
There are reports of getting flashing led with the power connected in reverse with bind plug inserted but binding failing.
Ensure you have proper power and bind plug properly inserted. Once you have this addressed and both
The main and sat receivers are flashing then you can look at the radio
freechip is offline Find More Posts by freechip
Old Jun 19, 2012, 06:38 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
i have 5 RX's and none bind...
should't the button on the back of radio light up when pressed ?
Old Jun 19, 2012, 06:50 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Originally Posted by FASTBEN View Post
... should't the button on the back of radio light up when pressed ?
No, the LED on the back of the tranny turns off when you press the button to indicate the module is in range check (low power) mode.
But before you even turn the tranny on you must be sure the main and remote receivers are in bind mode - LEDs on all of them are flashing rapidly. If even one of them is not, there is no point of continuing with turning the tranny on in bind mode.
ivanc is offline Find More Posts by ivanc
Old Jun 19, 2012, 07:56 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
so what may be the cuz???
and how could 5 RX;s go bad on the same day?
Old Jun 19, 2012, 10:29 PM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The first thing is to check that the receivers are in bind mode, as discussed above. Then test that the transmitter goes into bind mode.
Hold the button while turning on and release it in a couple of seconds (exact timing is not critical). The button should be flashing rapidly. If it isn't you have a transmitter problem.
As noted above, both the main receiver unit and the satellites must be flashing rapidly for bind to take place. Sometimes there is a bad connection that prevents a satellite from going into bind mode or binding. This can usually be cured by unplugging and replugging the cable at both ends or using some contact cleaner.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jun 19, 2012, 10:40 PM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Ben
If I understand correctly you went to bind a new setup and it failed.
You attempted to "connect" to other models that were already bound and they failed as well?
You cant bind or connect to anything?
If so I hate to say it sounds like a bad RF deck in the Tx.
aerocal is offline Find More Posts by aerocal
Old Jun 20, 2012, 05:34 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
... used the bind plug still nothing my satellite flashes very fast but the RX lite wont come on!!!! ... Ben
This portion of your original post is a bit confusing.
Sat and Main receivers should go into bind mode when bind plug is inserted and proper power is supplied. Both units LED should be blinking fast before you move on and look at the radio.
Old Jun 20, 2012, 07:45 AM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
well no lights are blinking on any of the RX's that is what puzzles me,this should have nothing to do with my TX,until the lights come on in RX i cant find out if the TX goes to binding mode.
Old Jun 20, 2012, 07:50 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Check your bind plug.
Ensure the wire is not broken.
Once you have receiver confirmation that it's in BIND mode then you can move on to the radio.
Old Jun 20, 2012, 09:23 AM
aerocal is offline
Central California
Joined Dec 2006
Ben
In the OP you said "test it with my other planes no binding,,,used the bind plug still nothing my satellite flashes very fast but the RX lite wont come on!!!!".
Ok I see now.I guess I misunderstood.I still dont completely understand.
Your remotes are fast blinking but the Rx are not? I find it hard to believe multiple Rx/sat combinations are all doing the same thing all at once.
Are you sure you are understanding the bind process?
You have done this before? Right?
Are you using a known good power source?
Bindplug is in the Rx port marked bind?
If there is something about the bind process your not understanding please ask again.Your definition of what exactly is happening is kind of confusing.
To me anyway.I assumed you were mixing up the term "bind" and "connect"
with your other Rxs that also did not work.Thats what I get for making assumptions.
I think you need to be more clear exactly what you are doing and what is happening at the various stages of the bind (or connect) process to be able to get an accurate picture of what is going on here.
If your not getting a fastblink on main Rx and remote(s) when you power them with bindplug in then it is correct that there is no point going any further until you find out why.I kind of understand you had fastblink on the remote but not the main Rx? This would kind of indicate a borderline power supply.Ive found over the years that the remotes are very slightly more forgiving to lack of power than the main Rxs are.
Old Jun 20, 2012, 09:27 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
+1, only guessing at this point cause info is lacking or confusing.
Old Jun 20, 2012, 06:33 PM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Same confusion here - I don't see how a remote receiver will get into bind mode (LED flashing rapidly) while the main won't. Maybe the OP does not make difference between "bind" and "connect" and/or does not understand the binding process. Correct info from the OP is needed to be able to help him.
Old Jun 20, 2012, 06:59 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
By "RX" do you mean the main units? The satellites are receivers too.
I have seen cases where with the bind plug in and no Tx turned on, the main unit showed rapid flashing but the satellite showed something else, such as intermittent flash or weak steady light. The problem was the connector cable contacts.
But I haven't see the satellite doing the rapid flash of bind mode without the main unit doing likewise.
Please clarify what happens.
Old Jun 20, 2012, 07:56 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
ok lets see if i can do this correct.
i had flown 3 planes last week with these main RX ans satellite's i hook the power then my TX and all was good,i switched motor and ESC cc100 lite with internal BEC hooked my 4s and ESC beeped but no servo's worked,,,so i used my plug to see if i need to bind one more time still nothing so i grabbed my small hand luch with orange HK RX charged the battery and hooked up no flashing light on main i then took another plane same but in that one i could see a rapid flashing on satellite but very week the rest is history i used all other 2.4 dms2 RX's with a 2s 300mil 7.4 with regulator but no help the battery has fresh charge...
Help! cant bind my rc please help terrence.humbert 3D Foamies 1 Mar 11, 2012 07:10 AM
Question loss of bind after binding another rx robertc Radios 12 Sep 23, 2011 10:44 PM
Video Cant Bind My new parkzone 210 RX Decnav Electric Plane Talk 0 Feb 02, 2008 08:56 PM
Question It cant be that hard cant it?? corkyo4 Beginner Training Area (Aircraft-Electric) 20 Sep 22, 2006 09:53 AM
Bind bind bind hb888 Micro Helis 6 Aug 29, 2005 06:40 AM
