Old Nov 09, 2001, 10:49 AM
tenover is offline
Find More Posts by tenover
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Single/Dual Conversion
What is Single vs. Dual conversion? I just bought a HiTec Focus 3 FM Transmitter, a feather reciever (which is single cinversion) and a 555 reciever which is dual conversion. They both work with thr transmitter, but what's the difference
tenover is offline Find More Posts by tenover
Old Nov 09, 2001, 10:52 AM
risto is offline
Find More Posts by risto
Electrics rule
risto's Avatar
Bielefeld, Germany
Joined Jun 2000
See: http://www.torreypinesgulls.org/Radios.htm
Risto
risto is offline Find More Posts by risto
Old Nov 09, 2001, 11:14 AM
tenover is offline
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Thanks for the link, I've read that before, but it's like trying to learn a new language. Basically, I don't have anything to worry about, right? The dual conversion just will allow a longer range
Old Nov 09, 2001, 12:01 PM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Dual conversion is better at rejecting some common types of interference, that's all.
Some small single conversion receivers have poor range but it's not because they are single conversion it's because they are small and cheap.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Nov 09, 2001, 12:40 PM
tenover is offline
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Thanks, That's all I wanted to know...So it doesn't matter to your Tx whether your Rx is single or dual?
Old Nov 09, 2001, 01:36 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
All other things being equal, the range is the same for single conversion vs. dual conversion. Dual conversion is better at ignoring some types of interference.
Unfortunalely, all things are not always equal. Single conversion receivers have fewer stages (RF, oscillator, mixer, IF, detector and decoder) than a dual conversion (RF, two oscillators, two mixers, two IFs, detector and decoder). This makes them lighter and less expensive. Each stage performs a specific task - to amplify, filter or frequency shift the signal. The RF stage's primary affects the receivers ability to handle weak signals, but if you're dealing with small models that will only ever be within a couple hundred feet of the transmitter, the rf stage is unnecessary - why have a receiver that will pick up a signal a mile away if your only 100' away? So, if you don't need the range, receivers can be made even lighter and less expensive by eliminating the RF stage. For ecconomic as much as technical reasons, it doesn't make sense for a manufacturer to eliminate the RF stage from a dual conversion receiver so this usually only happens in single conversion receivers
So if you're looking for a rule of thumb...
If you buy a dual conversion receiver is is most likely a full range unit. If you buy a single conversion, you need to check.
gnofliwr is offline Find More Posts by gnofliwr
Old Nov 09, 2001, 03:40 PM
potifar is offline
Find More Posts by potifar
san marcos, ca
Joined Jun 2001
single or dual?
agree with most of the stuff said above - however, a well-designed single conversion receiver with a good quality IF filter, and a good linear front end, has only one small disadvantage over a dual conversion receiver, but it has many advantages.
the disadvantage is that channels 11, 12, 13 and 14 MAY have an image which MAY make them sensitive to transmissions on channels 56 through 60 -- for this reason, JR does not supply receivers on channels 11 thru 14.
however, AMA recommends that single conversion receivers use a crystal below the channel frequency - image problem gone - but is it? in the case of fm receivers, this crystal below the carrier frequency, inverts the detected pulse and you will find that you need a change in the receiver to cope with that - another reason that JR does not supply receivers on channels 11 thru 14.
other than that, a GOOD quality single conversion can offer the same range, narrow-band selectivity and 3IM performance as a dual-conversion receiver, and that at lower parts count, cost and size, and at comparable, or slightly lower, price.
peter
potifar is offline Find More Posts by potifar
Old Nov 09, 2001, 04:20 PM
Rotten Robbie is offline
Find More Posts by Rotten Robbie
Rotten Robbie's Avatar
Kent, Wa.
Joined Feb 2001
The last two answers are very good. The image problem is the real problem.
Use the single conversion recivers like th Feather and GWS Pico for park flyers.
For larger airplanes and especilly gliders, use a good double conversion reciever.
FMA makes very good double conversion recievers at a very good price.
Robbie
Rotten Robbie is offline Find More Posts by Rotten Robbie
Old Nov 10, 2001, 12:20 AM
BillJ is offline
Find More Posts by BillJ
Plains,PA,USA
Joined Jan 2001
The main problem with single conversion Rx's is that they MAY also "recognize" a signal that is 23 channels up or down (the image frequency) from their intended channel. For example, a plane flying on ch 20 might be hit by a plane flying on ch 43. This is common to AM, FM and older PCM gear and has been called the 23-skidoo. This is a function of spacing of Tx's on the flight line and the relative flight path of the aircraft to the Tx's. Range is primarily a function of sensitivity.
BillJ is offline Find More Posts by BillJ
Old Nov 10, 2001, 02:05 AM
risto is offline
Electrics rule
risto's Avatar
Bielefeld, Germany
Joined Jun 2000
As I read AM modulation is not affected by this.
From http://www.torreypinesgulls.org/Radios.htm
Current production techniques produce acceptably tight tuning and AM receivers (which are limited to signal ON/OFF, remember) typically limit their IF span to less than 5 Khz each way i.e., anything out of about 450 460 Khz is lopped off drastically thereby eliminating the 435 and 475 interference. So AM is happy as a clam with 20 Khz channel separation. The problem is with FM.
Risto
Single/dual conversion, narrow/ultra narrow band???????? thexfiles Radios 2 Dec 01, 2004 08:42 PM
Single and dual conversion? W99DEY Radios 9 Oct 12, 2004 04:24 PM
Single and dual conversion setup Zagijim Hitec/Multiplex USA 4 Aug 09, 2004 09:18 PM
F/S single and Dual conversion Xtals HItec/GWS NoM'rcrashPlease Aircraft - General - Radio Equipment (FS/W) 1 Aug 07, 2004 10:28 PM
Single, dual conversion crystals in transmitter? mill5471 Radios 2 Mar 02, 2004 11:44 AM
